Mostly the flare issue....it started when I took it for a test drive after replacing the rear brakes. I pulled up to the curb to put it in reverse and back into the driveway and it wouldn't do anything right away...just rev then it would continue into the gear. I tried it with overdrive then...same thing. The only gears the worked operational were to manually shift into 2 or 1. My brother suggested from reading on the forum to do a test by gearing down from 2 to 1 manually and if gears down it maybe something else. We have both looked into the value body diaries and I have purchased the following parts: EPC, Transgo Shift Kit, VLV ASY-TRANS THROT, PLATE TRANS SOLENOID. Now I am looking to purchase a overdrive solenoid, if you suggest that I should go that route as well. I hoping to get this complete this weekend and just not sure where to find the last part.
