Go Back   Ford Explorer and Ranger Forums "Serious Explorations"ģ > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1991 - 1994 Explorer Ranger Navajo 1st Generation > Stock 1991 - 1994 Explorers
Notices
Stock 1991 - 1994 Explorers For questions related to the base Ford Explorer. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. No modification questions.
Does a 93 Explorer XLT 4x4 NO EGR Have a CMP???
Reply
Thread Tools
Old 09-02-2008, 06:45 PM   #1
compton6974
Petawawa, ontario
93 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Just wondering if a 93 has a Cam Postioning Sensor or not?? Have a spare 92 Explorer Engine and i know it does not have one, so hopefully the 93 does not as well!!!
And also would a 92 Computer work on a 93??? Thanks
compton6974 is offline   Reply With Quote
( Join the Elite Explorers )
Old 09-02-2008, 09:33 PM   #2
bigtee
West Jordan, utah ( suburb Slc)
94 xlt & 04 xlt
Vehicle Specs
Quoted: 0 Post(s)
I have been trying to find the answer to the exact same question for
two days.. Exept I have a 94 4.0
So, according to Autozones website (and I quote)
"1991-93 and 1991-95 4.0 (VIN X) engines did not use CMP sensors"
It goes on to say that 1994 2.3l California engines did.
My Hanes manual does back this info up, you have to read it carefully.
My X flashes a cel code 214 constantlly, (CID something something)
and it points to a possible bad Crankhaft pos. sensor.
I tried to verify the lack of a cmp sensor by calling two other parts houses to
see if they had a sensor in stock, both said they dont show a cmp for a 94
4.0
Thats as far as ive gone with it. Anyone?
bigtee is offline   Reply With Quote
Old 09-03-2008, 05:12 AM   #3
mawrazen
Atlanta, Ga
94 Eddie Bauer
Vehicle Specs
Quoted: 1 Post(s)
I would say yes.
Part from Autozone for 1994 EB EX:
Duralast / Crankshaft Position Sensor
Warranty - 2 YR SU264 $35.99
1994 Ford Truck Explorer 2WD 4.0L MFI
__________________
Faith is the evidence of things hoped for, the substance of things not seen.
Ford count: 94 EB Ex (303K miles) , 94 Mustang Convertible,
"Don't touch the TRIM!" Freedom IS NOT Free!
Sometimes I'm here, but mostly I'm gone.
mawrazen is offline   Reply With Quote
Old 09-03-2008, 06:12 AM   #4
bigtee
94 xlt & 04 xlt
Vehicle Specs
Quoted: 0 Post(s)
Yes to which sensor Mawrazen?
As stated in my post, the Crankshaft sensor is used but our model does not
use a Camshaft sensor... (Camshaft sensor=CMP)
My local Autozone wants 38.99 for the Crank sensor...
Is that what your trying to say?
Thanks
Old 09-03-2008, 07:45 AM   #5
Four0Sport
West Virginia
1993 2dr
Vehicle Specs
Quoted: 41 Post(s)
http://www.partsamerica.com/ProductD...tNumber=CSS625
the 4.0L motor DOES have a camshaft sensor, it is a cam drive synchro that goes where the distributor would be like on a 2.9. the gear helps drive the oil pump just like a distributor would and there is a magnetic pickup on top that is the 'sensor' part of the camshaft position sensor.
__________________
1993 Explorer Sport, Narrowed HP44 SAS, UA2015 survivor
Four0Sport is offline   Reply With Quote
Old 09-03-2008, 03:27 PM   #6
compton6974
Petawawa, ontario
93 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Thanks for all the replys!! I see the spot u are talking about where a distributor would be but there is no electrical sensor coming out of it at all?? Would that still be it?
Old 09-04-2008, 06:46 AM   #7
mawrazen
Atlanta, Ga
94 Eddie Bauer
Vehicle Specs
Quoted: 1 Post(s)
From Advance Auto website:
For vehicle: 1993 FORD EXPLORER V6 4.0 Liter FI
6 parts found.
Product Description Availability * Price
Part No.
CSS551 BWD Automotive Crankshaft Sensor
Crankshaft Sensor:
Warranty: Limited 1 Year*
Ships in 2 days
$54.99
Part No.
CSS15P BWD Automotive SENSOR CRANKSHAFT POSITIN BWD
OE Style; Sensor
Buy online,
pickup today!
Ships in 1 day
$36.98
Part No.
CSS15 BWD Automotive Crankshaft Sensor
Crankshaft Sensor:
Ships in 2 days
$73.99
Part No. CSS13 BWD Automotive Crankshaft Sensor
Crankshaft Sensor:
Ships in 2 days
$54.99
Part No.
FF440D Niehoff Ignition Crankshaft Sensor
Engine Crankshaft Position Sensor:
Ships in 1 day
$48.99
Part No.
