Go Back   Ford Explorer and Ranger Forums "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
Annoying beeping noise on startup and every 40 minutes...
Reply
Thread Tools
Old 09-29-2008, 03:34 PM   #1
fedaykinone
Norwich, CT
'01 Explorer sport
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I've had an 01 Exp. sport for a bout five years now. Recently I'm getting this annoying beeping noise on startup and roughly every 30 to 40 minutes thereafter while it's running. When I start it, it's 5 sets of 5 beeps. When it's running it's 3 sets of 5 beeps. I've had problems with my airbag system almost since I've had it, and I noticed the little airbag indicator guy is no longer lit. I can't remember for the life of me, if he was lit or unlit when I got the damn thing. I need to make it stop before I lose my mind.
fedaykinone is offline   Reply With Quote
( Join the Elite Explorers )
Old 09-29-2008, 03:40 PM   #2
Dopler174
Official Welcome Committe
Greensboro, NC
Dopler174's Avatar
1993 XLT 4X4
Vehicle Specs
Quoted: 0 Post(s)
Crawl under the dash and listen for the beep anb where its comming from, and cut the wire making the noise maker. That is what I would do anyway.
Dopler174 is offline   Reply With Quote
Old 09-29-2008, 04:34 PM   #3
rwenzing
Michigan
03 Ranger FX4 LII 5.0 S/C
Vehicle Specs
Quoted: 2 Post(s)
The 5x5 beep is for the Restraints System. When the airbag light is not functional, the beep takes over. Replace the bulb.
__________________
Bob
2003 Ranger FX4 Level II, 5.0L V8, 4R70W, BW4406 T/C, Aussie Locker front, Torsen rear
Torque Monsters, Magnaflow, duals; Explorer EATC, steering wheel controls, consoles
Bilstein 7100 reservoir shocks, Cadillac/Mustang SVO rear discs, Duff traction bars
Ford owners' manuals ONLINE, then click on "Glovebox"
rwenzing is offline   Reply With Quote
Old 09-29-2008, 05:02 PM   #4
Cobraguy
Phoenix...Greatest City on Earth
Cobraguy's Avatar
1995 EB & 1999 EB 5.0
Vehicle Specs
Quoted: 13 Post(s)
Quote:
And then fix your problem...
__________________
http://banners.wunderground.com/weat...AZ/Phoenix.gif
Quote:
Originally Posted by four0sport
she is a girl, there are no answers, only more questions!
Cobraguy is offline   Reply With Quote
Old 11-05-2008, 09:32 AM   #5
joat
south carolina
98 X 4.0 ohv 2wd
Vehicle Specs
Quoted: 0 Post(s)
buckle the driver seat belt
joat is offline   Reply With Quote
Old 12-16-2008, 10:41 PM   #6
coppe
coppe's Avatar
01 xls v6 SOHC
Vehicle Specs
Quoted: 7 Post(s)
ive had the same problem for a while, actually since i bought my X a couple of months ago, and my airbag bulb is ok, and even with the two front belts bucked it keep on beeping as described above. BUT...... i´ve noticed the seatbelt bulb seems to be out..... i cant find any comments on the beeping beeing related to the seatbelt bulb, .... but can anybody enlighten me????? i would hate to do the bulb replacement (which apparently needs a very long taking apart process of the dashboard) and keep the beep afterwards.
coppe is offline   Reply With Quote
Old 12-17-2008, 07:50 AM   #7
Cobraguy
Cobraguy's Avatar
Vehicle Specs
Quoted: 13 Post(s)
removing the cluster isn't that difficult or time consuming. It appears daunting...but in actuality, it's not bad at all.
__________________
Old 12-17-2008, 01:30 PM   #8
coppe
coppe's Avatar
01 xls v6 SOHC
Vehicle Specs
Quoted: 7 Post(s)
well then i think that´s one of my next weekend proyects, thanks for the encouragement.
But also does anyone know if the beeps are related at all to the seatbelt bulb being out?? or do i need to get the truck scanned to search for some active codes that might result in the beeping??? should i be worried? or just go with it until i get some spare time to take it to the shop?
Old 03-10-2009, 08:25 AM   #9
99_Exp_SC
MCAS Beaufort, SC
99_Exp_SC's Avatar
99 Sport
Vehicle Specs
Quoted: 0 Post(s)
This was very helpful. I repaired the bulb and it fixed the problem. Thank you.
99_Exp_SC is offline   Reply With Quote
Old 03-11-2009, 08:56 AM   #10
jumpervb
roanoke,va.
2000 XLT & 2011 XLT
Vehicle Specs
Quoted: 8 Post(s)
Quote:
Do you have a procedure you followed to get to the light? How about where
it is located? I have the same problem with my 2000 explorer and I really need to get it fixed.
Thanks!
jumpervb is offline   Reply With Quote
Old 03-11-2009, 12:08 PM   #11
99_Exp_SC
MCAS Beaufort, SC
99_Exp_SC's Avatar
99 Sport
Vehicle Specs
Quoted: 0 Post(s)
US
http://www.explorerforum.com/forums/...ad.php?t=46290
This link should help you get the cluster off. Once you do that just replace the appropriate bulb. I didn't have to actually replace mine. I just finagled with it a little and it began working again. Good luck.
