| Need for Speed! Explorer, Ranger, Mountaineer 4.0 - 4.6 - 5.0 Nitrous, Superchargers, Camshafts, Head Work, Stroker Kits... DRAG RACING. Explorers, Mountaineers and Rangers CAN move! |
Thread Tools |
#161 |
Knoxville, TN
98 Mountaineer A4WD
Very good, great to hear of the project. Doing it yourself you know how things will work, and fit etc. When you get to it if you need it, I'm sure there is an alternator similar enough to what you have that can be fitted. The new stuff is amazing, I grew up with 55 amp Ford alternators modified with 80 amp windings. Now the same size small aftermarket units can make over 100 amps at idle, and OEM parts are not far off from that. Regards,
__________________ Don 91 Lincoln LSC/SE, 99/93 Explorer Limited 4WD, 98 AWD Mounty with 255/55/18's, big sway bars, and 12.75" x 1.25" rotors. Soon a BW4406, built trans, stereo and interior. The best thing that could help us all, is the Fair Tax Plan. Be American, Buy American (Manufacturer)
#162 |
BAM!!! Just like that
Mt. Baldy, Ca
94 xlt 2x4
Ok this is an old thread but I am planning to do the markviii fan on my 96 v8. Is their any way to soften the on amp spike with some sort of capacitor or something? On the 2 speed fans is the inital amp spike the same for high and low or does the low speed have a lesser amp spike? If it is the case if you start the fan on the lower speed then using a 2 relay setup when it switches from low to high it will already be moving so it should in theory not spike much higher?
Nate __________________ ***TORQUE is when you push down on your erection and your feet fly out from under you!*** |
#163 | |
Wannabe Elite Explorer
Phoenix...Greatest City on Earth
1995 EB & 1999 EB 5.0
Have you considered trying to control it with a PWM controller? Painless is the only one I know that has something heavy duty enough to control that big a fan.
__________________ http://banners.wunderground.com/weat...AZ/Phoenix.gif Quote:
#164 | |
Mt. Baldy, Ca
94 xlt 2x4
Quote:
Thanks, Nathan __________________ ***TORQUE is when you push down on your erection and your feet fly out from under you!*** |
#165 |
Salisbury, South Australia
1997 Explorer XLS 4WD
Okay so I am going to mount a Mark VIII Fan in the original Radiator shroud. This is going to be just a bit too tall for the water pump snout. so I am going to remove the snout on the water pump and then, fingers crossed, I should have the clearance. The controller is a Painless unit, If the fan shroud and water pump fit, this is the next step.
#166 | |
Quote:
#167 | |
I think we would all like some pictures of that install!
#168 |
2003 Explorer Sport
I use a Ford Contour duel fan set up in my Street driven 331 Vorech Blown mustang. In the middle of July with the A/C blowing, stuck in NJ traffic, I have never seen temps higher than 190 degrees. Its a 2 speed fan thats thermostatically controlled via a tap into the thermostat housing.
I would highly sugguest this fan due to how thin it sits, and how much air it moves. I dont know CFM, but it "felt" like more air than a Be Kool duel fan and more than a Black Magic Ultra __________________ 2003 Sport XLT Banshee Supercharger kit with 7.5 psi, 30 Lb injectors, 255 LPH fuel pump. 22" Rims, HID head and fogs, retarded sound system, EBC bakes |
#169 |
Oregon,OH
1996 XLT - 347 V8
Yep, I also use the contour fans and have never had a problem.
__________________ 1996 Explorer XLT Supercharged 347 w/ BW4406 Build Thread, 8000K HID Headlights and Fog Lights, Custom electric fans with painless controller, Stainless running boards, etc... 1999 Ranger XLT manual 2WD 3.0L (DD). Window visors, 35% front tint & 20% stock rear tint, 6000K HIDs, 96 explorer rims.. mostly stock 1997 Mountaineer (Swapped 4x4 4.0 OHV from my 96 Explorer) (Sold) |
#170 |
Elite Mountaineer
South Jersey
99 Mountaineer V6 4x4
X2! I've been using them for 2 yrs now, no problems at all. Never been above 205* in any situation. __________________ Al ![]() 99 Mountaineer 4.0 SOHC. TT/Warrior Shackles, 2" BL, 32x11.5/15 BFG A/T's, Rancho 5000's, Supplemental HHO Generator(out for cell redesign), Electric Fan Conversion, AVM Manual Lockout Hubs, Dual Battery System, Gibson cat back exhaust. EATC Mod. BW1354 swap, finally done! My 4405 To 1354 Swap Thread Support your own economy, Buy American, all of our jobs depend on it.
