Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
Rear hatch lock issues
Reply
Thread Tools
Old 09-26-2008, 07:44 PM   #1
LifeisaBeach
Vehicle Specs
(Original Poster)
Howdy all. I'm having some issues with the rear hatch on my 2000 Explorer Sport. The remote unlock won't open it, nor will the key open it. This once was an intermittent problem but now seems permanent. The only way to get the door unlocked is to crawl into the back and flick the lock switch above the wheel well a few times.
The problem seems to be an electrical one of some sort, but I have no idea where to start here. Anyone seen this problem before? Any suggestions? My wife has eliminated the idea of me taking it to the dealer for a potentially costly repair given what the value of the Explorer is these days, but it's a royal pain not having it work.
LifeisaBeach is offline   Reply With Quote
Old 09-26-2008, 10:38 PM   #2
gmanpaint
Torsion Bar Free
since 2010
gmanpaint's Avatar
94 XLT-95 FX4
Vehicle Specs
Since you say the key wont even work, leads me to think the lock actuator is sticking. The lift gate panel comes off very easy. 2 screws from the strap, plugs around the panel come off from a tug on the panel, or I use a door panel removal tool. A flat screwdriver will work for prying upon the panel plugs. Careful to not break them, you reuse them. Look at the lock mechanism, try to spray a lubricant, WD-40, or white lithium spray grease. You will see some small rods that will move with the lift handle, soak them good. Use a paper clip, push the weather door on the key entry, and spray a little inside the lock. After your all greased up, start working the lift handle open/close--open/close.
Then the key, side to side, in/out. If this works, congrats! You just saved some coin, and the misses will think your one handy guy, and she is lucky to have you! If not, you just eliminated one thing, and may need to try the electrical angle. Your Misses will still give you points for trying!LOL!
__________________
The Black Hole
Pugly
gmanpaint is offline   Reply With Quote
Old 09-27-2008, 03:59 PM   #3
LifeisaBeach
Vehicle Specs
(Original Poster)
Thanx gman. I took it all apart and checked out the lock. I could see where, when it wouldn't open, how the mechanism was moving slightly when trying to unlock with the remote. Repeated clicking of the unlock switch would move the arm a little bit at a time until it eventually reached the correct position. So I lubed everything up good and so far it's looking "mostly" fixed. It failed to unlock a couple times with the remote still, but the second try got it. Perhaps when the lube sets in some more, it'll be perfect. In any event, I seem much better off now. Thanx a bunch for the tip.
I'm having a similar problem with my driver's door lock, but I'll start a new thread on that since it's more complicated.
Old 09-27-2008, 05:30 PM   #4
gmanpaint
Torsion Bar Free
since 2010
gmanpaint's Avatar
94 XLT-95 FX4
Vehicle Specs
Welcome to the Forum! Glad to be of some help.
Tip, White spray lithium grease will last a long time, it has a straw nozzle like the WD-40 so you can get a good shot at your object.
I was thinking, does your lift handle have a crack in it anywhere? Does it come away from the door at all? Moisture/elements might be getting to the lock mechanism. Just a thought.
__________________
The Black Hole
Pugly
Old 09-28-2008, 11:22 AM   #5
LifeisaBeach
Vehicle Specs
(Original Poster)
Yeah, I used white lithium grease. Very good stuff. I avoid WD40 like the plague. I used to work in a skateboard shop years ago, and we were constantly seeing people come in who had used WD40 on their wheel bearings, and the WD40 had ate up the wheels. Nasty, corrosive stuff if it gets on the wrong things.
I didn't notice any cracks in the lift handle... it all seems ok here. Even the mechanism all looked ok to me from the inside. If the lube fix doesn't hold up long, I'll post back. Thanks again for the help.
Old 09-28-2008, 12:25 PM   #6
IAmTodd
Johnstown, PA
IAmTodd's Avatar
1994 Explorer XLT
Vehicle Specs
Were you able to get the key to work in the hatch? I haven't been able to use the key since I bought the vehicle. I pulled it apart but found nothing that appeared to be out of place.
__________________
1994 Explorer XLT | M5R1 swap | 2" Lift | 32" ProComp Mud Terrains
2006 Saab 9-3 Aero | 2.8 Full pressure turbo | 6MT | 280whp/325wtq
IAmTodd is offline   Reply With Quote
Old 09-28-2008, 03:39 PM   #7
LifeisaBeach
Vehicle Specs
(Original Poster)
I just checked it... key works fine now.
Old 09-28-2008, 04:30 PM   #8
IAmTodd
Johnstown, PA
IAmTodd's Avatar
1994 Explorer XLT
Vehicle Specs
Quote:
Hmm, Just another issue to iron out once I get back in the states!
__________________
Old 08-27-2009, 03:16 PM   #9
etraffic
breezy, mn
2000 ford explorer
Vehicle Specs
2000 ford explorer back hatch handle loose door locked
The linkage on the back hatch came unfastened and the handle was loose. Ford uses plastic fastener clips over perfectly good threads to hold this together. The outdoor plastic handle is only conected to the car with two aluminum ribets. One was already missing on mine. But if you just want to open the door, you can rip the handle off and pull it out. hopefully you won't crack the plastic. You can see the linkage screw hanging as you look up through the left hole. Grab it with a plyers and apply a steady force down. This will open the hatch. I just rigged up a different handle and put a nut on the treads to hold it together. This can all be done without tearing appart the interier and may only take 20 minutes. I used a rope and handle from the garage opener, a medium size washer and a nut. First make a small loop, with a small hole to slide over the linkage screw, then the washer, then the nut. Slide the other end of rope through the handle, move the handle very close to the vehicle and tie the not close. Trim the rope and wala ... the hatch works.
etraffic is offline   Reply With Quote
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
