EF Swag Store 2013 Ford Explorer Forums Elite Membership Chat Room My Posts Reviews Explorer Photo Gallery
Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer 2nd Generation > Modified 1995-2001 Explorers
Notices
Modified 1995-2001 Explorers Questions related to modified 1995-2001 Explorer, Mountaineer, Ranger and 2002+ Sports (2dr). Aftermarket accessories and modifications. Bullbar, running boards, floor mats, cargo mat, DVD headrest, wheels, tires, stereo upgrade, headlights, mud flaps, torsion twist, lift kits, engine swap, transmission swap.
cost for cam install?
Reply
Thread Tools
Old 08-27-2008, 04:02 PM   #1
GTexplorer
Dawsonville, Ga
96 XLT
Vehicle Specs
(Original Poster)
ive searched and found out that the comp 410 cam would be best for me. i know i will need longer pushrods. but how much is it going to cost me to have those installed? and does that 410 cam have a nice, loping idle?
__________________
1996 explorer XLT
1988 ranger 302
R.I.P. 2000 XLS 2x4
Proud to be American!
GTexplorer is offline   Reply With Quote
Old 08-28-2008, 08:09 AM   #2
Cobraguy
Phoenix...Greatest City on Earth
Cobraguy's Avatar
1995 EB & 1999 EB 5.0
Vehicle Specs
Call Competition Cams and ask them. They will tell you what you need to know.
Is this for an OHV V-6? You sure don't want much of a cam in one of those. Darn thing won't be able to pull itself out of it's own way at a stoplight if you do. Keep your lift high (beware of piston to valve clearance), your overlap down, and use a wide angle. No lope that way, but it will really help the torque...which is what will make the cam fun to drive. Again, call Comp and talk to them. Answer their questions honestly (don't exaggerate) They will make the best recommendation for you. Over camming an engine is the worst thing you can do for street use.
Curious...why would you need longer push rods? Does that cam have a smaller base circle?
__________________
http://banners.wunderground.com/weat...AZ/Phoenix.gif
Quote:
Originally Posted by four0sport
she is a girl, there are no answers, only more questions!
Cobraguy is offline   Reply With Quote
Old 08-28-2008, 09:15 AM   #3
GTexplorer
Dawsonville, Ga
96 XLT
Vehicle Specs
(Original Poster)
thats what i read from searching. that i would need longer pushrods, the valve springs would be ok. is anybody running a comp cam on a ohv?
__________________
1996 explorer XLT
1988 ranger 302
R.I.P. 2000 XLS 2x4
Old 08-29-2008, 03:03 PM   #4
GTexplorer
Dawsonville, Ga
96 XLT
Vehicle Specs
(Original Poster)
come on guys- i know theres some people with them in 1st gens
__________________
1996 explorer XLT
1988 ranger 302
R.I.P. 2000 XLS 2x4
Old 11-28-2008, 01:49 PM   #5
jd4242
va beach
jd4242's Avatar
92 SC
Vehicle Specs
i have the 410 in my 92 but have not started it just for the reason you just said i did not know i would need longer pushrods and now i am taking it back apart i hear it will need 5.525 and stock is 5.475 is this right im running stock rockers also somebody HELP!!!
__________________
92 xl 5.5"duff arms,3"BL,PJ 36x14.50,wrapped headers,side dump exhaust,.20 over,HF oil pump,422cam,45cc 95tm p+p 10.67:1 heads,p+p lower manifold,75mm TB,90mm maf,36lbs injectors,P+P GM M90 Supercharged & intercooled!!SCT tuned!!electric fan,4.88s aussie locked front & back!!next NOS&W/M
http://www.explorerforum.com/forums/...=double+vision
jd4242 is offline   Reply With Quote
Old 11-29-2008, 10:06 AM   #6
Cobraguy
Cobraguy's Avatar
Vehicle Specs
Again, call the manufacturer! That is your best source of information. Keep in mind that even though two engines may be the same, they can require different push rod lengths due to machining, tolerance stack, etc. Your best bet is to actually measure and see what you need. But the manufacturer can probably get you close enough.
__________________
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
