Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
Speedometer not working problem
Reply
Thread Tools
Old 08-26-2008, 02:09 PM   #1
Dawara
Buenos Aires
'95 XLT 4x4
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Dk Exp Speedometer not working problem
This is my first post here !!
May be a common problem , sorry if I didnt found it on the forum.
My speedometer is not working. Just some movements when I am over 90mph.
On the speed sensor (on the transmition ) I got just one connection .(the 2 wire plug )
that is ok ??? there is no speedometer cable ??
Any Ideas ???
Is a ford Explorer 1995 xlt 4x4 ( like the 1996 model )
thanks in advance !!!
Dawara is offline   Reply With Quote
( Join the Elite Explorers )
Old 08-27-2008, 01:46 PM   #2
Dawara
Buenos Aires
'95 XLT 4x4
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
pleasee I need help !!
Old 08-27-2008, 03:15 PM   #3
Blacksheep Josh
Slinky+Escalator=Fun
Statesboro, GA
Blacksheep Josh's Avatar
'01 Ford Ranger, RIP 93 X
Vehicle Specs
Quoted: 13 Post(s)
The speedometer isn't moving at all? Or it stops moving once it reaches 90mph?
__________________
I haven't been on this forum in a while and I'm trying to work my way back into it. I'm going for Mod or bust!
"Thunder" Registry R.I.P. 2005-2012
2001 Ford Ranger Edge 5.0L Swap Thread
1991 Nissan 240sx Drift Pig
Blacksheep Josh is offline   Reply With Quote
Old 08-28-2008, 08:25 AM   #4
Cobraguy
Phoenix...Greatest City on Earth
Cobraguy's Avatar
1995 EB & 1999 EB 5.0
Vehicle Specs
Quoted: 13 Post(s)
Do you have a check engine light, or any other drivability issues? Does the cruise control work? If you have no other problems, then you must have either a bad wire from the splice to the instrument cluster, or a bad speedo itself. The VSS branches off from the sensor to the ECM, then to a splice to the Cruise servo, and then to another splice by the instrument panel that distributes the signal to several different locations and component.
__________________
http://banners.wunderground.com/weat...AZ/Phoenix.gif
Quote:
Originally Posted by four0sport
she is a girl, there are no answers, only more questions!
Cobraguy is offline   Reply With Quote
Old 08-28-2008, 08:52 AM   #5
Dawara
Buenos Aires
'95 XLT 4x4
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Dk Exp
Is not moving at all. Sometimes abobe 90mph it moves like crazy for a few seconds and stop moving again.
What I would like to know is how many cables or wires cames from the VSS (the speed senson)
THANKS !!!!
Old 08-28-2008, 08:55 AM   #6
MustangP51
Connecticut
2009 Limited V8
Vehicle Specs
Quoted: 4 Post(s)
It almost sounds like a loose or bad ground, but I wouldn't know where to look.
MustangP51 is offline   Reply With Quote
Old 08-28-2008, 08:56 AM   #7
Dawara
Buenos Aires
'95 XLT 4x4
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Check engine light is off and there is not other drivability issues. Cruise control is not working !!
This is a picture of my speed sensor.
Looks like something is missing?
Old 08-28-2008, 08:56 AM   #8
Cobraguy
Cobraguy's Avatar
Vehicle Specs
Quoted: 13 Post(s)
You didn't answer my question about any other issues.
The VSS has two wires that I can see. A pink with orange, and a gray with black. The latter is the actual signal wire that is distributed to the vehicle. I believe you'll find it's a white connector.
EDIT: You posted just as I was writing this. That should be your VSS. I think you'll find those wires clean up to the colors I posted. At this point, it's time to determine what, if any, signal is going where. Time to start taking readings. The VSS sends out an AC signal. First place I would check is the instrument cluster.
__________________
Old 08-28-2008, 02:11 PM   #9
Dawara
Buenos Aires
'95 XLT 4x4
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Dk Exp
So no cable is missing there ?
I must check on the instrument cluster if any signal is comming from the VSS ???
Could be a mal functioning VSS ??
The VSS is the only sourse of speed ???
Thank you very much for your help !!
Old 08-28-2008, 04:59 PM   #10
Cobraguy
Cobraguy's Avatar
Vehicle Specs
Quoted: 13 Post(s)
No...no cable on a 95. It's all electronic. The VSS could be bad, but if it were, then you should have other problems too. But I would check it to be sure.
__________________
Old 08-29-2008, 02:29 PM   #11
Dawara
Buenos Aires
'95 XLT 4x4
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Thanks Cobraguy !
(It is a 95 but like 96 and later model, is the same?) Sorry that I insist.
So, if maybe is not a bad VSS , where I can look for ???
Old 08-30-2008, 08:51 AM   #12
Cobraguy
Cobraguy's Avatar
Vehicle Specs
Quoted: 13 Post(s)
Check for a VSS signal at the cluster, the cruise servo, and any other place it may be, depending on the options on your car. If no signal, then keep tracing back until you either find it, or determine the VSS is bad. If you can get your hands on a known good VSS, just toss it in and see if it fixes it.
__________________
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
