Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1991 - 1994 Explorer Ranger Navajo 1st Generation > Stock 1991 - 1994 Explorers
Notices
Stock 1991 - 1994 Explorers For questions related to the base Ford Explorer. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. No modification questions.
Gas Leak @ Fuel Rail
Reply
Thread Tools
Old 09-21-2008, 11:33 PM   #1
TACO626
El Monte, CA
'91 XLT 4wd
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I've noticed a fuel smell for the past few days, diag and traced a drop of gas coming out the main fuel line that connects to the fuel rail/fuel pressure regulator.
-The fuel line is steel braided
-Connects to the fuel rail under upper intake from driver side
I used my air gun to dry it, immediately gets wet and instantly drips on injector
Anyone have advise on the fix, I am very capable of r+r upper intake and repairing the necessary.
I did my search but honestly did not find the exact problem.
91 4.0 xlt 4x4
TACO626 is offline   Reply With Quote
( Join the Elite Explorers )
Old 09-21-2008, 11:49 PM   #2
Willard
Bloomington, Indiana
04 Ranger Edge
Vehicle Specs
Quoted: 1 Post(s)
I would go in, remove the line, and see if it needs replaced or what. I'm gonna guess you just need to replace it, not sure how far it goes though.
__________________
Jesse
'94 Eddie Bauer DD/Beater
"Old Faithful" RIP
'04 Ranger Edge DD "Black Knight"
You want to see my face?
Willard is offline   Reply With Quote
Old 09-22-2008, 12:48 AM   #3
Blacksheep Josh
Slinky+Escalator=Fun
Statesboro, GA
Blacksheep Josh's Avatar
'01 Ford Ranger, RIP 93 X
Vehicle Specs
Quoted: 13 Post(s)
Yeah, just sounds like the connection is bad. Or possibly something isn't sealing up correctly.
__________________
I haven't been on this forum in a while and I'm trying to work my way back into it. I'm going for Mod or bust!
"Thunder" Registry R.I.P. 2005-2012
2001 Ford Ranger Edge 5.0L Swap Thread
1991 Nissan 240sx Drift Pig
Blacksheep Josh is offline   Reply With Quote
Old 09-22-2008, 10:10 AM   #4
TACO626
El Monte, CA
'91 XLT 4wd
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
The leak is where the hose nut meets the threaded part of the fuel rail
Old 09-22-2008, 11:43 AM   #5
Maniak
Moderator-Stock 91-94
Vail, Arizona
Maniak's Avatar
1992 XLT 4x4
Vehicle Specs
Quoted: 219 Post(s)
I'm assuming your talking the fitting at the back of the engine and not the one on the Fuel Pressure Regulator (FPR). I'm assuming that becuase you have a 1991 and unless you changed something the Fuel line going to the FPR uses a funky press on fitting instead of a nut connection.
If its not loose and assuming the threads on the fuel rail are good then the connector on the hose has to be bad (or a hole in the hose itself).
If thats the case you need to get some replacement lines from a junk yard. If your going to go that route I'd replace both of those flex lines to the style on the late 1992/1993-1994. That style uses a nut on the FPR connection also. Those FPRs seems to be easier to find and were cheaper when I needed one. Of course, if you do that you will need to replace your FPR to the other kind which can't "hurt", except for the cost of the FPR.
~Mark
__________________
Click HERE to see our Explorer Specs
Maniak is offline   Reply With Quote
Old 09-22-2008, 12:25 PM   #6
TACO626
El Monte, CA
'91 XLT 4wd
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Its a fuel line that connects at the driver side. The nut is roughly a 22mm? Looks like anyways, right above injector 6?
Anyways, I will be removing the upper intake soon and will have a better description
I greatly appreciate your help -
On a side note, Pick-A-Part is 7 minutes away and they will be having a 50% off weekend in a week or 2. I was there last weekend and I did see and peek around 2 Gen1 x's. Not sure exactly what years but hopefully will have the parts I need.
Old 09-22-2008, 01:30 PM   #7
Blacksheep Josh
Statesboro, GA
Vehicle Specs
Quoted: 13 Post(s)
oh man, if there's a 50% sale going on, i'm gonna have to go back home, lol.
i need axle, seat belt, seats, hood.... wonder if that's nation wide...
__________________
Old 09-27-2008, 03:45 PM   #8
TACO626
El Monte, CA
'91 XLT 4wd
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Ok so I attacked the upper intake this morning, all went smooth. Found the fuel line nut where it connects to the rail - loose! Inspected all very thoroughly and re-tightened nut. Replaced intake gasket, pcv valve, some fuel lines and a few vacuum hoses. Let it run for 10 minutes, road test to gas station, pumped $40, went to car wash and now I'm home. All looks fresh!
Time to have a 6pack to start
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
