| Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. |
Thread Tools |
#1 |
Wannabe Elite Explorer
missouri
00E.B.,93 xlt 92 xlt
correct parts #'s 4.0sohc guides & tensioners with pics...
okay I did not have the left/right cam problems mine was the main chain and balance shaft trouble was finding the parts numbers I searched on here the internet and the Ford dealers... finally found One out of 5 Ford dealers that knew what I need so here we go
__________________ 00 E.B. 4x4 sohc RIP 97 xlt control trac 94 explorer sport 93 xlt explorer 4x4 92 xlt explorer (parts truck) 92 xlt explorer project Last edited by project92; 10-27-2008 at 10:30 AM. |
#2 |
missouri
part 2
__________________ 00 E.B. 4x4 sohc RIP 97 xlt control trac 94 explorer sport 93 xlt explorer 4x4 92 xlt explorer (parts truck) 92 xlt explorer project |
#3 |
missouri
okay you see most has there part numbers but her is a rundown...
F77Z6K297BC. BS GUIDE $11.77 2L2Z6K297AA.MAIN CHAIN GUIDE $10.85 1L2Z6L266AA. BS TENSIONER.$19.30 YL2Z6L266AA. MAIN CHAIN TENSIONER. $42.78 F77Z6020AB. TIMING CHAIN COVER $ 10.83 Other parts of interest... YL2Z9461AA. TOP HALF OF INTAKE $1.85 EACH (6) YL2Z9E436AA. BOTTOM GASKET OF INTAKE $4.53 EA. (2) and don't forget the tool kit 6488 also you may need a oil pan gaskets I'll get them number later most part are cheeper at ford becuase the local auto parts don't sell just the guides or tensioners they have to sell them in sets which includes chains and run over $100 buck a piece... you can get a whole 4 chain kit for $577 from carquest ![]() okay the internet is good and bad... don't get the TC gaske from ford it's 10 bucks, you can got to oreilly's and get the TC kit and get all the gaskets you need (SEE PICS BELOW).. also the kit for the upper is cheeper at oriell's also it's just there web page doesn't show the correct set so I spent a extra 10 bucks at the Ford dealer because of this.. the kit is 14-16 at most auto parts stores (pics below.. __________________ 00 E.B. 4x4 sohc RIP 97 xlt control trac 94 explorer sport 93 xlt explorer 4x4 92 xlt explorer (parts truck) 92 xlt explorer project Last edited by project92; 10-27-2008 at 10:17 AM. Reason: adding/ deleting info... |
#4 |
missouri
pics of parts
#5 |
missouri
last set for a while
#6 |
Knoxville, TN
98 Mountaineer A4WD
The rear tensioner often forgotten is 7U3Z-6K254-A. That's the easiest part to change. I'll try to post the front cam chain tensioner kit later, the 00M12 kit that has the upper gaskets and check valve in it together with the kit. Good thread, a parts number list.
__________________ Don 91 Lincoln LSC/SE, 99/93 Explorer Limited 4WD, 98 AWD Mounty with 255/55/18's, big sway bars, and 12.75" x 1.25" rotors. Soon a BW4406, built trans, stereo and interior. The best thing that could help us all, is the Fair Tax Plan. Be American, Buy American (Manufacturer)
#7 |
Melbourne, VIC
98' eXplorer XLT
Thanks mate.
It's the most straight forward parts list I've found so far... Now to find a way of getting it shipped over here ??? The cost through the dealers here is over $5000+ So I'll be doing it myself over the holidays... |
#8 |
Melbourne, VIC
98' eXplorer XLT
One Q is the tool kit 6488
Is they the tools for the timing and balancer ??? A bit shady and confused with all the info I've been reading... Thanks in advance
#9 |
Knoxville, TN
98 Mountaineer A4WD
FYI, one more part and Ford number, the rear block cover(plug) is F77Z 6026 AB.
#10 |
Does the intake have to come off the complete this job? I've seen a few write-ups and some indicate removal and some have no mention of it. I'd like to be able to remove just the alternator bracket, fan/waterpump/timing cover, move the PS, and radiator.
![]() I'm not too worried about anything moving because I'm only planning on replacing the plastic parts and the other day I completed the 00m12 kit installation. Last edited by nobodyfresh; 12-08-2008 at 09:05 PM. |
#11 |
Knoxville, TN
98 Mountaineer A4WD
Yes the upper intake needs to come off to do the work, even the front stuff. You don't have to remove the radiator, just be very careful around it. get the right tool to pull the balancer, that's tricky with so little space, and the odd tool bolt sizes.
#12 |
Chicago, IL
2000 XLT
Pics?
The pics aren't showing. Were these originally posted on a photohosting site and the links are now bad?
Would be great if they worked. Otherwise, good thread. Thanks, Bill |
#13 |
Germantown, MD
Pics work for me.
I even singed off and pics still show so its not an Elite vs non-Elite thing. And they're not hosted on a photo hosting site, they are attached directly attached to the reply and are hosted on this forum. __________________ »»»»»...how'd the moon get there, how'd the moon get there? |
#14 |
Knoxville, TN
98 Mountaineer A4WD
Ditto, there are lots of pictures of good new Ford parts.
#15 |
Chicago, IL
2000 XLT
That's odd. All I get are the boxes with the red X.
Most, but not all, of the other threads seem to work. Bill |
#16 |
Bushwacker, AL
2002 SportTrac
Greetings guys, my Sport Trac has been doing the death rattle and I have been doing some research. I am going to replace the two tensioner, but I keep hearing people say the check valve. Is the Check Valve a different part or is it inside the tensioner?
Thanks in advance.
#17 |
Waterloo Ontario
2000 XLT 4.0 SOHC 4X4
The check valve is part of the tensioner for the left side chain. It comes in the kit YL2Z-9E473-AA which costs around $50. This was the kit used in the 00M12 owner notification program from years ago. It was used to correct the start up rattle on a cold engine when the tensioner got weak.
If you have an on-going rattle it is likely the primary timing chain that goes from the crank to the Jackshaft, although it could mean that your left tensioner is totally done and the cam chain is loose. Last edited by bluestream1; 07-23-2009 at 08:20 PM. |
#18 |
Knoxville, TN
98 Mountaineer A4WD
There you go Leo, try that YL2Z-9E473-AA for the small kit that doesn't require timing tools.
It's $44 from Tasca, but confirm that with a local Ford parts department as to content. I haven't checked on that part number, let's hope it's the one I mentioned for the left cam chain. http://www.tascafordparts.com __________________ Don 91 Lincoln LSC/SE, 99/93 Explorer Limited 4WD, 98 AWD Mounty with 255/55/18's, big sway bars, and 12.75" x 1.25" rotors. Soon a BW4406, built trans, stereo and interior. The best thing that could help us all, is the Fair Tax Plan. Be American, Buy American (Manufacturer)
#19 |
virginia
99 xlt
timing chains
good morning about the timing chains--does the engine have to be removed in order to to the job on 99 explorers 2 whl drives
#20 | |
virginia
99 xlt
timing chain replacement
Quote:
| Thread Tools | |
