Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1991 - 1994 Explorer Ranger Navajo 1st Generation > Stock 1991 - 1994 Explorers
Notices
Stock 1991 - 1994 Explorers For questions related to the base Ford Explorer. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. No modification questions.
Tommy
Reply
Thread Tools
Old 08-19-2008, 10:07 AM   #1
TB3
Reidsville, Ga.
94
Vehicle Specs
(Original Poster)
Tommy
Hi everyone.
Tommy here, I started working on cars at Midas muffler at 16. So at 46 now that makes about 28 years of really knowing what I was doing. I must have done 40+ brake jobs for my friends at the industrial plant I went 2 after midas.
Now I do have very mechanical skills on Brakes,shocks,and simple under hood things. Buuuut . Sons girlfriend has 94 explorer . They took it 2 a local mechanic with turning over but not cranking.He thought it might be fuel pump.now even I know 2 check relay or at least take fuel line lose before dropping tank. Not him. After dropping fuel tank and saying pump was good ,relay was bad it made it here. Not cranking again ,I swapped relays with A/C . Trying 2 crank A/C kicked in. Changed fuel filter because no gas was coming 2 top line on motor.When I had the fuel filter off tried 2 crank, nothing out of gas line below. Checked inertia switch, it was not popped up,ok right? Disconnected inertia switch, no start. Still no gas. Any help???
Tommy.
TB3 is offline   Reply With Quote
Old 08-19-2008, 01:03 PM   #2
Sams01XplrSprt
Southern Cali Explorer
Newport Beach California & Bay Area California
Sams01XplrSprt's Avatar
2001 Sport (sold)
Vehicle Specs
welcome
__________________
2001 Ford Explorer Sport 4.0 sohc engine. Mods include: dual 40 series flowmasters & high flow k&n air filter & removed silencer & yellow fog lights (sold for $1,800) as of 2-26-12
Sams01XplrSprt is offline   Reply With Quote
Old 08-19-2008, 08:25 PM   #3
BrooklynBay
Aerostar Forum Moderator
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
Welcome to this forum! Check the PCM relay, and the fuel pump relay. Do you see a check engine light on the dashboard when you turn the key to the accessory position? Check the crankshaft postion sensor, and the camshaft position sensor. Turn the engine with a ratchet or a breaker bar, and listen to see if the fuel pump keeps priming with every movement of your ratchet or breaker bar.
BrooklynBay is offline   Reply With Quote
Old 08-20-2008, 09:38 AM   #4
atistang
Ohio
94 XLT
Vehicle Specs
why not cut to the chase, is the fuel pump getting power??
and for shits and giggles see if you have any spark when you crank it, some vehicles will cut the power to the fuel pump if there is an ignition failure
atistang is offline   Reply With Quote
Old 08-20-2008, 10:13 AM   #5
TB3
Reidsville, Ga.
94
Vehicle Specs
(Original Poster)
Can see harness where I can disconect fuel pump 2 check for fire 2 fuel pump. All I have is 2 prong ac/dc power light. Ground 1 end 2 frame and other in slots 1 by 1?
Old 08-20-2008, 10:16 AM   #6
atistang
Ohio
94 XLT
Vehicle Specs
yes, but you need someone to turn the key to on, you should get power for about 2 seconds
Old 08-21-2008, 10:53 AM   #7
camnnikki
West Point, NY
'91 Eddie Bauer
Vehicle Specs
Have you thought about the possibility of water in the gas? I was working on a lumina just this week that had the same issues, had spark, good crank sensor, but no fuel going to the engine. Turns out that water had filled about a quarter of the tank and it ran over 900 to fix at the local shop.
camnnikki is offline   Reply With Quote
Old 08-21-2008, 11:10 AM   #8
410Fortune
ELITE BRONCO2ERER
Crawlorado
410Fortune's Avatar
B2 Mod
Vehicle Specs
hes not getting any fuel from the fuel line = fuel pump is not pumping
if th eFP is not pumping then you check the fuse and connections
If that looks good then you check for power and signal at the relay.
If that looks good check the relay
If power is being sent to switch relay on and then the relay is sending power to the pump then you check for power at the fuel pump wiring plug
if the power is there, you likely have a bad fuel pump
__________________
96 Explorer daily driver build-1996 XLT 5.0L AWD to 4x4 conversion complete on 33's
88 BII 5.0L conversion - BII 5.0l drivetrain thread
My Bronco II - 1988 Bronco II 4x4 V8 on 35's - registry and updates
Wifes 07 FJ build - 2007 FJ cruiser locked and lifted
410Fortune is offline   Reply With Quote
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