#171 |
Firstly I must give credit to Aldive (RIP) for the inspiration to try these mods,Thankyou Wise Man.
Okay these are pics of the fan install and the Painless performance Fan control unit ![]() ![]() ![]() ![]() ![]() ![]() As a bonus, I did see Aldives install of a Mustang 4.6 Lt aftermarket throttle body, however, the problem was the cruise control attachment point is in a different location, so I grabbed another Standard Throttle body from an Explorer and carefully used an engraver tool to grind away the pressed on Accelerator cable Pie section, I modified the aftermarket spring to suit and cruise control works perfect. ![]()
#172 |
Oregon,OH
1996 XLT - 347 V8
wow. talk about a close fit!! Looks good though, good job!
#173 |
B
#174 |
va beach
92 SC
i ended up getting ride of my HHr do to it not keeping up and got a 3.8 supercharged thunderbird fan.this is very similar to the 2 speed Taurus fans but there is one less blade,the blades are thicker,larger blade circumference and a smaller shroud.its also said to pull more cfms than the taurus and just under the mrk8, (4300 cfms).this fan fits like a glove on my rad,it is larger in thickness,about 5" but can be trimmed down to under 4".i run a manual rad so i dont think ill even trim it.here are some pics and ill add one when i go to install it
__________________ 92 xl 5.5"duff arms,3"BL,PJ 36x14.50,wrapped headers,side dump exhaust,.20 over,HF oil pump,422cam,45cc 95tm p+p 10.67:1 heads,p+p lower manifold,75mm TB,90mm maf,36lbs injectors,P+P GM M90 Supercharged & intercooled!!SCT tuned!!electric fan,4.88s aussie locked front & back!!next NOS&W/M
http://www.explorerforum.com/forums/...=double+vision |
#175 | |
kah-lee-fur-nyah
1997
Quote:
__________________ 302 V8, BW4406, K&N CAI, 1" Phenolic spacer, TMH, Henson Custom Tune and a ticking noise problem. |
#176 |
kah-lee-fur-nyah
1997
What other fan can we use for our 5.0 v8's?
I've been to the junkyard several times but can never tell what fan would be good enough to cool down a 302 efficiently. With the controller issue, if people do pull efan's from the junkyard then why not pull/take the oem fan controller too? is it because it would be worthless in our application? __________________ 302 V8, BW4406, K&N CAI, 1" Phenolic spacer, TMH, Henson Custom Tune and a ticking noise problem. |
#177 | |
Elite Mountaineer
South Jersey
Quote:
![]() ![]() ![]() ![]() I'm still using the DC controller. 2 years and still going strong. I did move the mounting location of the controller from behind the grill to mounting it on the ABS assembly. Much drier and more access-able location. __________________ Al ![]() 99 Mountaineer 4.0 SOHC. TT/Warrior Shackles, 2" BL, 32x11.5/15 BFG A/T's, Rancho 5000's, Supplemental HHO Generator(out for cell redesign), Electric Fan Conversion, AVM Manual Lockout Hubs, Dual Battery System, Gibson cat back exhaust. EATC Mod. BW1354 swap, finally done! My 4405 To 1354 Swap Thread Support your own economy, Buy American, all of our jobs depend on it.
#178 |
kah-lee-fur-nyah
1997
thanks for the pics albi1cnobi1.
found some info here http://forums.corvetteforum.com/c3-t...pal-duals.html about markviii fans and their true CFM rating. ![]() could it be that people are just over-hyping the mark viii's CFM and amp draw? __________________ 302 V8, BW4406, K&N CAI, 1" Phenolic spacer, TMH, Henson Custom Tune and a ticking noise problem. |
#179 | |
va beach
92 SC
#180 | |||
Moderator-Stock 91-94
Vail, Arizona
1992 XLT 4x4
Here ya go..
I know I say "Taurus" on the Vid.. Its actually a Mark VIII.. I just never re-shot the vid.
Now, when your choosing a breaker (assuming your going with a breaker and not a fuse), keep in mind that they use heat to know when to open. If your in a very hot climate, like we are in southern Az, you will need to oversize your breaker. We tried 80 amp breakers which is well under the max spike of the fan but over time, in the heat of summer the breaker would pop. We are now using 100 amp breakers on 2 different vehicles and neither has had any issues with the breaker popping. We are using 8 gauge wire to handle the extra load that "might" go through the wire if there is a short. The fan in that video was behind a 3 core radiator on a 460 motor. We also did a comparison test of a 1 speed mark vIII fan behind a 2 core (with condensor in front) in an f-150 and the readings were about the same. ~Mark |
| Thread Tools | |
