Ford Explorer Sport Trac Ford Ranger Mazda Navajo Mercury Mountaineer, Ford Aerostar Message Board®
Ford Explorer, Sport Trac, Mercury Mountaineer, Mazda Navajo, Ford Ranger, Ford Aerostar SUV Enthusiast Forums
Join the "Elite Explorers Today!"
Explorer4x4 Sportrucks EF Arcade Forums Elite Membership Product Reviews Explorer Photo Gallery
Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Repair - Tech - Modifications & Detailing Forums > 2006 - 2010 Explorer Mountaineer > Stock 2006+ Explorers
Notices
Reply
Thread Tools
Old 08-24-2008, 01:36 AM   #1
exshipdriver
San Antonio, TX
2006 Mountaineer Premier
Vehicle Specs
Whooping noise from 06 Mountaineer
2006 Mountaineer Premier, V8 AWD.
I'm getting a whooping noise that sounds like it's coming from the right rear side. Noise is intermittent, and most closely resembles the start-up of a police car siren. (No cops behind me!) Noise lasts about a second, although on rare occasion it will drag on for a little longer than that.
It happens regardless of whether I'm driving, stopped at a light, or in park.
I can't forcibly replicate the noise or predict when it will happen. If there were some kind of a pneumatic load leveling system in the rear end, I'd suspect that since the noise could almost pass as air leaking out. (No beans for lunch.) It's definitely coming from the back end of the car and sounds like it's on the inside.
It doesn't sound like the same pitch as the back-up sensors. I also considered possible venting from the gas cap, but the noise happens regardless of tank level, temp, humidity, etc. Only other thing back there is the subwoofer, but I'm pretty sure it makes the noise regardless of whether the stereo is on or off.
Dealer couldn't replicate it, so no luck getting it fixed yet.
Any ideas? Thanks.
exshipdriver is offline   Reply With Quote
Sponsored Links (Less Ads)
Old 08-24-2008, 08:38 AM   #2
les_from_syracus
Vehicle Specs
Also have "whoop"
I just bought a 2006 Explorer last week and have the same intermittant "whoop". My vehicle seems to whoop when I am excelerating or rounding a bend, so I was thinking I have a bare wire somewhere that is contacting the frame, setting up one of the alarms. If anyone has fixed a similar "whoop:, Id be interested in what it was.
les_from_syracus is offline   Reply With Quote
Old 08-24-2008, 09:24 AM   #3
corkey
Elite COLD weather tester
lifted and lock, and FROZEN SOLID,, oh yeah,. in CANADA,,,,,,,
corkey's Avatar
96 XL and 90 Ranger XLT,
Vehicle Specs
i had a whooping noise in the front of my 96 , i rotated the tires it went away ,for a bit , than the noise moved, i looked at the tire ,it looked like a bad belt, and than replaced it,, no more noise,,
__________________
96 XL,some gears, axles,wheels,tires, lift kit, coilovers, back springs,shocks,stereo,subs,satellite radio,door speakers,amp bypass, and a few other things,,looks like enough for now,, till spring i guess,
In this world there are two kinds of people, my friend. Those with loaded guns and those who dig. You dig.
clint eastwood,
corkey is online now   Reply With Quote
Old 09-17-2008, 08:48 PM   #4
exshipdriver
San Antonio, TX
Vehicle Specs
Took it in again for the whooping noise/groaning problem, and the dealer wants to think it's everything BUT what I've described. Wind noise (replaced weatherstripping on a FRONT door), even though I've told them that it's coming from the rear end and I don't have to be moving for it to make the noise, aftermarket stereo (but it was doing it before I installed the aftermarket stereo), and they keep referring to it as a "pop" when I keep telling them it's a "whoop." I even printed out posts from several other owners have the same problem and gave them to the service rep to show that I'm not the only one having this problem. Yet there's apparently nothing in the Ford database of anyone else having this problem.
http://www.carcomplaints.com/Ford/Ex...rear_end.shtml
#s 66 and 73 at http://www.carcomplaints.com/Ford/Ex...shifting.shtml
If you have had this same problem and got it fixed, please let me know what your dealer did to solve it. It's not a something I can voluntarily replicate or predict when it will occur, so troubleshooting is tough. I'm thinking of riding in the 3rd row whenever my wife and I are in the car together so that if it makes the noise, I can pinpoint where it's coming from. Otherwise, I'm at a loss, and my dealer is too (or he doesn't want to deal with it.)
Thanks.
Old 09-18-2008, 09:41 AM   #5
exshipdriver
San Antonio, TX
Vehicle Specs
Another follow-up: Found the following posted by someone else at http://ford.justanswer.com/explorer/...d-explorer-xlt
Trying to see if the noise happens when rear AC is on. So far, only hearing it when it is off, so the guy who wrote this may be onto something. Anybody else?
there is a noise that I think may be yours ---see if this sounds right -- if you have rear a/c , there is a valve in that system -- this valve may make noise when the front a/c is on low blower and the rear a/c is off , it makes the noise more in this mode-- it will happen at any speed and make this hoot sound and you can not tell if its from the front or the rear --- to disprove my theory ,, try to see if the noise is there with or with out the a/c on --- if by turning the a/c off and driving and the truck and it never makes the noise ,, then I am on to something --- if it still makes the noise with the a/c off ,, well then I was wrong -----take your time and get back to be me ---noise problem are hard to diag , especially on the web ,,
Old 09-18-2008, 10:56 PM   #6
gjmarr
Calgary, Alberta
'06 Explorer XLT
Vehicle Specs
I first noticed the whooping noise on our way back to Calgary from Minnesota this summer. I first thought it was wind noise but, as noted by others, it can happen any time at any speed. Tonight it happened pulling into our driveway. The A/C was not on at the time (Calgary, mid-September, 8:15 PM, altitude 3500 feet - it gets cold when the sun goes down). The noise definitely is coming from the rear part of the vehicle and it does sound like it is inside. Strangest car noise I ever heard. Should I be concerned about it?
gjmarr is offline   Reply With Quote
Old 09-19-2008, 10:16 AM   #7
jrford
Birmingham, MI
jrford's Avatar
'04 EB V8 AWD
Vehicle Specs
I cant help with the wooping noise but i did have luck convincing a dealer of a problem with video clip using my Cell Phone. I took this other truck (jeep) in as it would just die anytime/speed etc. Service writer came back and said no problem found (no codes), but I pulled out my phone showed her that the check engine light comes on, hear the buzzer? They couldn’t dispute there was a problem. They wound up changing the CPS sensor which fixed it.
__________________
Jim
'04 EB Quad Buckets V8 AWD, 3.55s, Michelin LTX A/T2, Tow Hooks, Class III, roof rack, Audiophile/Sub
jrford is online now   Reply With Quote
Old 10-02-2008, 11:15 PM   #8
exshipdriver
San Antonio, TX
Vehicle Specs
So I sat in the way back for a little while and listened for the noise. I think the post that I found earlier about the rear AC compressor may be on the right track. The noise definitely comes from the rear LEFT side, basically in the back corner near the bumper. It also only seems to happen when the front AC is on low and the rear is off.
For gjmarr, understand temp differences in Calgary, but is it possible that you had the ac on but the temp set higher so that at least it was dehumidified air and not necessarily cold air?
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
Copyright 2010 - 1996 Rick Horwitz Photography
