Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer 3rd Generation > Stock 2002 - 2005 Explorers
Notices
Stock 2002 - 2005 Explorers Questions related to non-modified 2002 - 2005 Explorers and Mountaineers. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. Sport Trac and Sport use the 1995-2001 forum.
Thermostat Housing Leak?
Reply
Thread Tools
Old 10-03-2008, 10:09 PM   #1
just2dune
mesa,az.
2003 explorer xlt
Vehicle Specs
(Original Poster)
US Thermostat Housing Leak?
Took 02 Exlpr XLT 4.0 to dealer for a leak. Dealer says has warped thermostat housing, of course not covered under extended warranty. Going to take care of myself. Is it a basic thermostat and housing replacement or are there any tricks that I need to be aware of to make the job easier? Can't believe dealer quoted over $500 to replace..
Thanks!
just2dune is offline   Reply With Quote
Old 10-03-2008, 10:29 PM   #2
XtremeRanger
Columbus, Ga
'95 Ranger XLT
Vehicle Specs
My GF's just started leaking today. Its a 10 minuites thing to replace yourself if you have some tools....
I just replaced my Moms on her 98 and had to remove the upper intake manifold. Her part was $230. For the 02 models the intake was redsesigned and made it EASY to take off....I literally took my GFs of in 5 minutes. Not sure of the price yet, its leaking at the seam so Im going to try some plastic weld or somthing first before I go looking for a new one.
My Moms was cracked so it couldnt be fixed at all....
For $230 tho, it came with new temp sensors and the thermostat as well.....Decently price for everything. I think wy GF's will be cheaper...it has One less sensor it it....
$500 is WAY too much!.....Bend over....
It cant be "warped" the dang thing is PLASTIC!
__________________
1995 Ford Ranger - Not Stock
2002 Explorer XLT 2wd 4.0 Black everything but a sunroof., Manik Grill Guard, Mounty Cluster, Tint, Yakima MegaWarrior Basket, 6K HID's
2005 Saturn VUE Redline AWD
2006 Saturn ION Redline - in the rebuild process, shooting for 300HP
XtremeRanger is offline   Reply With Quote
Old 10-03-2008, 10:40 PM   #3
fixxxer
Aurora, Co.
93 XLT 4X4
Vehicle Specs
Many types of thermo-plastics CAN warp, so can ABS plastic, especially if there is uneven tension on the plastic mounts.
__________________
-Larry
93 XLT 4x4
90 Celica GTS
97 Camry
Ford Explorer and Ranger Owner's Guides and more...
fixxxer is offline   Reply With Quote
Old 10-04-2008, 11:51 PM   #4
not8taxi
queens, ny
not8taxi's Avatar
02 XLT
Vehicle Specs
Quote:
Thanks!
it should be the lower thermostat housing...i actually replaced this on my 02 ex....you would have to drain the antifreeze from the car to replace the housing...i went ahead and got a new thermostat and replaced that as well...just make sure u get the housing, the gasket for the bottom of the housing and a thermostat...if your handy you shouldnt have a problem...here a link to the other thread http://www.explorerforum.com/forums/...38#post2031438
not8taxi is offline   Reply With Quote
Old 07-15-2012, 01:38 PM   #5
mdawson2121
Columbus, Ohio
2004 Ford Explorer V6 4X4
Vehicle Specs
I have an 04 explorer 4.0 L flex fuel. I just replaced my housing, o-ring, gasket, coolant temp sensor and thermostat for less than $80.00. it took me about 20 minutes to take the old one out and put the new one in.
Let me know if you need help, I got most of my parts from Advance Auto Parts with the exception of the housing, housing had to be purchased from dealer for $53.00
All you need is pair of adjustable pliers and set of metric ratchet sets
mdawson2121 is offline   Reply With Quote
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
