Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Explorer & Ranger Transmissions, Transfer Cases, & Differentials
Notices
Explorer & Ranger Transmissions, Transfer Cases, & Differentials Transmissions, Transfer Cases. A4LD, 4R70W, 4R44E, 4R55E, 5R44E, 5R55E, M5OD, BW 1354, Control Trac, GEM, AWD. Ford 8.8", Dana 35
Why are there four o-rings?
Reply
Thread Tools
Old 10-23-2008, 12:04 AM   #1
zzb3886
Seattle, WA
00 XLT SOHC
Vehicle Specs
(Original Poster)
I'm going to do a pan drop and filter change for my 5R55E. The new filter kit contains four o-rings. But there are only two places on the filter to hold o-rings (see figure). Where should the extra two o-rings go? Just don't want to get confused when it's a mess under the truck. Thanks!
zzb3886 is offline   Reply With Quote
Old 10-23-2008, 12:10 AM   #2
BrooklynBay
Aerostar Forum Moderator
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
The picture didn't come out. There are usually only 2 O rings provided with the filter.
BrooklynBay is offline   Reply With Quote
Old 10-23-2008, 09:35 AM   #3
XploreAlaska
Wasilla, Alaska / USMC camp pendleton, CA
1994 Limited
Vehicle Specs
too tight of a fit with the 2 big o-rings? then try the 2 smaller ones! its just an option in case one set is too loose/tight.
XploreAlaska is offline   Reply With Quote
Reply
Tags
o-rings, transmission filter
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
