#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1991 - 1994 Explorer Ranger Navajo 1st Generation > Stock 1991 - 1994 Explorers
Notices
Stock 1991 - 1994 Explorers For questions related to the base Ford Explorer. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. No modification questions.
93 Explorer Charging System Problem
Reply
Thread Tools
Old 09-15-2008, 09:29 AM   #1
mattbguitar
'93 XLT 4x4
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I noticed that the charging light on my Explorer stayed on so I checked the running volatge at the battery. It was only about 11.6V. I know for a fact that the alternator is working because it has been tried on another vehicle. I have no idea where to start looking for a problem. One thing though, I noticed that the running lights both stayed on fine, but when I turn on the actual headlights, the drivers side light goes off completely.
Another thing, although it may be unrelated, the vehicle lacks alot of power when going up hills. I probably just need a new fuel filter though.
Any ideas?
mattbguitar is offline   Reply With Quote
( Join the Elite Explorers )
Old 09-15-2008, 10:36 AM   #2
BrooklynBay
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
Quoted: 380 Post(s)
Welcome to this forum! You might have a high current fuse blown out.
BrooklynBay is offline   Reply With Quote
Old 09-15-2008, 11:06 PM   #3
mattbguitar
'93 XLT 4x4
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Quote:
Do you have any idea which one. None of the ones under the hood are labeled specifically to the charging system.
Old 09-16-2008, 10:26 AM   #4
BrooklynBay
Brooklyn, NY
Vehicle Specs
Quoted: 380 Post(s)
It might be a main one.
Old 09-16-2008, 03:32 PM   #5
Alan_V
Anaheim, CA
1993 XLT
Vehicle Specs
Quoted: 0 Post(s)
Any ideas?
A couple of simple things to consider as I don't have a manual at the moment. Check the output voltage at the alternator. As a rule, always check both ends of the wire. I it's better there, you've got resistance in the wire. Also try running a ground from the case to battery ground. Most alternators ground thru the case. Again, added resistance between the engine and the ground. Check the ground post of the battery for voltage. If you read more than 50mv, that ground is bad. If I have time when I get home, I'll go thru my manual and see I come come up with anything else.
Alan_V is offline   Reply With Quote
Old 09-16-2008, 06:19 PM   #6
XxxMonoxideChild
Rockford, IL
XxxMonoxideChild's Avatar
92 pile
Vehicle Specs
Quoted: 0 Post(s)
i just went through a similar thing. truck wouldnt charge. after replacing the alt, battery, battery terminals, starter relay, running a ground to the alt, all new charge wire, and even OEM wiring harness with plugs. my truck STILL wouldnt charge.
ended up being a bad ignition relay....? i still dont get the reason why, but our trucks alt dont just charge the battery when the engine is on. the ignition relay has to inform the alt also that the motor is on, and to charge the battery. to me, that sounds like complicating things alot more then they need to be, but the fact is, ford decided they liked that idea.
not saying the same issue is what your dealing with, but if you get to the end of your rope replacing EVERYTHING, and it still doesnt work, try it. it took me weeks to fix this issue till i figured this out.
one exception though. my charge light never came on at all. and the voltage was getting so low, the truck stranded me a few time's, so it really should have.
__________________
-1992 4 door exploDer 4X4
-- Mazda Navajo steering wheel, Navajo tail lights, 31X10.5X15's, Disc brake swap w/3.73LS, Larger rear sway bar, overhead console, auto dimming mirror, blue limited gauge's, cone filter intake, 5.0 MAF housing
~Link to pic's at the registry!~
XxxMonoxideChild is offline   Reply With Quote
Old 09-16-2008, 06:44 PM   #7
Alan_V
Anaheim, CA
1993 XLT
Vehicle Specs
Quoted: 0 Post(s)
Relay is about the second cheapest thing you can replace, so go get one. There are about 8 relays with the same part # in the box and at $6 each, you might just consider replacing them all. Cured an ABS problem I had last month. Light woudl come and go. Replaced the power relay and it's been fine ever since. Also fixed a blower problem a few years back.
Old 09-16-2008, 08:33 PM   #8
weldtron
Chicago, IL.
'93XLT
Vehicle Specs
Quoted: 0 Post(s)
Can anyone tell me where the ignition relay is located?
WELDTRON
weldtron is offline   Reply With Quote
Old 09-16-2008, 09:44 PM   #9
weldtron
Chicago, IL.
'93XLT
Vehicle Specs
Quoted: 0 Post(s)
Question Where is the relay located?
Old 09-18-2008, 09:09 AM   #10
mawrazen
Atlanta, Ga
94 Eddie Bauer
Vehicle Specs
Quoted: 1 Post(s)
Under the hood on the passenger side.
__________________
Faith is the evidence of things hoped for, the substance of things not seen.
Ford count: 94 EB Ex (303K miles) , 94 Mustang Convertible,
"Don't touch the TRIM!" Freedom IS NOT Free!
Sometimes I'm here, but mostly I'm gone.
mawrazen is offline   Reply With Quote
Old 09-18-2008, 11:33 PM   #11
Delta_1980
livingsville, California
92' exploder
Vehicle Specs
Quoted: 0 Post(s)
make sure you check the water level in the battery before you do anything else. My system wasn't charging , checked the fluid...topped off all the cells and bam... back in business . The cells (water level) should be right up to the plastic lip.
Delta_1980 is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
