Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
1999 Mercury Mountaineer rear lift gate will not open
Closed Thread
Thread Tools
Old 10-01-2008, 12:07 PM   #1
thunderfoot4too
Bear DE
1999 Mountaineer
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I'm looking for a way to open the rear lift gate on my truck, there is no tension on the release handle, and the rear window will not open either. I've tried pulling on it, pushing on it, having another turn the key while trying to open it, locked and unlocked the doors and nothing. ANY SUGGESTIONS??
thunderfoot4too is offline
( Join the Elite Explorers )
Old 10-01-2008, 02:00 PM   #2
heathmo
Davenport, IA
'99 Sport
Vehicle Specs
Quoted: 0 Post(s)
Sounds like my problem
I have a somewhat similar issue with my rear liftgate, basically I have to pound on the button that pops the glass to finally get it to pop. Then to lift the gate I have to hold the button on unlock and then I can get the gate to pop. Then of course I have to close the glass again to make sure I don't break anything. Something on the long list of things that I'd like to fix, but tolerate because there are plenty of more expensive things I need to fix. Hopefully that's a little help. If you're wanting it to work right, you'll have to pop the gate apart and fix that whatever's broken in there.
heathmo is offline
Old 10-01-2008, 02:37 PM   #3
thunderfoot4too
Bear DE
1999 Mountaineer
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
With a little research further into the forum I found this is a pretty common problem. Same resolution to fix it. WD-40. Believe it or not it worked. I can finally open the rear gate and window. Pop the plugs at the top of the inside panel and soak the release springs in WD-40, slip the straw into (the straw from the sprayer) into the key hole and give it a good soak. Let it sit and do it again depending how bad the stick is, mine wouldn't open at all. Turn the key a few times and you should be good to go. Surprised me that it could be that simple.
Old 10-01-2008, 07:56 PM   #4
Sams01XplrSprt
Southern Cali Explorer
Newport Beach California & Bay Area California
Sams01XplrSprt's Avatar
2001 Sport (sold)
Vehicle Specs
Quoted: 4 Post(s)
welcome aboard
__________________
2001 Ford Explorer Sport 4.0 sohc engine. Mods include: dual 40 series flowmasters & high flow k&n air filter & removed silencer & yellow fog lights (sold for $1,800) as of 2-26-12
Sams01XplrSprt is offline
Closed Thread
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
