Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Projects - Hobbies and Additional Topics > Projects - Hobbies - DIY > Home Improvement
Notices
Home Improvement Working on a project around the house, condo, or apartment? Questions about a home improvment project? This is the place!
Lets talk Digital TV and rabbit ears.
Reply
Thread Tools
Old 08-26-2008, 10:55 PM   #1
RockRanger
Elite Ranger
Fresno CA
RockRanger's Avatar
86 ranger no more
Vehicle Specs
(Original Poster)
Right now Tracy and I have 2 TVs and one set of rabbit ears to watch Tv off of. The current rabbit ears are some cheap ones from K mart. Nothing fancy about them. In the bedroom TV with the rabbit ears hooked up I can CBS and barely get NBC. That is it.
When we move the rabbit ears out to the living room we can barely get Fox, get NBC ok, ABC ok, CBS limited, and a local KUSI channel.
Both of the TV's are old school enough that I will be needing the converter box if we stay with rabbit ears.
My question is will the digital box help boost the signal so I can pickup channels better then then I do now? Also would a better set of rabbit ears help get the signals better as well? I just do not want to go drop a few hundred bucks on this stuff and not get any better TV. I figure in a year or year and a half we will probably get cable or directv anyway so it is only a short term solution.
Cable will run $40-50 a month so it will be cheaper to stay with broadcast but if I am stuck with only 2 channels then I will start forking over for cable even though we are only home for 8-9 days a month.
RockRanger is offline   Reply With Quote
Old 08-26-2008, 11:49 PM   #2
Tbars4
Offroad Moderator
anaheim hills,california
Tbars4's Avatar
95 ranger 4x4/ 91 X 4x4
Vehicle Specs
...This might help...Think of am radio and fm radio...When fm came to service it was digital, as in 102.7..
...For example:
...The chanel on tv, let's say your channel 8...It is now broadcasting as 8, 8.1,8.2,8.3...Channel 8 is the current broadcast signal...Channel 8.1 is the same channel being transmitted in a different screen format and is digitized...Now, channel 8.2 and 8.3 are addittional channels being broadcast from the same station...Say, 8.2 is there live newsroom feed and 8.3 is their uplink...
...I know, maybe to much info..
...Your reception area will still be critical for your rabbit ears..They do have rabbit ears that will be better and can pick up some of the digital channels but they use the dial style and you need to slide the channel in...
...I would look into getting a better roof antenna and the hd box...Most tv station sites have a digital tv info page as I believe it is required by the FCC...On these info pages they all have a link for a coupon for the digital box...
...This is the page from channel 8 and if you look at the bottom of the page, it has a link for the coupon...
http://www.cbs8.com/dtv/
...I hope this helps some...
...Now my problem, lol...How do I get digital on my 5" tv in the X???...
__________________
I have Rocks in my head. What's in yours?
'95 ranger xl 4x4 2.3L std cab, 2 sticks Ranger RegistryThe Squirrel
'91 4x4=To much to list, much more to add.. Project "X" and more Pics & Mod's List
How to: Wheels,Tires, & Lifts...
Buy Explorerforum.com Items here
Tbars4 is offline   Reply With Quote
Old 08-26-2008, 11:50 PM   #3
jad2411
I'm a jackass!
El Paso, TX
jad2411's Avatar
blue 02 xlt & white 02xls
Vehicle Specs
It costs 50 dlls and it does help a lot with reception, at my uncle's he gets more channels than he did before, so why not buy one and try it out?
jad2411 is offline   Reply With Quote
Old 08-27-2008, 12:35 AM   #4
Maniak
Moderator-Stock 91-94
Vail, Arizona
Maniak's Avatar
1992 XLT 4x4
Vehicle Specs
Here is my input since we just got DTV converter boxes...
We finally got a DTV since we have one really old TV and one bleeding edge HDTV. The old TV is an old sony.. So old that the remove is just one step above a clicker.. the TV only goes to channel 13. The big TV is a Panasonic HDTV circa 2000. That means no DTV tuner or HDMI inputs..
The old TV picks up 1.5 channels with the rabbit ears.. (Channel 13 is clear, channel 18 is very snowy)..
I tried both the Insignia available from Best Buy and the Apex dt250 (also available at best buy).. Neither box picked picked up any stations at all with the rabbit ears that pick up 1.5 channels of analog.
On the big TV we have a 160" Dual band big antenna on the roof.
