Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Under the Hood > Explorer, Ranger, A/C & Heater systems HVAC
Notices
Explorer, Ranger, A/C & Heater systems HVAC Ford Explorer, Ranger, Mountaineer, Bronco II, Air Conditioning and Heating Systems.
2003 XLT clicking in dash, no heat
Reply
Thread Tools
Old 10-11-2008, 01:14 PM   #1
grabill68
2003 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
From other posts on here it seems to be the actuator, I have removed radio trim and console. I located the actuator but I can't figure out how to get in there and remove screws. Is real tight in there. Any suggestions would be appreciated.
grabill68 is offline   Reply With Quote
( Join the Elite Explorers )
Old 10-11-2008, 01:59 PM   #2
Mustang Mike
Jefferson, SD
96 Eddie, 93 xlt, 04 xlt
Vehicle Specs
Quoted: 1 Post(s)
Help
I think the bolts are 7mm
Use a 1/4 inch drive ratchet to get the very top bolt, you have to remove
the trim under the steering wheel, then shine a flash light to see the bolt,
use about a 10" extension
The use the same ratchet to get the very bottom one, you will need an angle
after the socket, or you can use a wrench to get that one. To get the other
top one, remove the radio bezel, unplug your 4x4 harness, and you heater
controls. You have to use the wrench to get this one.
Putting the actuator in is interesting, feed it through the opening by the
radio and crawl under the dash to line up in the hole. Make certain that
you have the temp control all the way to cold before removing that way you
know what position the blend door is in. Then before you install new
actuator, plug it in and go to hot, then back to cold to make sure the new
actuator is in the cold position. This actuator moves very slow, don't let
that scare you. in fact my old one worked fine out of the car because there
was no pressure on the broken gear.
Put the top bolt in first with the long socket. I have to put some glue off
of my kids glue stick to hold the bolt in the socket so it doesn't fall off.
Then put the lower bolt in, I used my wrench for that one, and the one in
the radio spot I didn't even try to put back in, works fine with two in.
Good luck, keep going you'll get it, took my 2 1/2 hours and I am no
mechanic!
Let me know if you have any questions or need pictures. I will check my
email all day.
Michael
See this post:
http://www.explorerforum.com/forums/...ht=sleb&page=2
Mustang Mike is offline   Reply With Quote
Old 11-07-2010, 04:51 PM   #3
DIGGAR7
LINCOLN RI
2003 XLT
Vehicle Specs
Quoted: 0 Post(s)
Sounds like the problem
Thanks
mustang mike
it sure soundss like the problem the actuator
for the no heat problem.
I heard this clinking but could not quite pin point it but i did notice this little white box i guess this is a small gearbox and the gears inside must be strippred
i will attempt to replace thanks
DIGGAR7 is offline   Reply With Quote
Old 11-07-2010, 05:38 PM   #4
BigRondo
USMC 1371
Worcester, MA
BigRondo's Avatar
2002 XLT V6 4x4
Vehicle Specs
Quoted: 94 Post(s)
Quote:
Originally Posted by DIGGAR7 View Post
Thanks
mustang mike
Welcome to the forum!!
Here is the thread you are looking for!!
http://www.explorerforum.com/forums/...d.php?t=294140
Hope this helps out!!
__________________
Rondo - USMC, Combat Engineer, 1983-1996
Click here for a list of my write-ups!
Quote:
Originally Posted by FIND on 4-22-13
Don't mess with Boston. They will drop everything, hunt you down, and then go on like you never existed once they are done cleaning up the mess.
BigRondo is offline   Reply With Quote
Old 11-11-2010, 04:12 PM   #5
the last dj
Casper, Wyoming
Vehicle Specs
Quoted: 0 Post(s)
03 heater blend door actuator
Working on an 03 Explorer, have replaced the blend door with the "heatertreater" solution. Did not fix the heater problem, moved forward with replacing the actuator. However, when plugged in to the harness, there is no movement of the actuator. Fuses are good, no other problems appear to exist. Help, please.
the last dj is offline   Reply With Quote
Old 11-11-2010, 04:23 PM   #6
BigRondo
USMC 1371
Worcester, MA
BigRondo's Avatar
2002 XLT V6 4x4
Vehicle Specs
Quoted: 94 Post(s)
Quote:
Did you follow the test procedure for checking out the new actuator as outlined in this thread?
__________________
Old 10-29-2013, 12:58 PM   #7
brian jackson
Edmonton, Alberta
2003 explorer xlt
Vehicle Specs
Quoted: 1 Post(s)
CAN
Just wanted to mention your tutorial was a great deal of help to me Rondo. First took it to my local dealer and they quoted me 9.5 hrs labour @ 165.00 per hour + diagnostics and parts. Fast forward to late 2013 the part cost me 122.00. Your tutorial saved me any further costs on top of that. Not a mechanic at all but I do have a healthy respect for my tools. Took me 3 1/2 hrs with trips back and forth to my laptop, but i'm back up and running again thanks to your efforts here. The 7 months of winter will be a little warmer for me and my family now and I have you to thank for that.
Thank you from a greatful Canadian for this site and your help Rhondo.......Brian
brian jackson is offline   Reply With Quote
Old 10-29-2013, 07:02 PM   #8
BigRondo
USMC 1371
Worcester, MA
BigRondo's Avatar
2002 XLT V6 4x4
Vehicle Specs
Quoted: 94 Post(s)
Glad I could help out!!
__________________
Old 08-11-2014, 09:31 PM   #9
rmclayton
Flint MI
03 ford explorer xlt
Vehicle Specs
Quoted: 0 Post(s)
I just bought a 03 ford explorer it has a clicking sound like the turn signal is - but it's not- then I noticed the drivers side carpet is really wet, I later turned the heat on and I don't have any heat at all. I have only had this for a week. Are these the symptom of the actuator...is that the same thing as the heater core?
rmclayton is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
