#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer 3rd Generation > Stock 2002 - 2005 Explorers
Notices
Stock 2002 - 2005 Explorers Questions related to non-modified 2002 - 2005 Explorers and Mountaineers. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. Sport Trac and Sport use the 1995-2001 forum.
Aux Power outputs fuse Locations
Reply
Thread Tools
Old 09-16-2008, 09:18 PM   #1
johnd555
Wakefield Ma.
05 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
US Aux Power outputs fuse Locations
05 Ford Explorer refers these as the Auxiliary power point designed for accessory use only . ( phone charger , I pod adapters )
Hope this Helps anyone who losses Power in either one of the two 12 v outlets, Like I did in my 05 Explorer.
The Rear Power aux 12V output facing rear seats is Fuse # 7 in located in the power distribution box located under the Engine hood on the Drivers Side , it is a cartridge maxi 20A (blue) large size fuse that controls the rear power outlet, it is referred to as the Power point #2, it is located on the left side of the power Distributuon box, All the numbers are listed on the cover all the small fuses are clustered in the middle of the box, See the diagram on the bottom of the distribution box cover, but you have to read it upside down.
The Front Power aux output between the Front Seats is Fuse # 9 referred to as power point #1
Power distribution box is between the battery and the steering column on the driver side of the vehicle. Lift the tab on the end pointing toward the battery up and the cover snaps right off.
Hope this Helps
__________________
Johnny D
johnd555 is offline   Reply With Quote
( Join the Elite Explorers )
Old 09-06-2011, 08:30 PM   #2
Fixer upper 04
Austin, Texas
2004 XLT
Vehicle Specs
Quoted: 1 Post(s)
Convenience outlet fuse replacement
Thanks Johnd555. I should have read this post before trying to be a contortionist and searching under the dash for the fuse. Much easier and faster replacing the #9 fuse under the hood!
Fixer upper 04 is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