We were getting snowy channel 4 and picked up 6 ,13 and 18 only.
I hooked up the DTV converter box and now get channel 4, four channel 6's(PBS), channel 11 (fox), three channel 13s (cbs), channel 18.
During the day we can pick up two more statoins...
Soo.. the DTV box "might" help, but it might not.. I'm going to replace the big old roof mount antenna with a grid style antenna (still directional). It should have better gain and much less wind loading (smaller antenna).. As it is now, I have it aimed at the tower which is 30+ miles away..
BTW.. Using the CEBC coupons the apex and the Insignia converter boxes are $19 from best buy.. After 2 days of having them I'm going to return the Apex box and exchange it for a 2nd insignia. The apex supports intelligent antenna (I think thats what you call it) and has s-video out but the remote control is so bad that the extra features don't mean anything.. the button clicks aren't seen, or it thinks you hit the button twice.. sometimes I got it confused.. I hit channel up and it thinks I hit channel down...
Just going to Digital cleaned up the picture so much, even when using the composit input on the tv that I'm not going to worry about running svideo..
~Mark
__________________
Click HERE to see our Explorer Specs
Maniak is offline   Reply With Quote
Old 08-27-2008, 03:42 PM   #5
Blacksheep Josh
Slinky+Escalator=Fun
Statesboro, GA
Blacksheep Josh's Avatar
1993 Ford Explorer XLT
Vehicle Specs
Don't forget, you can get coupons from the Gov't to help pay for the converter boxes!
__________________
"Thunder" Registry R.I.P. 2005-2012
2001 Ford Ranger (New!!)
"You can hear me when I'm coming" - Yung Joc
Blacksheep Josh is offline   Reply With Quote
Old 08-27-2008, 03:46 PM   #6
Maniak
Vail, Arizona
Maniak's Avatar
1992 XLT 4x4
Vehicle Specs
Quote:
That is what I did.. and they are good for 90 days.. If your going to use them online, don't wait until the last minute.. a few places I checked wouldn't take the coupons becuase ours were set to expire in 2 days...
~Mark
__________________
Old 08-27-2008, 03:57 PM   #7
SuRrEaLNJ
hail to the king, baby!
out of my mind...
SuRrEaLNJ's Avatar
MUNK 07 Focus 97 XL1200C
Vehicle Specs
what you guys really need to boost your pickup is to get an amplified antenna, wich will run ya somethin to the tune of 30-80 bucks depending how nice of a unit you want, ie variable gain, hdtv, etc
the converter box's only job is to make sure your old tv can interperate the new digital tv signal
__________________
Quote:
Originally Posted by Spas View Post
You are all lunatics, and Jay is your king!
BEN REALLY REALLY LOVES PINK
SuRrEaLNJ loves Hannah Montana
SuRrEaLNJ is offline   Reply With Quote
Old 08-27-2008, 04:04 PM   #8
Maniak
Vail, Arizona
Maniak's Avatar
1992 XLT 4x4
Vehicle Specs
You mean something like this? http://www.radioshack.com/product/in...entPage=search
I got something like that from a RadioShack amplified antenna (it looked like a 6 ft piece of square plastic tubing). It didn't help when we were running analog but I think I kept that amplifier and can always plug it inline with what we current have..
I do plan on replacing the old RS big antenna (160" 57 element) with a more effieicent high gain less wind load antenna.. but if an amplifier would help I'll do that too.
~Mark
__________________
Old 08-27-2008, 04:18 PM   #9
Stic-o
Elite Movie Star
Tujunga, CA
Stic-o's Avatar
'99 XL 4x4 & '06 XLT 4x2
Vehicle Specs
Remember that the new HD signal don't have anywhere close to the range of the old radio/TV waves. You probally need a Amp. Or just go pick up a small HD tv for a few hundred bucks.
It's cheaper then tires, Matt!!!
__________________
The JP Mobile ~'99 Explorer XL
The Mall Crawler ~'06 Explorer XLT
The Tow Rig ~ '05 F-150 SuperCrew
The Commuter ~ '10 Focus SES
Stic-o is offline   Reply With Quote
Old 08-28-2008, 01:13 AM   #10
SuRrEaLNJ
out of my mind...
