Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer 3rd Generation > Modified 2002 - 2005 Explorers
Notices
Modified 2002 - 2005 Explorers Questions related to modified 2002 - 2005 Explorers and Mountaineers. For Sport Trac and Sport models use the 1995-2001 forum. Aftermarket accessories and modifications. Bullbar, running boards, floor mats, cargo mat, DVD headrest, wheels, tires, stereo upgrade, headlights, mud flaps, lift kits, engine swap, transmission swap.
custom spacer install gone awry $#^!
Reply
Thread Tools
Old 11-03-2008, 06:46 PM   #1
BajaXplorer
San Marcos, CA
2002 XLT 2WD
Vehicle Specs
(Original Poster)
Ok so I spent a LONG weekend messing with the front coils on my X. I had some custom 3" aluminum spacers made by a machinist friend please no comments about ( "you should have gotten RB's spacers)
Anyways the way these spacers are made is they require the top mount to be rotated 90*.
Anyways that easier said then done. The top mount DOESNT move without taking the WHOLE coilover apart.
Thats where my problems started. Ive taken a bunch of coils in/out but these ones on my 02 were the most PITA to put back together. I just couldnt get them compressesed enought to get back the top nut etc.
So after I get it back together(after a full wasted day)
I go to put the coilover back in the X.
now the second PITA, it doesnt want to fit.??!#%^&* too f###ing long( it would bolt up top but bottom munt wouldnt fit!!
SO as a last straw I take apart the upper ball joint from the spindle and get it all back together.
I still didnt get my spacers on because the top mount wont just turn (if you have seen a X coilover apart, you know there is a plastic spacer/catch up top to keep the coil from spinning) thats where my problem lies, if I could turn the top mount 90*.
anyone have any reccomendations...??? (besides new spacers from RB..yet)
thanks all
Doug
__________________
Doug M.
2002 Ford Explorer 4L, 2WD
I love the smell of race gas in the morning, smells like Baja...
BajaXplorer is offline   Reply With Quote
Old 11-03-2008, 07:36 PM   #2
Thelt
Lenoir, NC
2002 Limited
Vehicle Specs
thanks all
Doug
You are over my head here but can't you just rotate the bottom connector on the strut to compensate for the turn you have to do on the top?
__________________
2002 Explorer Limited, V6, 3.73 limited slip
265/75/16s
Blacked out trim
Thelt is offline   Reply With Quote
Old 11-03-2008, 07:41 PM   #3
BajaXplorer
San Marcos, CA
2002 XLT 2WD
Vehicle Specs
(Original Poster)
wish it was that easy...tried
__________________
Doug M.
Old 11-03-2008, 08:00 PM   #4
Thelt
Lenoir, NC
2002 Limited
Vehicle Specs
wish I could help. I have RB spacers and had to get them installed
__________________
265/75/16s
Blacked out trim
Old 11-03-2008, 11:41 PM   #5
JCUZ
Canberra, Australia
JCUZ's Avatar
2004 XLT 4x4
Vehicle Specs
There is a rubber/plastic insert in the top metal cup. You need to remove that (I use a large screwdriver) and then turn it 90*; just make sure you turn it the right way, or you're going to have to remove it and turn it a further 180* to get it the right way.
__________________
2004 Explorer Limited 7 seater, LPG SVI powered 4.6L V8, 4WD (with BWM 2WD coming), Auto, Lukey mufflers, Roof mount DVD system, HID driving lights (high beam)22s with 265/35/22 Atturo AZ800s
JCUZ is offline   Reply With Quote
Old 11-04-2008, 07:05 AM   #6
jutgin
Chattanooga, TN
2002 ST
Vehicle Specs
thanks all
Doug
I think jcuz already answered about the rotating the mount.
But taking the ball joint apart should not have been a last straw effort. It should have been one of the first things you took apart. It is a tight squeeze for these 3rd gens, we need to take everything possible apart to make room for spacers.
Throw up some pics if you get them installed later!
__________________
2002 Ford Explorer Sport Trac 4x4
Body lift / 33's
jutgin is offline   Reply With Quote
Old 11-04-2008, 11:46 AM   #7
BajaXplorer
San Marcos, CA
2002 XLT 2WD
Vehicle Specs
(Original Poster)
JCUZ, do I still need to completely undo the strut top nut though, that is what im trying to avoid... It appears since the washer above the top bushing has 2 flat edges it will not allow it to rotate..?
just trying to do this the easiest way to save headaches and anothr wasted weekend..
I really am hating the design of the Gen III Explorers.. to car like...
I will not be putting in the spacers until I replace the upper ball joints, so it will probably be after Thanksgiving now..
__________________
Doug M.
Old 11-04-2008, 03:13 PM   #8
JCUZ
Canberra, Australia
JCUZ's Avatar
2004 XLT 4x4
Vehicle Specs
Yep, you need to undo the top bolt unfortunately.
__________________
Old 11-04-2008, 05:09 PM   #9
ktford
Brisbane Australia
2005 XLT & '04 XLT
Vehicle Specs
I hope others can learn from your mistake, kiss.
keep
it
simple
stupid
__________________
Purchased last new V8 X to be brought down under, then got an '04 to park beside it, cause two V8's are better than 1
Missing my 365rwhp turbo Falcon like crazy
ktford is offline   Reply With Quote
Old 11-04-2008, 05:32 PM   #10
BajaXplorer
San Marcos, CA
2002 XLT 2WD
Vehicle Specs
(Original Poster)
actually my spacers are a simple design, I just didnt know that the top mount didnt spin...
__________________
Doug M.
Old 11-05-2008, 10:42 AM   #11
chris's2005
Unregistered
Posts: n/a
Vehicle Specs
Quote:
yeah ive been inspecting the entire front end suspension on my X, cause you proly already read that i have a loud squeek over medium to large bumps.
I took a look the other day at the strut assembly and noticed at the top a rubber cup was folded under the spring and the other half was outside hugging the spring, could this be the squeak problem i got?
Old 11-05-2008, 03:26 PM   #12
JCUZ
Canberra, Australia
JCUZ's Avatar
2004 XLT 4x4
Vehicle Specs
Yes, it may well be. The squeak would be the spring rubbing against the metal cup - metal on metal = squeak.
__________________
Old 11-05-2008, 04:15 PM   #13
chris's2005
Unregistered
Posts: n/a
Vehicle Specs
to fix it, would it require me to remove the strut assembly
Old 11-05-2008, 04:41 PM   #14
helmsa
Southern Oregon
2004 Explorer XLT V6 4x4
Vehicle Specs
Completely. Remove the assembly, disassemble (just like replacing spring), realign everything, reassemble, replace.
__________________
2004 Explorer XLT 4.0L FFV V6 4x4
Pro Comp All Terrains 265/75R16
No Other Mods Yet (POOR AT CURRENT MOMENT!), but I am looking for input at my CarDomain.
helmsa is offline   Reply With Quote
Old 11-05-2008, 11:34 PM   #15
Ford02Exp
Myrtle Beach, SC
'02 XLT
Vehicle Specs
chris, i got that same squeak, if you disassemble everything and put it back together, let me know how that turns out.
__________________
-JB
2002 Ford Explorer XLT
265/75R16 Mudd King Mud Terrains
F-150 Front tow hooks
3" Front and 1.75" Rear Roadbully Spacers
Ford02Exp is offline   Reply With Quote
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
