| Modified 2002 - 2005 Explorers Questions related to modified 2002 - 2005 Explorers and Mountaineers. For Sport Trac and Sport models use the 1995-2001 forum. Aftermarket accessories and modifications. Bullbar, running boards, floor mats, cargo mat, DVD headrest, wheels, tires, stereo upgrade, headlights, mud flaps, lift kits, engine swap, transmission swap. |
Thread Tools |
#81 | |
Wannabe Elite Explorer
Southern Oregon
2004 Explorer XLT V6 4x4
Quote:
But as said, there would be no technical issues that would prevent you from doing this. Just the psychological issue of having stock tires on a rig that should be wearing some 32's. __________________ ![]() 2004 Explorer XLT 4.0L FFV V6 4x4 Pro Comp All Terrains 265/75R16 No Other Mods Yet (POOR AT CURRENT MOMENT!), but I am looking for input at my CarDomain. |
#82 | |
Canberra, Australia
2004 XLT 4x4
Quote:
__________________ 2004 Explorer Limited 7 seater, LPG SVI powered 4.6L V8, 4WD (with BWM 2WD coming), Auto, Lukey mufflers, Roof mount DVD system, HID driving lights (high beam)22s with 265/35/22 Atturo AZ800s |
#83 | |
Southern Oregon
#84 |
Oakdale Tn.
'05 XLT V8
My Spacers Are Installed
... You might remember that I wanted to raise the front end to level. I have installed 2 inch spacers to accomplish this. The only problem at this point is that the tie rod end nuts (both) did not live through popping out the tie rod ends. Ford was the only place that I'm able to find them and they had to be ordered. Wednesday before they come in. I've got her down off the stands and on her own wieght. The attitude is completely different. ![]() As soon as I have steering back, I'll take the "After Pictures" then attempt to figure out how to get them posted. I may have to go "Elite" to do this. I promised RoadBully that I would post pictures.
__________________ Mike (goatman) Henry 05' XLT 4x4 V8. 2" RoadBully Spacers (Front), 275/70/16 Yokohama's, Edlebrock RPM series muffler with 2 1/2" exhaust. K&N Filter 91' F150 4x4 351 XLT Lariat 94' XL, 4.0, 5 speed, 2" bl, 32x11.50(sold it )
#85 |
Potomac, MD
1997 EB
For those of you who have done the spacer installation, have you found that your trucks need an alignment afterward like the second gens do after a torsion twist? Thanks.
__________________ 2002 Limited 1997 Eddie (SOLD) |
#86 | |
Norfolk, Va
'02 Eddie Bauer
Quote:
__________________ 1998 Chevrolet Corvette 2002 Ford Explorer Eddie Bauer |
#87 |
Oakdale Tn.
'05 XLT V8
Well... Here is the first attempt at the picture thing. I've had to really pull in the pictures due to the size limit (note to self). Well with all that.. Here we go.
First Pic is the Ex as it was. Then some shots of the spacers as they went in. I'm going to re-do the after shots so the entire vehicle can be seen. Be right back. __________________ Mike (goatman) Henry 05' XLT 4x4 V8. 2" RoadBully Spacers (Front), 275/70/16 Yokohama's, Edlebrock RPM series muffler with 2 1/2" exhaust. K&N Filter 91' F150 4x4 351 XLT Lariat 94' XL, 4.0, 5 speed, 2" bl, 32x11.50(sold it )
#88 |
Oakdale Tn.
'05 XLT V8
Here is the end result of the installation of the front spacers.
#89 | |
Unregistered
Quote:
![]() thanks alot-sorry for all the questions chris (im doing 3 in front and 2.5 in back) |
#90 | |
Saint John, NB
Explorer XLS '02
Quote:
So How are you enjoying the lift Mike? |
#91 | |
Canberra, Australia
2004 XLT 4x4
Quote:
Goatman went with 2" lift at the front. __________________ 2004 Explorer Limited 7 seater, LPG SVI powered 4.6L V8, 4WD (with BWM 2WD coming), Auto, Lukey mufflers, Roof mount DVD system, HID driving lights (high beam)22s with 265/35/22 Atturo AZ800s |
#92 |
Saint John, NB
Explorer XLS '02
I'll keep track of pics we get here and post them up once we get a good range of sizes.
Right now we've got 3" front, 1.75" rear, ![]() 3" front ,3" rear ![]() 2" front 3" front, 2.5" rear 2" front, 2" rear
#93 |
2002 Mercury Mountaineer
RB, what are the tires (make and size) on the white ex you posted above with the 3" front and 1.75" rear lift?
#94 |
Saint John, NB
Explorer XLS '02
That's Ford02Exp's truck, and he's running 265/75R16 Mudd King Mud Terrains
#95 | |
Oakdale Tn.
'05 XLT V8
Quote:
Chris, I don't mind the questions. I did the install myself. Just to know the difference, I used a spring compressor for one side and did not on the other. Either way, I used the floor jack to raise the lower control arm to re-connect the upper control arm. Without the spring compressor, it was doable. Be prepared to really crank down with a lever to get the upper control arm down far enough to get the bolt started on the upper ball joint. With the spring compressor in place there was more movement available in the lower control arm. One more tip... You might as well disconnect the lower bolt of the strut assembly. I thought I could short cut this and it just didn't work. I didn't need extra bolts for the strut, However I did mess up the tie rod end nuts. They are hard to find so be careful. I guess the whole job took me five or six hours. The first side took longer since I was figuring things out. Let me know if you have any more questions .
#96 |
louisville
06xlt4x4
#97 |
Oakdale Tn.
'05 XLT V8
I suppose there might be a little more stress on the upper ball joint. I don't see additional stress anywhere else. As far as alignment, I've heard others with the coil spring lift have no need for alignment. My spacers have been on for a less then two weeks. To soon to see any odd wear.
#98 | |
Unregistered
Quote:
Thanks Chris |
#99 |
Savage,MN
Explorer 03 XLT 4.6L
Nice!
I was just wondering about how much more stress if any or life loss you lose from your axles since they are pretty much level stock and adding more height will make them at more of an angle maybe it wont do anything just a question i had in my brain and i thought i would bring it up. tony.
#100 | |
Saint John, NB
Explorer XLS '02
Quote:
| Tags |
| 3rd gen lift, explorer lift, lift spacers |
| Thread Tools | |
