Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
95 4.0 Rear Engine Seal
Reply
Thread Tools
Old 10-27-2008, 06:52 AM   #1
marragtop
balt, md
91, 92, 95, and 2000 xlts
Vehicle Specs
Quoted: 4 Post(s)
(Original Poster)
I have an oil leak that accumulates where the trans bolts to the engine. THis weekend I degreased everything, started it up, and got underneath it to watch the leak. The leak is definitely coming from where the trans mates with the engine. I'm assuming this is the rear engine seal that is leaking. Do you all agree? Also, how hard is it to replace? It's the 4.0, 4x4, AT, with 186k on it.
__________________
'88 F150 4x4
'91 Explorer XLT 4x4
'92 Explorer XLT 4x4
'95 Explorer XLT 4x4
If it don't = 16 (4x4), it ain't worth driving...
marragtop is offline   Reply With Quote
( Join the Elite Explorers )
Old 10-27-2008, 08:24 AM   #2
Heavymentill
Ann Arbor, Michigan
Heavymentill's Avatar
96 Explorer Limited
Vehicle Specs
Quoted: 0 Post(s)
If you are sure its oil and not trans fluid. Then its the rear main seal. This requires removing the trans. Make sure your PCV system is operation correctly, as a build up of pressure in the block will cause the main seal to leak.
__________________
Heavymentill is offline   Reply With Quote
Old 10-27-2008, 08:49 AM   #3
marragtop
balt, md
Vehicle Specs
Quoted: 4 Post(s)
(Original Poster)
Thanks for the reply. I was reading my Chiltons and it says to remove the transmission and the transfer case also has to be removed. Does this sound right? I've pulled transmissions before, but not from 4wd vehicles (yet!).
Also, where is the PCV valve located on a 95 4.0? if the PCV has it's normal rattle, can I assume that that's OK?
__________________
'88 F150 4x4
Old 10-27-2008, 09:05 AM   #4
Heavymentill
Ann Arbor, Michigan
96 Explorer Limited
Vehicle Specs
Quoted: 0 Post(s)
It is not necessary to remove the transfer case. It just makes it easier to handle by removing it. I personally wouldn't recommend removing it, it just makes for extra work. As for the PCV, this is a very inexpensive part. I recommend replacing it for insurance purposes, seeing your going through all the trouble of doing the main seal.
__________________
Old 10-27-2008, 09:08 AM   #5
marragtop
balt, md
Vehicle Specs
Quoted: 4 Post(s)
(Original Poster)
I'm hoping that the PCV is clogged and maybe replacing it will reduce the pressure on the seal, so I won't have to replace the seal. I know it's a long shot, but I've got nothing to lose.
__________________
'88 F150 4x4
Old 10-27-2008, 09:13 AM   #6
Heavymentill
Ann Arbor, Michigan
96 Explorer Limited
Vehicle Specs
Quoted: 0 Post(s)
I wouldn't count on that helping much at all. One good thing is you have an automatic trans, so its not like you are putting a clutch at risk.
__________________
Old 10-27-2008, 09:18 AM   #7
marragtop
balt, md
Vehicle Specs
Quoted: 4 Post(s)
(Original Poster)
Has anyone had any good/bad experiences with any of the oil additives such as Barrs or Wynns engine stop leak? Generally, I refrain from using these types of products because I think there is a long term risk of additional damage. But with 186k on this Explorer, I'm not sure I want to go through the effort of putting the seal in. I think it's time I search for yet another Explorer.
__________________
'88 F150 4x4
Old 10-27-2008, 09:23 AM   #8
Heavymentill
Ann Arbor, Michigan
96 Explorer Limited
Vehicle Specs
Quoted: 0 Post(s)
Band-Aid at best. If your lucky it may help for a while but its just delaying the inevitable.
Good luck.
__________________
Old 10-27-2008, 09:58 AM   #9
Cobraguy
Phoenix...Greatest City on Earth
Cobraguy's Avatar
1995 EB & 1999 EB 5.0
Vehicle Specs
Quoted: 13 Post(s)
Quote:
Ok. You have my attention. How are you going to remove the trans without removing the transfer case? Or are you suggesting he actually does remove it, but leaves it attached to the trans?
A rattling PCV valve should mean it's fine. But what's more likely to be an issue is the vacuum lines to it. Make sure they are good.
I would try and see if I could find the special tool for installing the rear main seal. The installed depth is critical...and having it absolutely square in the bore is critical. The tool ensures that. Many do it without it, but it's good piece of mind if you have it.
__________________
http://banners.wunderground.com/weat...AZ/Phoenix.gif
Quote:
Originally Posted by four0sport
she is a girl, there are no answers, only more questions!
Cobraguy is offline   Reply With Quote
Old 10-27-2008, 10:05 AM   #10
Heavymentill
Ann Arbor, Michigan
96 Explorer Limited
Vehicle Specs
Quoted: 0 Post(s)
Leave it attached. Special tool? Do you mean a seal driver? The old gasket and a mallet work fine. Just drive it in till its fully seated. It's not science.
__________________
Old 10-27-2008, 10:08 AM   #11
marragtop
balt, md
Vehicle Specs
Quoted: 4 Post(s)
(Original Poster)
Is a normal trans jack going to be able to handle the trans with the transfer case attached? btw... this will be an on my back job..... no lift.
__________________
'88 F150 4x4
Old 10-27-2008, 10:22 AM   #12
Heavymentill
Ann Arbor, Michigan
96 Explorer Limited
Vehicle Specs
Quoted: 0 Post(s)
I've done it 3 times without a lift and once with. I have a cheap JC Whitney trans jack, and a regular jack to help when aligning it to re-install the trans. Without a lift, I've done it twice with no help at all. If you can, get someone to help when trying to align the torque converter bolts to the flex plate. Also inspect your flex plate for cracks as there is an updated version. If it looks like its got a circular plate welded on the mounting area where the bolts go through its the old version the new one looks like its all one piece.
__________________
Old 10-27-2008, 11:01 AM   #13
Cobraguy
Cobraguy's Avatar
Vehicle Specs
Quoted: 13 Post(s)
That is not the procedure Ford calls for. They give a spec from flush and a tool to put it there. To each his own...but I've used the tools with great success.
I was hoping you were going to show us a way to replace the seal by leaving the transfer case intact...
__________________
Old 10-27-2008, 11:35 AM   #14
dogfriend
Human-Animal Hybrid
Carmichael, CA
dogfriend's Avatar
'97 Sport 4x4
Vehicle Specs
Quoted: 5 Post(s)
I thought they were designed to leak. Mine does. Just a little bit, not enough to go through the trouble to mess with it.
dogfriend is offline   Reply With Quote
Old 10-27-2008, 11:51 AM   #15
marragtop
balt, md
Vehicle Specs
Quoted: 4 Post(s)
(Original Poster)
I could probably live with the leak if I could convince my wife to park it on the asphalt street instead of our concrete driveway. Oil and concrete don't mix too well....
__________________
'88 F150 4x4
Old 10-27-2008, 11:14 PM   #16
Heavymentill
Ann Arbor, Michigan
96 Explorer Limited
Vehicle Specs
Quoted: 0 Post(s)
Procedures are for people who get paid by the hour.
__________________
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