PC14 Standard Motor Products Engine Crankshaft Position Sensor Bracket
Ships in 5 days
$74.99
__________________
Old 09-04-2008, 10:03 AM   #8
410Fortune
ELITE BRONCO2ERER
Crawlorado
410Fortune's Avatar
B2 Mod
Vehicle Specs
Quoted: 3 Post(s)
91-92 no Cam pos sensor
93 ONLY CA or later year productions have cam position sensor
my 93 OHV engine did NOT have EGR or the CAM sensor
I have seen a few 93's that DO have EGR and the cam sensor
94+ has egr and cam sensor
If you are putting a 93 engine into a 92 truck you NEED to keep the 92 computer, the 93+ has two 02 sensors
Keep your 92 sensors and exhaust, if the 93 block is fitted with a cam sensor just forget about it (dont wire it up) and you will be golden
You can use any OHV donor from 91-2001 in your truck, you just want to take it down to the lower intake and heads, use your 92 fuel rail, accessory brackets, intakes, engine mount plates, etc
__________________
96 Explorer daily driver build-1996 XLT 5.0L AWD to 4x4 conversion complete on 33's
88 BII 5.0L conversion - BII 5.0l drivetrain thread
My Bronco II - 1988 Bronco II 4x4 V8 on 35's - registry and updates
Wifes 07 FJ build - 2007 FJ cruiser locked and lifted
410Fortune is offline   Reply With Quote
Old 09-04-2008, 10:40 PM   #9
Four0Sport
West Virginia
1993 2dr
Vehicle Specs
Quoted: 41 Post(s)
see i must have an oddball bc my 93 is non egr with 1 O2 sensor and ive always wondered about it, sorry to stray from the main topic, but it caught my attention
__________________
Old 09-05-2008, 03:08 AM   #10
seth247
Tulsa, Oklahoma
'92 XLT 4X4
Vehicle Specs
Quoted: 1 Post(s)
Maw, we gotcha buddy. The crank po's are on there!
But he's lookin for a CAMshaft pos sensor.
__________________
-Matt
Forest Green'92 XLT 4X4 302/4R70W
To all those in uniform, past and present. Thank You.
seth247 is offline   Reply With Quote
Old 01-03-2009, 06:07 PM   #11
Jamescurtis
Ca
93 XLT 4x4 6 cyl
Vehicle Specs
Quoted: 0 Post(s)
The Cam Position Sensor - To Be or Not to Be?
Happy New Year Explorer Owners!
I read an older post below Aug 2000 by "FORTUNE410" the following:
"93 ONLY CA or later year productions have cam position sensor"
"my 93 OHV engine did NOT have EGR or the CAM sensor
I have seen a few 93's that DO have EGR and the cam sensor"
SO, given some contradictions to the subsequent responses...the questions are:
1) HOW do we know for sure which "few" had the pricey Cam Sensors installed? Does it go by VIN/month veh made? What is "vin X"? One mechanic pointed to some wires and said they lead to the camshaft sensor, but never looked to verify it was there. Seemed suspicious to me that he didn't show me with a mirror when I asked him to visually confirm. It is supposedly on the rear of the block squeezed close to the engine fire wall. Which begs the next question,
2) Could I pull it myself with a mirror? What tools will I need? Is it easily damaged? How? Also, I understand a P214 points to sensors NOT a possible wiring issue, unless the wire leads to the sensor that encompases p214. Is this correct? If, so, would it be a waste of $$ to have an electrical expert do a electrical check for $45 - 60 dollars (or whatever can be negotiated). I am ok with doing it myself, but only if someone can point me to a great instructional manual that is affordable and comprehensive.
3) If the truck runs so well (like mine) with it still pulling a P214 error code pointing to either the cam or crankshaft position sensors (since I understand this code does not point to a particular sensor), are we Explorer owners sucking it up and paying about $800 to replace to just clear the engine light? This does not make sense...there must be a solution by pulling the camshaft sensor, cleaning it, and putting it back on. Maybe I am not as educated about this, but is the only consequence to a seemingly well running truck (with a bad CAM sensor) poor gas mileage?
4) What happens, besides not getting the engine light to turn off, if you ran the truck with a bad sensor given my 93 explorer runs fine? Are other parts wearing faster with a bad sensor?
Any mechanics out there that have come across this? What are my chances that if I replace just the crankshaft sensor, the P214 code will clear? I could live with testing this crank sensor first (assuming Autzone website walks us through this?), but this is, of course, an option I could afford (and hope for!!)
Thanks!!
Jamescurtis is offline   Reply With Quote
Old 01-04-2009, 12:26 AM   #12
Four0Sport
West Virginia
1993 2dr
Vehicle Specs
Quoted: 41 Post(s)
all the 4.0s have the cam sensor.. which is a timing sensor for the DIS, it is where the distributor would normally be on the back of the motor, even has a shaft with a drive gear that runs off of the cam just like a distributor. in actuallity it is a glorified distributor. the cam sensor itself is bolted to the top of the 'shaft'. installation of the shaft requires a cam alingment tool to get it within spec for it to run.
__________________
Old 01-04-2009, 12:41 AM   #13
Maniak
Moderator-Stock 91-94
Vail, Arizona
Maniak's Avatar
1992 XLT 4x4
Vehicle Specs
Quoted: 213 Post(s)
Quote:
Thats where it would be, but not all of the 4.0 OHV motors have them. I have a '91 sitting on the ground and a '92 motor in our X and they do NOT have a cam sensor. both have a crank sensor though.
