#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
Rack and Pinion...
Reply
Thread Tools
Old 08-20-2008, 11:25 AM   #1
Dylansav
Twin Cities,Minnesota
'98 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Rack and Pinion...
We just replaced the engine on my 98' 4.0 SOHC and now we notice a LEAK. The power stearing fluid is pretty much pouring out of the rack and pinion seal at about a bottle a day.
For my truck, I need to replace the whole entire rack and pinion instead of just the seal that is leaking. Has anyone done that and how hard is it?
Dylansav is offline   Reply With Quote
( Join the Elite Explorers )
Old 08-20-2008, 02:54 PM   #2
Turdle
Move along people
nothing to see here
Turdle's Avatar
2000 Mounty
Vehicle Specs
Quoted: 652 Post(s)
It is a pretty tough job actually-could take a couple of days depending on your speed-
you'll need to remove the torsion bars--for instance. The front end comes apart and the rack slides out the passenger side, IIRC
I have changed one on a 97 eddie bauer. It took 2 of us all day.
__________________
Jon
9 mile skid, on a ten mile ride. Hot as a pistol but cool inside.
2000 Mountaineer
1998 Mountaineer "Turdle"-gone
1993 Convertible "Vitamin D Wagon" Sold also
Turdle is online now   Reply With Quote
Old 08-21-2008, 02:18 AM   #3
Dylansav
'98 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
It's my only option
The mechanic gave me a $800 estimate to do the job. $200 for parts..I could get what i need at my favorite auto salvage yard for $50 and i have most of the tools.
I think i'm going to follow what AllData online says and some from the Chilton manual for the procedures since i have never thought about attempting to replace the rack and pinion..But do you have any tips or tricks?
Any advice on this project would be much appreciated
Old 08-21-2008, 07:09 AM   #4
MountaineerGreen
Towing Moderator
North East Arkansas
MountaineerGreen's Avatar
2012 F150 4x4
Vehicle Specs
Quoted: 8 Post(s)
It can be done- lots and lots of patience and a few tools. I'd change one out for $600 though
Make sure you pay attention to where your lines go- if they are crossed, it doesn't work well.
Don't round off the fittings on the lines that connect to the rack. If they won't budge, go buy flare nut wrenches.
Save the boots off your old rack- most aftermarket boots suck.
When you get your new rack, remove both tie rod assemblies right out of the box, it helps get the rack on top of the crossmember, you can install the tie rods after the rack itself is in place.
The connection from the steering wheel to the rack is important and a PITA. Its a pinch bolt, remove it entierly, but it's difficult to get to. Make sure you don't turn your wheel with the rack disconnected or else is bye bye steering wheel clock spring.
MountaineerGreen is offline   Reply With Quote
Old 11-13-2008, 08:55 PM   #5
Dylansav
'98 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
sorry for the late reply on this one! This problem has kind of slipped my mind when the local dollar store has started to supply me with $1 bottles of ps fluid.
i really appreciate your guys' advice. i just have a few more questions...
Do you guys know of any sites that have a step by step process on how to do this?
if you are planning on getting bigger tires, would I have to change out the rack and pinion to meet the tires demands?
Thanks for the help
Old 11-14-2008, 12:37 AM   #6
dmac0923
Yorktown
2002 ranger xlt
Vehicle Specs
Quoted: 1 Post(s)
ive done the rack on my nissan sentra and it wasnt that bad to tackle.......i looked under my fords a little closer to see what its like on a 4x4. MAN! it defenetly looks alot more complicated....
how do you remove the torsion bars???
__________________
2002 Ford explorer 4dr eddie bauer 4.0 auto 4wd
2002 ford Ranger 4dr XLT 4.0 auto 4wd
1995 ford explorer 4dr XLT 4.0 auto 4wd
1969,1970 Mustangs
dmac0923 is offline   Reply With Quote
Old 11-17-2008, 01:26 AM   #7
Dylansav
'98 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
How do you remove the Torsion Bars...I was wondering the same thing haha!
Any tricks??
Thanks!
Old 11-17-2008, 06:07 AM   #8
MountaineerGreen
Towing Moderator
North East Arkansas
2012 F150 4x4
Vehicle Specs
Quoted: 8 Post(s)
You don't have to touch the torsion bars to change the rack and pinion..........
Old 09-28-2009, 12:46 AM   #9
Newbie Explorer
Topsham, Maine
'98 Sport
Vehicle Specs
Quoted: 0 Post(s)
i have a 98 ex. and i needed to swap out the rack and pinion, and i'm halfway through. i have a replacement part from the local junkyard but i've run into a bit of a problem. I've disconnected all of the hose fittings, the tires are off, the whole front end is on jack stands, and i cannot find a way to pull the old rack and pinion out through the passenger side. I've twisted and turned in just about every way i can imagine, and i'm halfway through removing the lower control arm in the hopes that that can give me the few extra inches of clearance i need. Any tips, photos, or general advice would be a great help, as i'd like to get it back on the road so i don't have to bum rides to work throughout the winter. Thanks for any help.
Newbie Explorer is offline   Reply With Quote
Old 09-29-2009, 02:37 PM   #10
ExploringNC
Hickory, NC
'98 XLT, '91 EB
Vehicle Specs
Quoted: 0 Post(s)
Take the boot off one side of the rack and remove the inner tie rod, then it sould come right out.
__________________
'91 EB 4.0 OHV 4x4
31x10.5 Maxxis Bighorn's
Uwharrie 2010
BrooklynBay's List of Useful Threads
ExploringNC is offline   Reply With Quote
Old 09-29-2009, 11:19 PM   #11
Newbie Explorer
Topsham, Maine
'98 Sport
Vehicle Specs
Quoted: 0 Post(s)
that would have been a way easier approach from the get go. thanks for the tip, i'll have to keep that in mind should i ever need to change one again. Somehow, Someway, that rack and pinion got changed and everything seems to work thus far.
Old 01-22-2011, 10:24 PM   #12
kronick
San Diego, CA
98 Ranger XLT
Vehicle Specs
Quoted: 0 Post(s)
I found this thread while looking for info on changing out the rack in my 98 Ranger. Just wanted to add some details from my experience for the next guy.
My Ranger is 2WD, 2.5L, Regular cab. That means I have a wimpy truck, but the rack and pinion came out with no issues. 2WD models don't have torsion bars, and there was no need to lift the engine like some posts I found.
I was able to remove the rack with the PS high pressure lines attached and the outer tie rod ends still attached. Getting those off was easy once the whole assembly was out of the truck.
To detach the pinch bolt on the steering shaft I used an 18" socket extension. It wasn't particularly difficult, though if I had an air conditioner in there it may have been a bit more tight.
I had a Pitman arm puller to get the outer tie rod ends off. Some people seem to have success hitting the steering knuckle, but the arm puller worked like a charm. Borrow one if you don't want to spend the $15 for your own.
Hope this helps someone out there. Good luck.
kronick is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