SuRrEaLNJ's Avatar
Vehicle Specs
was refering more to the little tv, i honestly dont know much about roof antenas but what i was thinking was more like this http://www.bestbuy.com/site/olspage....=1118844608800
__________________
Old 08-28-2008, 10:52 AM   #11
Maniak
Vail, Arizona
Maniak's Avatar
1992 XLT 4x4
Vehicle Specs
Quote:
ahh.. gotcha.. that wouldn't work for us.. but may work for Matt.. We are considered Far Fringe. We are effectivly 30+ miles from the tower.
~Mark
__________________
Old 08-28-2008, 11:53 AM   #12
tdavis
Linux Guru
Jack of All Trades
Pinole, CA
tdavis's Avatar
2001 F250/XLT Superduty
Vehicle Specs
Get basic cable service - it's much better. I know, I know, you guys are never home..
Next step is to get a real antenna. I know it's cool to have Tracy hold the rabbit ears in weird positions (dirty minds!)..
The DTV tuners will either work or not at all. The beauty of digital TV is the signal is cleaner, when there is enough strength..
My last suggestion - for laugh and grins, is there any coax in the house? Hook it up and see what you get - sometimes they act as giant antenna's, and improve reception..
__________________
Thomas Davis
Chased vehicle -> Honda VFR800
Tow vehicle -> Ford F250 Superduty
Frankenstein Rock Crawler - > Suzuki Samurai (sold, onto the next project..)
tdavis is offline   Reply With Quote
Old 08-28-2008, 06:19 PM   #13
glfredrick
"The Pastornator"
Louisville, Kentucky
glfredrick's Avatar
86-98 Ranger STX
Vehicle Specs
I've found that digital signals are easier to tune than analog. When we actually tried rabbit ears (before cable and satellite) we could barely draw in the strongest local channels, and we had to constantly fiddle with the antenna.
Now, with a new 37" Samsung widescreen, we can draw in digital signals WITHOUT any antenna! Just the set alone -- no box, no nothing -- can draw in about 20 local channels. I was impressed.
We're still on cable (current landlord won't allow satellite, which is best by far) but the number of channels we recieve doubled from just the digital tuners in the set.
I'd get the converter box and see what happens... You'll need it anyway. One of our local analog channels is already sending scrolling messages across the screen saying that they will begin reducing power to their analog channel in October. Though the change comes after the first of the year, many stations area already in process and there are lots of things different already.
__________________
glfredrick is offline   Reply With Quote
Old 08-28-2008, 08:44 PM   #14
RockRanger
Elite Ranger
Fresno CA
RockRanger's Avatar
86 ranger no more
Vehicle Specs
(Original Poster)
I think we are just going to get a basic cable or satellite dish package. By the time I buy two converter boxes and another antenna I could pay for a few months of cable right there. I doubt I am very close to any of the broadcast points anyway because we live in the back country of San Diego. Now I just need to get around to running the coax cable where I want it.
I sure am not going to let the cable installers do it cause I have seen how they do it. I understand why they do it the way they do I just don't want it done on my house that way.
Old 10-10-2008, 05:40 AM   #15
johnd393
Valparaiso, Indiana
2001 Ranger Edge
Vehicle Specs
If you can, put up an antenna outdoor antenna. Rabbit ears are not worth fooling with unless you have no other option. Radio Shack outdoor antennas are fine for most people. Some people get good results with a outdoor antenna in the attic. The digital boxes will likely get more stations because each station can have 2 or 3 sub channels. The DTVPal box, sold at Sears, and Kmart, even has a program guide like cable or dish. Real high definition tv, HDTV is free from an antenna and can be a higher quality picture than cable or dish. The cheap converter boxed that the government coupons work on do receive HD but convert it down for standard tvs. It's still a good picture. Other set top boxes have been out for several years already that have hi def outputs. I think any new tv purchased now has the digital tuner in it.
Here's a link for the government coupons https://www.dtv2009.gov/
johnd393 is offline   Reply With Quote
Old 10-10-2008, 07:04 AM   #16
briwayjones
Sykesville, MD
briwayjones's Avatar
'00 XLS, '03 Sport
Vehicle Specs
Personally I think they're a waste of money. I've never seen an amplified antenna that worked better than a decent set of un-amplified rabbit ears. In fact I don't think I ever had one that even worked quite as well.
