Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
97 Explorer 5.0 Radiator
Reply
Thread Tools
Old 09-23-2008, 04:30 PM   #1
jkamin
stratford,nj
97 xlt 5.0
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
How do you get the radiator out of a 97 explore 5.0 V8, Hayne manual sez to remove shroud, mount bolts, did that. release clips at bottom annd lift out.
how do leave the AC condensor in
jkamin is offline   Reply With Quote
( Join the Elite Explorers )
Old 09-23-2008, 06:31 PM   #2
Sams01XplrSprt
Southern Cali Explorer
Newport Beach California & Bay Area California
Sams01XplrSprt's Avatar
2001 Sport (sold)
Vehicle Specs
Quoted: 4 Post(s)
welcome
__________________
2001 Ford Explorer Sport 4.0 sohc engine. Mods include: dual 40 series flowmasters & high flow k&n air filter & removed silencer & yellow fog lights (sold for $1,800) as of 2-26-12
Sams01XplrSprt is offline   Reply With Quote
Old 09-23-2008, 08:46 PM   #3
wpurple
CT
97 Explorer 12 Escape
Vehicle Specs
Quoted: 2 Post(s)
It is a little bit of a PITA, you have remove the fan (yup, that's right) in order to make room to move it about an inch and a 1/4 towards the motor to clear the clips of the condensor, then to the left I believe and up and out. Not sure what bonehead designed it.
wpurple is offline   Reply With Quote
Old 09-23-2008, 10:13 PM   #4
Dan Whitaker
One fast putty tat
Raytown MO (Kansas City suburb)
Dan Whitaker's Avatar
No Mounty no more.
Vehicle Specs
Quoted: 21 Post(s)
Quote:
Correct me if I'm wrong but I believe you need a special tool to remove the fan.
__________________
P r i c k me, do I not bleed Ford Blue.
Dan Whitaker is offline   Reply With Quote
Old 09-24-2008, 10:19 AM   #5
Cobraguy
Phoenix...Greatest City on Earth
Cobraguy's Avatar
1995 EB & 1999 EB 5.0
Vehicle Specs
Quoted: 13 Post(s)
You do Dan. It's one big bolt on deal. But you can usually rent them from Autozone, etc.
I have never tried to leave the condenser in the car. I've gone ahead and pulled them together. Everyone I've seen pull one does it this way. It may be possible, but it sure would be a pain in the butt that way even if it could be done. But I have the a/c equipment needed too. So I don't worry about it. Evacuate, unbolt the a/c lines, and pull it all as one unit.
__________________
http://banners.wunderground.com/weat...AZ/Phoenix.gif
Quote:
Originally Posted by four0sport
she is a girl, there are no answers, only more questions!
Cobraguy is offline   Reply With Quote
Old 09-25-2008, 02:44 PM   #6
wpurple
CT
Vehicle Specs
Quoted: 2 Post(s)
You do need a special tool for removing the fan, but removing the radiator from the condensor is just a pain, not at all impossible. A little patience, a few good adjectives and it comes out.
Old 11-22-2008, 06:08 PM   #7
beach
south florida
Mount/Ex/Fusion/boat lol
Vehicle Specs
Quoted: 60 Post(s)
Great, looks like I'll have fun with the radiator. I too wonder who designed some of this stuff with the 5.0 in this engine bay. If I ever find the one responsible for the location of the pcv, I will pimp slap them silly.
beach is offline   Reply With Quote
Old 11-24-2008, 09:43 AM   #8
jkamin
stratford,nj
97 xlt 5.0
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
5.0 exploer radiator
It can be done !!! Remove raduator hoses, shroud and trans line fittings. Remove the clips holding Radiator and condensor together. On the lower right side of the rad. find a clip, squeeze together and pull that side of radiator back. Keeping the clip out Slide Rad. to the right and up and out. If you think this is crazy check out the short hose between the water pump and the oil filter adapter. Have to remove the water pump or the adapter to change it. Try to stay calm!!!!!!!
Old 12-01-2008, 04:26 PM   #9
beach
south florida
Vehicle Specs
Quoted: 60 Post(s)
Damn I cannot get the radiator to budge from that clip, have it pressed and pulling and it won't move (the clip holding the radiator on passenger side at bottom).
Old 12-01-2008, 04:33 PM   #10
410Fortune
ELITE BRONCO2ERER
Crawlorado
410Fortune's Avatar
B2 Mod
Vehicle Specs
Quoted: 3 Post(s)
just bre glad they finally built an Explorer with the pushrod 5.0L, I can deal with the funky manifolds, the water/oil cooler and combioned AC/radiator its better then having 5 timing chains! LOL
__________________
96 Explorer daily driver build-1996 XLT 5.0L AWD to 4x4 conversion complete on 33's
88 BII 5.0L conversion - BII 5.0l drivetrain thread
My Bronco II - 1988 Bronco II 4x4 V8 on 35's - registry and updates
Wifes 07 FJ build - 2007 FJ cruiser locked and lifted
410Fortune is offline   Reply With Quote
Old 12-01-2008, 07:00 PM   #11
beach
south florida
Vehicle Specs
Quoted: 60 Post(s)
Ok I still can't get the radiator out, all bolts, lines etc are off/disonnected. I keep seeing people say "clips" and in the manual it says remove all "clips"....am I blind as I can only see one "clip" which is the one on the bottom passenger side?
Old 12-03-2008, 09:17 PM   #12
5litersplorer
Ontario
2000 Explorer 5.0L AWD
Vehicle Specs
Quoted: 0 Post(s)
LOL to the 5 timing chains comment. I would like to add that five timing chains isn't so bad, it's the 15 nylon tensioners that are the culprit. What were they thinking????????
Sole reason why I snapped up a 5.0L version.
5litersplorer is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
