| Explorer & Ranger Transmissions, Transfer Cases, & Differentials Transmissions, Transfer Cases. A4LD, 4R70W, 4R44E, 4R55E, 5R44E, 5R55E, M5OD, BW 1354, Control Trac, GEM, AWD. Ford 8.8", Dana 35 |
Thread Tools |
#1 |
Sunshine Coast Queensland
98 XLT
Check fliud hot or cold
Just had to top up my transmission fluid after a transfer case replacement and we have over filled it !.
After draining a good litre of fluid not sure when to check the level. With the motor running or not , hot or cold, can not search a solution or see it in the manual Also after driving around the block, i get a whirring sound off and on , could this be that the transmission is to full. I do not want to drive it again till i have the right level of fluid to see if that has gone away 98 SOHC |
#2 |
Wannabe Elite Explorer
Queens, New York and living in Budd Lake, NJ now.
2002 Explorer XLS 4.0 4x4
tranny fluid is checked with tranny at normal operating temp and engine running.
__________________ 2002 XLS 4.0 SOHC 4x4. Frantz Bypass filter, Mobil 1 5W30.Perma-cool dual remote (2 full flow PureOne PL30001). Perma-cool remote transmission filter (Pure One PL30001). Scanguage II, Sunpro Oil Pressure Guage Gen 4 mirrors "The More Complex The Mind, The Greater The Need For The Simplicity Of Play" |
#3 |
98 XLT
So it appears that i may not have overfilled it and it needs more , with the motor running the indicator has no oil on it but when i switch off the motor the indicator is covered in oil all the way up ?
So i should just keep filling till the indicator is correct whilst running |
#4 |
Human-Animal Hybrid
Carmichael, CA
'97 Sport 4x4
Yes, pour in about 1/2 qt (< 0.5 L) or less at a time to avoid overfilling.
#5 |
Yep fill it more. Then go through your gears, drive, 3,2 etc... and back to park. Check fluid again.
#6 |
Anchorage, Alaska
'97 Explorer XLT AWD 5.0L
I know it states in Chilton manuals to always check the fluid when the engine is warm, and after a few miles of driving to get the transmission fluid to normal operating temperature.
What I do, is pour in ~1/4 of a qt, hop in the truck, switch through all the gears multiple times, holding each gear for about 10 seconds. After putting it back into park, let it set a minute or 2 to make sure all (most of) the fluid has drained down the tube, then check the level a couple times. Repeat as necessary. __________________ Daily Driver: 1997 V8 Explorer - K&N FIPK, Granatelli MAF, 3" Body Lift, WAR-153 Shackles, Torsion Twist, custom-built skidplate. 4.56s, Ion Alloy 133's, 33x12.5 Interco TrXus STS. 1986 Bronco2: RIP |
| Thread Tools | |
