#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Explorer & Ranger Transmissions, Transfer Cases, & Differentials
Notices
Explorer & Ranger Transmissions, Transfer Cases, & Differentials Transmissions, Transfer Cases. A4LD, 4R70W, 4R44E, 4R55E, 5R44E, 5R55E, M5OD, BW 1354, Control Trac, GEM, AWD. Ford 8.8", Dana 35
changing throw out bearing
Reply
Thread Tools
Old 08-30-2008, 09:54 PM   #1
antiquecar
ft. thomas, ky
1997
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Cool changing throw out bearing
I have a 97 with a manual transmisssion. i have the Tran. out and can not figure how to remove the old throw out bearing from the slave and install the new one. It has got to be simple.
Thanks in advance
antiquecar is offline   Reply With Quote
( Join the Elite Explorers )
Old 08-30-2008, 10:27 PM   #2
RangerX
Moderator
Elite Ranger
Omao, Kauai
RangerX's Avatar
'93 Ranger XLT 4X4
Vehicle Specs
Quoted: 184 Post(s)
It's been a while, so I forget if it twists off (counterclockwise) or if there's a small spring clip. Slide the bearing down and see if there's a clip.
Are you replacing just the bearing and not the slave? If you're in there, you really ought to replace the slave. It's the most common failure point in these manual trannys.
Welcome to the forum.
__________________
Bill Collins
93 Ranger XLT 4X4
"Beauty is only sheet metal deep."
RangerX is offline   Reply With Quote
Old 08-30-2008, 11:36 PM   #3
HahnsB2
Battle Ground WA
88 Bronco II
Vehicle Specs
Quoted: 0 Post(s)
You really just have to pull hard to remove the bearing. Don't be cheap, replace both, I thought I could get away with just the throwout bearing, I felt stupid the next day when I had to pull my tranny again to replace a leaking slave.
__________________
88 Bronco II EB, 4.0L, M5OD, 4.56s, Aussie Locked 8.8, Aussie Locked D35 w/e-clip eliminator, Manual 1354, 3" PA Body Lift, 34x10.5 Swamper LTBs, Warn Hubs, U-Joint Drive shaft, OBA, Custom bumpers front/rear, 2 1/2" Exhaust w/flowmaster 40 series.
95 Dakota Sport CC, 5.2, 5-Spd(Hurst), 4x4, M1, HS 1.7 RR's, Aero Turbine 3030/Side Exit, 50mm TB, 30x9.50s on 15x8 Ultra 50 Series, 3.55s.
HahnsB2 is offline   Reply With Quote
Old 09-01-2008, 04:56 PM   #4
antiquecar
ft. thomas, ky
1997
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Smile still need help on the throw out.
Well the original had a thin retaining washer which I removed but the new one has a nylon clip. Do I need to try and install the old retaining washer. If so I need to remove the trans again since I didn't but thought about it later. Should have drank more.
Thanks
Jan
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
