| Stock 1991 - 1994 Explorers For questions related to the base Ford Explorer. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. No modification questions. |
Thread Tools |
#1 |
Wannabe Elite Explorer
greenville, south carolina
1991 explorer 4x4
is my 91 an interference engine?
is the 4.0 in my explorer an interference engine?
#2 |
Flowery Branch , Georgia, 1994 sport 2wd auto
2005 colorado 2wd 5spd
interference ?
__________________ Scott . |
#3 |
Groton, CT
1999 XLT
When the timing belt or chain breaks, the pistons hit the valves.
I don't know about the Ford 4.0. __________________ 1999 XLT, 5.0, A4, AWD 1986 Chevy Z28 Camaro, 5.7, T-5 2003 Chevy Suburban LT 1500, 5.3, A4, 4WD |
#4 |
Long Island, NY
1994 GMC Yukon 2 Door
I believe the 4.0 OHV (which is what's in your '91) is a non-interference engine.
__________________ -James 1992 Ford Explorer XLT 4x4 - Sold 1994 GMC Yukon 2 Door 350 TBI |
#5 |
1991 explorer 4x4
i've tried to google it but was unlucky. anywhere i can find out for sure?
#6 |
Moderator-Stock 91-94
Vail, Arizona
1992 XLT 4x4
The 1991-1994 are non interference (use 90tm or 93tm head castings). I can't comment 100% for sure on the newer ones (diff piston/head configuration)..
~Mark |
#7 |
1991 explorer 4x4
awesome. i think i will postpone my plans to change the timing set then.
#8 |
'91 xlt, 93
usually the timing chain is good for the life of the motor, under normal circumstances theres no reason to mess with it.
#9 |
Triangle Beach Explorer
Richmond, BC
1994 Explorer XLT
it will stretch over the life of the motor, but I believe the ECU will compensate for that.
i don't think its an interference engine, actually i don't think many V shaped engines are interference. I think its just a problem on straight 4's. |
#10 |
balt, md
91 xlt, 92 xlt, 95 xlt
Gates has a great Timing Belt Replacement Guide on their website that you can download. It tells you what engines have belts, if they are interference or not, and the recommended replacement interval. Go to www.gates.com and click on the Timing Belts link.
__________________ '88 F150 4x4 '91 Explorer XLT 4x4 '92 Explorer XLT 4x4 '95 Explorer XLT 4x4 If it don't = 16 (4x4), it ain't worth driving... |
#11 |
1991 explorer 4x4
but my engine doesn't have a timing belt. also they may not break but the explorer has nylon tensioners that i'm sure wear out. i've had v8's that were interference and when the chain broke i had to replace valves. i just had the heads off to put on new head gaskets and do not want to take them off again that's why i was thinking of replacing the chain, in case it breaks. if it's not interference i'll still replace it just not as soon as i was thinking.
#12 |
'91 xlt, 93
honestly I wouldnt even touch the timing chain unless your doing a full blown rebuild, do a quick search on ohv timing chains. You wont find many issues, the much more common fix for internals is replacing the worn pushrods.
#13 |
Vail, Arizona
1992 XLT 4x4
I'd have to agree.. In the past 10+ years being on EF (wow, its been a long time) I can't remember seeing anyone that needed to change the timing set on an OHV.
I replaced/rebuilt our motor at 355k miles.. nothing in the timing chain area looked overly worn. I didn't replace the timing chain set becuase I rebuilt my spare motor which had 150k or so miles (in that range).. I didn't change the timing set on that one either as it showed very little wear. ~Mark ~Mark |
#14 |
Northeastern, NC
96 ex
was wondering if a 96 explorer 4.0 was a interference engine or not can`t seem to find it in searches. my vin letter is x.
__________________ 96 XLT Rollin on 33x12.5 Mastercraft MT, TT, Shackles, 3" PA 883, and still scrapin soon to have superlift suspension kit and lockers 80 Jeep CJ5 on 44`s and chevy 1 tons Break It, Fix It, And DO It Again!!!!!!!!!! |
#15 |
moderation
Texarkana AR/TX
94 SAS sport
No, it is not an interferance engine. 4.0 OHV timing chain virtually lasts forever (life of engine) and if it were to break (almost unpossible) it would do no harm.
FYI it would be so stretched out it would barely run long before it broke. |
#16 |
Northeastern, NC
96 ex
thanks alot.
| Thread Tools | |