~Mark
__________________
Click HERE to see our Explorer Specs
Maniak is offline   Reply With Quote
Old 01-04-2009, 12:47 AM   #14
Four0Sport
West Virginia
1993 2dr
Vehicle Specs
Quoted: 41 Post(s)
is the cam synchronizer there, the 'shaft', if not what is in its spot? doesnt the gear on the bottom of the synchro shaft help drive the oil pump? or am i getting confuzzled?
__________________
Old 01-04-2009, 12:54 AM   #15
Maniak
Vail, Arizona
Maniak's Avatar
1992 XLT 4x4
Vehicle Specs
Quoted: 213 Post(s)
There is a cover where it would go (Cam sensor). I don't remember seeing anything down that hole but I can take a look at the '91 motor that is sitting on ground in the morning..
Its been a while since we build the motor thats in the '92 (just over a year now.. and I've slept since then so details are fuzzy, but I don't remember messing with any shaft there..)but there is a shaft for the oil pump that you get to when you put in the oil pump.
~Mark
__________________
Old 01-05-2009, 02:26 AM   #16
arco777
arco777's Avatar
1994 Explorer 2dr 4x4
Vehicle Specs
Quoted: 99 Post(s)
Quote:
My 94 X was giving me a consistent CEL a while back with code 214, but ran well otherwise. Cleaning my dirty MAF and ugly battery connections fixed it for good.
__________________
-1994 Explorer 2DR 4x4 - Explorer Express X-Spec swaybars/shocks, BBK throttle body, Dynomax exhaust, misc trans upgrades.
-2008 Mustang GT Bullitt #5560 - Brenspeed tuned
-1995 fullsize Bronco 5.8L - intake, exhaust and trans mods, cosmetic mods.
arco777 is offline   Reply With Quote
Old 01-05-2009, 10:52 AM   #17
410Fortune
ELITE BRONCO2ERER
Crawlorado
410Fortune's Avatar
B2 Mod
Vehicle Specs
Quoted: 3 Post(s)
okay maybe I can help a bit here
91-92 have a single 02 sensor, EGR, no CAM sensor
93 has NO EGR, NO CAM sensor (Does have a crank sensor, all 4.0L's do) two 02 sensors
94+ has EGR, CAM sensor, two 02 sensors
95+ has plastic intakes
96+ is OBD-II obviously, 8 bolt crank
98+ has returnless style fuel system
SOME 93 trucks do have EGR and a CAM sensor, not all of them but some (my guess is CA trucks and later year 93 got the EGR back and the CAM sensor with it
You cannot use a 91-92 computer on a 93 engine, well I mean you could, but why? the 93-94 computer is better.
91-92 had a knock sensor also, some still had a MAP sensor and they used a single 02 sensor
My 2ea, 93 engines had no EGR and no CAM sensor, I loved that sucker! its now in Froaders truck
__________________
Old 05-09-2009, 05:22 PM   #18
josmen
Fresno, ca
91 Explorer
Vehicle Specs
Quoted: 0 Post(s)
Finding a sensor
Hello, I want to confirm that my 93 4.0l has the Cam Position Sensor, and I live in California, so that seems to fit with what has been posted before. My question is though, where the heck can I buy a replacment, tried all the normal places, autozone, napa, advanced, kragens, and then some, nobody seems to have access to them. I also check all the places listed in this forum, even Amazon and they have a picture that looks right, but don't have any available. I guess I can get one from a junk yard, but would prefer to get a new one, or one that I know before hand works. Thanks
josmen is offline   Reply With Quote
Old 05-09-2009, 05:43 PM   #19
seth247
Tulsa, Oklahoma
'92 XLT 4X4
Vehicle Specs
Quoted: 1 Post(s)
Have to try ford I guess.
Or Fastpartsnetwork.com. The owner is a member and sells oem ford parts.
__________________
-Matt
Old 05-22-2009, 09:38 PM   #20
fmanerchia
Marcus Hook, Pa.
94 XLT
Vehicle Specs
Quoted: 0 Post(s)
Iím a first time poster and I canít believe the wealth of information that Iíve found here. My son blew the head gaskets on a í94 4.0 with 194,000 miles, VIN:1FMOU34X0RUB14595. We found another engine. The original was stamped 11L93 and the replacement was stamped 23J92. The original had a CMP and the replacement didnít. Everything else was identical. The Haynes manual had a lengthy procedure for aligning it. Much of this depended upon the position of the pointer at the top of the CMP. We couldnít see squat through the plastic so we set both engines to TDC, scribed the CMP relative to something on the block, and removed and installed it in the new block as close as we could.
The car runs great, but itís throwing a 214 code. Since the CMP is like a distributor, could we advance or retard it? How would we gauge our success? I donít think that the CMP is bad but it is possible (probable) that itís misaligned. The engine didnít need a CMP when it was in itís original body so is it doing anything besides setting the code? Is there any way to cheat the wires going to the CMP sensor or should I just look for a í92 brain? Of course, hereís the million dollar question, can I just unplug the CMP?
Thanks,
Frank
fmanerchia is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
