#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer 3rd Generation > Stock 2002 - 2005 Explorers
Notices
Stock 2002 - 2005 Explorers Questions related to non-modified 2002 - 2005 Explorers and Mountaineers. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. Sport Trac and Sport use the 1995-2001 forum.
Replacing visor on 2004 Explorer
Reply
Thread Tools
Old 08-11-2008, 10:02 PM   #1
Gator
Charlotte, NC
2004 XLS 4.0Ltr
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I could use a little help with replacing a broken visor on my Explorer. It has the lighted vanity mirror, and I'm not sure how to disconnect and reconnect the electrical connection.
If you can help I would appreciate it. Thank you.
Gator is offline   Reply With Quote
( Join the Elite Explorers )
Old 09-14-2008, 11:25 AM   #2
PapiBigRed
Orlando, Florida
'04 Mountaineer
Vehicle Specs
Quoted: 0 Post(s)
I have the same problem. Did you hear anything or get it resolved?
PapiBigRed is offline   Reply With Quote
Old 09-14-2008, 01:39 PM   #3
bforan21
Tewksbury, MA
2002 Explorer Eddie Bauer
Vehicle Specs
Quoted: 0 Post(s)
I replaced my 2002 lighted vanity mirror visor without an issue. The electrical connection is in the headliner and it's accessible after you remove the mount.
bforan21 is offline   Reply With Quote
Old 09-14-2008, 10:24 PM   #4
PapiBigRed
Orlando, Florida
'04 Mountaineer
Vehicle Specs
Quoted: 0 Post(s)
Excellent! I removed the remnants of the mount and tugged on the wires to break them free of the tape in the headliner. Now I have a tan visor in my office and am looking for the mount and cover. The local dealership only has the entire visor available with the mount. Took some pics of the process to post for any others.
http://picasaweb.google.com/geoffhoo...62326644431650
Old 09-22-2008, 08:03 PM   #5
mmeagher55
Alexandria, VA
2004 Eddie Bauer
Vehicle Specs
Quoted: 0 Post(s)
PapiBigRed, thanks for the excellent photographs.
I'm trying to figure out what to do with the electrical wire. Did you just stuff it up into the hole before screwing in the mounting bracket?
Thanks for your response!
mmeagher55 is offline   Reply With Quote
Old 09-23-2008, 07:48 PM   #6
PapiBigRed
Orlando, Florida
'04 Mountaineer
Vehicle Specs
Quoted: 0 Post(s)
Are you referring to when you replace the visor? When I replaced mine, I just pushed the connector back in over the little indentation. It might jostle a little, but it's so tight I'm not too worried about it.
If you're not replacing the visor with an illuminated one, I would recommend just capping the open connector with some electrical tap, tie a piece of string on the connector and shove it back in. Leave the string hanging out just a little so you can fish it out when you're ready to get at it again. I'm just shooting from the hip on this one.
Old 05-25-2009, 11:56 AM   #7
dah
florida
2002 xlt
Vehicle Specs
Quoted: 1 Post(s)
how to remove mount cover
Quote:
I assume cap on headliner is a pop off. Don't seem to be able to get it off.
Don't want to crack it as I only have the mirror replacement part not
the trim stuff.
dah is offline   Reply With Quote
Old 05-25-2009, 12:27 PM   #8
XtremeRanger
Columbus, Ga
'95 Ranger XLT
Vehicle Specs
Quoted: 5 Post(s)
the trim stuff.
Keep prying on it....
__________________
Mine: 2005 XLT A4X4 V8 -171k - Railgrabs/Yakima Megawarrior, Full HID's - Steelcraft Grille Guard
Hers: 2002 XLT 2WD 4.0 Black everything but a sunroof., Manik Grill Guard, Mounty Cluster, Tint, HID's 137k
My Registry:http://www.explorerforum.com/forums/...d.php?t=388806
XtremeRanger is offline   Reply With Quote
Old 05-26-2009, 01:57 PM   #9
nygbrad
Longwood, FL
2005 Explorer XLT
Vehicle Specs
Quoted: 2 Post(s)
Yes I got mine off and the connector was way up there but I finally got it out. I am going to switch my visors to the 2006 and up. My sister has on ans they are connected with a solid one piece like they should be!!
nygbrad is offline   Reply With Quote
Old 05-27-2009, 12:46 PM   #10
freakadore
MI
2003 XLT
Vehicle Specs
Quoted: 0 Post(s)
Anyone know where i can get just the plastic mirror cover? The plastic tabs snapped off. Thanks!!!
freakadore is offline   Reply With Quote
Old 07-01-2009, 05:35 PM   #11
trsmith
vancouver
1991 XLT
Vehicle Specs
Quoted: 0 Post(s)
whenever my gal opens the mirror on the visor - the light comes on for 1 second and then the fuse blows that controls the dome light and the radio. Any suggestions, how to deal with this?
trsmith is offline   Reply With Quote
Old 07-01-2009, 05:40 PM   #12
nygbrad
Longwood, FL
2005 Explorer XLT
Vehicle Specs
Quoted: 2 Post(s)
I would suggest checking to see if the wire is getting pinched in the metal between the roof and visor mount. It sounds like it is grounding out somewhere.
Old 03-01-2010, 12:46 PM   #13
BigRondo
USMC 1371
Worcester, MA
BigRondo's Avatar
2002 XLT V6 4x4
Vehicle Specs
Quoted: 94 Post(s)
Papi, I just replaced both my visors with ones I got from eBay. The covers on the mirrors were broken off. I couldn't find just the covers so I replaced the visors. I have the old visors that have the mounts. PM me!
BigRondo is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