__________________
2000 XLS, 4DR, 4x4, OHV, Manual ; 2003 Sport, 2DR, 2WD, SOHC, Manual
Mobil 1 & Amsoil Synthetic Fluids, 2WD switch Brown wire mod, KKM air intake, overhead console, lighted sunvisors, custom 2nd HU install, '03 Ranger Fog lights, Hurst short-shifter, 75MM MAF, BBK 66MM Throttle Body
My 2000 Explorer
briwayjones is offline   Reply With Quote
Old 01-09-2009, 01:34 PM   #17
Tbars4
Offroad Moderator
Tbars4's Avatar
Vehicle Specs
...Hmmm, I keep hearing that this may not happen next month as planned...There seems to be talk about delaying this...
http://www.cbs2.com/video/?id=89035@kcbs.dayport.com
__________________
Old 01-11-2009, 08:40 PM   #18
TheJackal
Mandeville, LA
1999 Explorer XL 2WD
Vehicle Specs
My dad's been getting into the DTV conversion. He's a radio guy and kind of predicted this years ago.
They have DirecTV (which I can't stand, but can't talk them out of it) and they do get their local channels. However, they only get about 4 of them in HD, and they don't give you the additional channels (you get whatever one their main broadcast is in HD and that's it, no 6.2 or 6.3). That wouldn't be a big loss, but they like the 24-hour local weather station that channel 6 puts out, and they want to get PBS in HD.
To pick up all the rest, they had a set of rabbit ears hooked up to the DirecTV receiver (the HD ones used to have a digital tuner built in, the new ones don't and they had to bitch to get one when theirs broke). This let them pick up the additional channels and puts them in the line with the rest of the locals on the sat box.
There was also a TV in the bathroom that got its signal from an attic antenna. My dad went to RadioShack and bought this VHF/UHF antenna. This was so they didn't have rabbit ears in the living room anymore. The tuner in the bathroom TV is poor and doesn't pick up some of the stations if the signal is split. My dad ended up going back to RadioShack and buying this UHF antenna just for it.
The signal from the larger antenna was eventually split so the lounge TV could have a DTV converter on it in addition to the satellite box so they can pick up the weather and stuff.
As far as the rest of the DTV stations, at least here, you're not missing much. There's some religious crap on one of them, and another one plays old movies continuously. The only really useful one is the "Weather Plus," which I've seen in other cities, and if they'd get cable we'd get the Weather Channel and it wouldn't need it either...
If you do plan on getting an antenna for the new DTV stations, all you really need is a UHF antenna like this one. After the conversion, all of the DTV stations are going to be on UHF. Remember all antennas installed outside must be grounded and never installed near overhead power lines.
We mounted ours in the attic due to homeowner's association restrictions. They still work pretty well despite that, tho, and we are out in the boonies. We mounted them to a pole attached to this tripod, with the larger one underneath the smaller one. The smaller one is way up in the peak of the roof, which is out of the way, and though the larger one had to be lower it is still high enough it won't be in the way.
Oh and about amplifiers, we've tried a few, but have never been pleased with them with either digital or analog TV. They just don't appear to do anything. With enough money, you might be able to find a useful one, but with the right antenna you can get a pretty good signal especially if you're in town.
My prediction for the DTV conversion is that it'll probably get pushed back 6 months to a year, and then it will finally happen. The stupid people who still ignored the warnings will raise a whole bunch of hell, eventually causing it all to go back to both analog and digital signals.
TheJackal is offline   Reply With Quote
Old 01-11-2009, 09:35 PM   #19
glfredrick
"The Pastornator"
glfredrick's Avatar
86-98 Ranger STX
Vehicle Specs
When we had a dish, I used one of these with good success.
http://www.amazon.com/Terk-Amplified...tag=dogpile-20
They feed right in via the dish cable and if the dish is allowed, so is the antenna.
We now use digital cable, but I preferred DirecTV to Insight (other than having broadband Internet service!). I got more channels, with better quality for less money. I'll probably go back to DirecTV once I move out of the city, and for Internet, who knows? Depends how far out I am -- either cell link or satellite uplink (pricey).
__________________
Old 01-11-2009, 09:36 PM   #20
Maniak
Vail, Arizona
Maniak's Avatar
1992 XLT 4x4
Vehicle Specs
All channels are NOT going UHF.. Most channels will be there though. I'm looking for the chart again, but in the Tucson area one of the DTV channels is currently on UHF but once the transision officially happens they will end up on VHF.
I'll post the current and final channel assignment chart once I find it again.
~Mark
__________________
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
