#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Explorer & Ranger Transmissions, Transfer Cases, & Differentials
Notices
Explorer & Ranger Transmissions, Transfer Cases, & Differentials Transmissions, Transfer Cases. A4LD, 4R70W, 4R44E, 4R55E, 5R44E, 5R55E, M5OD, BW 1354, Control Trac, GEM, AWD. Ford 8.8", Dana 35
C-clip eliminators for disc brake 8.8?
Reply
Thread Tools
Old 10-13-2008, 07:02 PM   #1
tennerv8
Duluth mn.
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I have a 31 spline 8.8 in my v8'd s10. This rearend has disc brakes. Can I get c-clip eliminators for a disc brake 8.8? All the ones im seeing are for drum brake 8.8's. Any help would be great guys. Thanks.
tennerv8 is offline   Reply With Quote
( Join the Elite Explorers )
Old 10-13-2008, 09:11 PM   #2
mjones97
Salem, IN
Vehicle Specs
Quoted: 0 Post(s)
There is no need for c-clips eliminators in the disc brake 8.8's. The caliper will hold it on if the c-clip breaks and the axle tries to come out.
__________________
~1986 Bronco II Eddie Bauer~
Modified Beyond Control
Support our Troops!
mjones97 is offline   Reply With Quote
Old 10-14-2008, 10:19 AM   #3
Cobraguy
Phoenix...Greatest City on Earth
Cobraguy's Avatar
1995 EB & 1999 EB 5.0
Vehicle Specs
Quoted: 13 Post(s)
Quote:
Except that some sanctioning racing organizations require a C clip eliminator and won't allow the rear rotor deal to pass.
Have you tried Mark Williams?
__________________
http://banners.wunderground.com/weat...AZ/Phoenix.gif
Quote:
Originally Posted by four0sport
she is a girl, there are no answers, only more questions!
Cobraguy is offline   Reply With Quote
Old 10-14-2008, 10:21 AM   #4
Rick
Admin
Pumpkin Pilot
Wayoutin, Aridzona
Rick's Avatar
'93 XL Pumpkin Edition
Vehicle Specs
Quoted: 396 Post(s)
I'm not sure what your intended use is, but C-clip eliminators are not recommended for offroad use due to the side loads placed on the axle. I got the same response from both Strange Engineering and Mark Williams.
__________________
Rick Horwitz, AB7FH "Serious Exploration's" Admin
Rick's '93/'98 Explorer "The Great Pumpkin"
Dodge Dart 512 Resto/Race 10.29 @ 129
2004 Mustang Mach 1
1960 Dodge Dart Seneca
Rick is online now   Reply With Quote
Old 10-14-2008, 10:55 AM   #5
tennerv8
Duluth mn.
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
This is a 2wd street truck. It has a healthy sbc in it at around 450hp. But will be seeing close to 600hp in the future. I was wondering if an NHRA track would allow this. Do I need c-clip eliminators to take it to a track.
Old 10-14-2008, 11:00 AM   #6
CDW6212R
Knoxville, TN
CDW6212R's Avatar
98 Mountaineer AWD
Vehicle Specs
Quoted: 186 Post(s)
Just a thought, the c-clip eliminators go one the outer axle, is there any reason that you can't still use the c-clip axles? I'd want to use them both if the track needed it.
__________________
Don
91 Lincoln LSC/SE/GTC, 99/93 Explorer Limited 4WD, 98 AWD Mounty with 255/55/18's, big sway bars, and 12.75" x 1.25" rotors. Soon a BW4406, built trans, stereo and interior.
The best thing that could help us all, is the Fair Tax Plan.
Be American, Buy American (Manufacturer)
CDW6212R is offline   Reply With Quote
Old 10-14-2008, 11:02 AM   #7
Rick
Admin
Pumpkin Pilot
Wayoutin, Aridzona
Rick's Avatar
Vehicle Specs
Quoted: 396 Post(s)
I've got an NHRA rule book here. I'll look into it.
__________________
2004 Mustang Mach 1
Old 10-14-2008, 11:06 AM   #8
Maniak
Moderator-Stock 91-94
Vail, Arizona
Maniak's Avatar
1992 XLT 4x4
Vehicle Specs
Quoted: 205 Post(s)
Didn't warn make a full floater kit (which gets rid of the c-clip) a while ago? I think it was them but I guess it didn't sell since they stopped making them pretty quick.
~Mark
__________________
Click HERE to see our Explorer Specs
Maniak is offline   Reply With Quote
Old 10-14-2008, 11:10 AM   #9
Cobraguy
Cobraguy's Avatar
Vehicle Specs
Quoted: 13 Post(s)
tenner...IIRC, you need C-clip eliminators any time you bolt up a slick or a certain size tire...but don't quote me on that. It's been a while. With 600 hp, you will need slicks. I had an old Comp Elim car lose an axle near the big end once. It wasn't pretty. Get the eliminator kits if at all possible.
__________________
Old 10-14-2008, 11:12 AM   #10
CDW6212R
Knoxville, TN
CDW6212R's Avatar
98 Mountaineer AWD
Vehicle Specs
Quoted: 186 Post(s)
Buy better axles also, they are available OTS from a few places.
__________________
Don
Old 10-14-2008, 11:14 AM   #11
Rick
Admin
Pumpkin Pilot
Wayoutin, Aridzona
Rick's Avatar
Vehicle Specs
Quoted: 396 Post(s)
Under NHRA general regulations 2:2
Axle Retention Devices
All cars except Stock and some ET cars as noted in Class Requirement must be equipped with a satisfactory means of rear axle retention minimum .120 inch aluminum or .09 inch steel bearing retainer mandatory. Stock C clip axle retention prohibited as outlined in Class Requirements.
Section 5A ET
Aftermarket axles and retention devices mandatory on any car running 10.99 (6.99 in 1/8) or quicker with locked differential.
__________________
2004 Mustang Mach 1
Old 10-14-2008, 11:15 AM   #12
Rick
Admin
Pumpkin Pilot
Wayoutin, Aridzona
Rick's Avatar
Vehicle Specs
Quoted: 396 Post(s)
Quote:
~Mark
Warn went through a business restructuring right after that product was introduced and eliminated the product from their offerings.
__________________
2004 Mustang Mach 1
Old 10-14-2008, 11:16 AM   #13
Cobraguy
Cobraguy's Avatar
Vehicle Specs
Quoted: 13 Post(s)
Ahh! That rings the bell! Thanks Rick.
__________________
Old 10-14-2008, 11:24 AM   #14
tennerv8
Duluth mn.
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
LOL! this all translates to $$$ to me. Great info guys. I guess I might have to swap to drum brakes to even get an eliminator kit to work huh? I like my discs
Old 10-14-2008, 11:35 AM   #15
Rick
Admin
Pumpkin Pilot
Wayoutin, Aridzona
Rick's Avatar
Vehicle Specs
Quoted: 396 Post(s)
I believe the C-clip eliminator will work with your discs. Give Strange or MW a call and see what they say.
__________________
2004 Mustang Mach 1
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