Old 07-28-2009, 12:50 AM   #12
verde1977mx
From Tijuana, Baja California
Explorer '01 Sport
Vehicle Specs
Quoted: 0 Post(s)
Hi to all, I actually have the same problem with my exp '01, but i have doubts 99_Exp_SC
wich bulb did you replace? the AirBag bulb or the SeatBelt bulb?
verde1977mx is offline   Reply With Quote
Old 07-28-2009, 12:55 AM   #13
BrianDye
I'll have another...
Monroe, MI
BrianDye's Avatar
2006 XLT
Vehicle Specs
Quoted: 77 Post(s)
Any bulb thats out...
__________________
06 Charcoal Beige XLT
Debadged in back, removed pin stripe, tinted fogs, LED conversion, black headlights w/Morimoto Mini retro, xB LED Halos, black bentley style grille, Tan cloth interior swapped w/black carpet, black leather/power/heated seats from a Limited
BrianDye is offline   Reply With Quote
Old 07-28-2009, 10:00 AM   #14
jad2411
El Paso, TX
blue 02 xlt & white 02xls
Vehicle Specs
Quoted: 1 Post(s)
The airbag one, but once you're there you'll want to replace all burnt ones, or for that matter all of them (they're cheap enough) so that you don't have to disassemble the dash again
__________________
If interior is to exterior and
include is to exclude, then
increment is to:
jad2411 is offline   Reply With Quote
Old 11-21-2009, 09:31 AM   #15
Tbirdsims
Farmingdale, NY
99' XLT 4X4
Vehicle Specs
Quoted: 0 Post(s)
My dad has a 99 eddie bauer, his has been beeping the airbag light is burnt out. Hes just running the truck till it dies out, i asked him what he wanted me to do, rip the dash apart or find the wire and snip it, he said find the wire...does anyone know where the wire is for that? a general location?
Tbirdsims is offline   Reply With Quote
Old 11-21-2009, 09:34 AM   #16
BrianDye
Monroe, MI
BrianDye's Avatar
2006 XLT
Vehicle Specs
Quoted: 77 Post(s)
x2 on that one, my 95's doing the same thing from the seatbelt light and I really dont wanna get back there again....
__________________
Old 11-10-2010, 09:23 PM   #17
Max458
Brownsburg IN
99 H.O. 4.0 4x4
Vehicle Specs
Quoted: 0 Post(s)
I have the same problem and have already takin that approach to solving it. The beeping is coming from a black box. It's about 3x6 in. All you do is remove the two 7mm bolts just above the hvac controls then pull the radio bezel out. Disconnect all your switches and maybe the radio too but I had enough room to not have to disconnect the radio. I also pulled out the vent box for more room. The box is on the left, its sitting there vertical, there's one 7mm bolt on the bottom holding it in place, then you pull it down so it slides out of place. There's four pigtails of wires going into it which was kinda surprising but the problem is the same beeping that comes from your doors being open with the key in the ignition, leaving the lights on and taking the key out and the annoying 5x5 sets of beeping even though they are in different tones is all coming from the same 1 lil 3/4 in speaker. Which is directly connected to to the circuit board inside the black plastic housing. I didn't want to even possibly hurt the circuit board be even attempting to disconnect the speaker. So basically... I met defeat and ended up just putting it all back together and decided to look harder on the internet for a resolution to the the very annoying beeping. Nor did I wanna lose the nice feature of it beeping at me when I do accidentally leave the lights on. But I think you could attempt to cut the wire sending the beep code to the speaker by taking a little ohm metering device and connecting it to each individual wire going into the little circuit board to see which on is sending the frequency or signal... sounds like it should work but it's just a thought. But for now I will just locate those bulbs and replace them and hopefully it fixes it. And one more thing... To take out the gauge cluster you have to 4, 7mm screws holding in the knee plate... there at the bottom. two of the bolts are holding in the hood release latch puller thing. then you take out the metal plate underneath it witch has 5, 8mm or 5/16 bolts holding that in. And of course you have to take out the radio bezel, then you'll find 5 7mm bolts holding in the housing around the gauge cluster 3 at the top and two at the bottom. then there's four 7mm bolts holding in the gauge cluster and theres ... 3 or 4 pigtails going into the back of the gauge cluster. And at the bottom left side of the cluster is the little nylon wire that goes to the P R N D 2 1 needle. That was a major nuisance... I didn't wanna disconnect it, because I didn't see any good way of doing so... so I just dealt with it in the way. The only reason I pulled the gauge cluster is cuz it sounded like the beeping speaker was behind it. I also took out two 1/2 in nuts holding the steering column up, to allow for more room, I did seem to help. There are also videos on youtube telling and showing you how to take out the cluster. But he never mentioned anything about the little bastard nylon wire going to the P R N D 2 1 box. Hopefully this all helps someone out.
Max458 is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
