Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Offroad Tech Forums > Offroad Explorer - Ranger Projects
Notices
Offroad Explorer - Ranger Projects Big projects... Lifts, Swaps, etc... IMPORTANT As the subject use your name, or the name of your truck, and the name of the project. Such as Superlift 5.5" installation, Dana 44 conversion, etc.
jamest's "RE-SAS"
Reply
Thread Tools
Old 11-04-2008, 04:45 PM   #21
IZwack
Germantown, MD
IZwack's Avatar
Vehicle Specs
Quote:
Originally Posted by james t View Post
Lowering the bracket off the axle isnt an option... its still gotta do rocks without hanging up.
Yeah I just noticed that there is a leaf spring preventing you from shooting as close to the tire as possible.
But have you looked at mounting them outboard of the chassis (assuming there is enough room between the tire and the chassis for flex)?
Also, I dunno whether or not the Beilsteins are revalvable but if you mount them at an angle (which I know you said you're not going to do but I just wanted to get this out on the table), you might be able to play with the valve stack to compensate for the added angle (you'd probably end up doing this anyway if the aim is to run fast through the desert). Revalving for the angle will lead to slightly greater heat when you're cycling the thing at high rates (but the shocks wont cycle as far since they are angled) -- but you've got reservoirs (bling) to compensate for the hot hot hot (how you feeling, hot hot hot)
__________________
»»»»»...how'd the moon get there, how'd the moon get there?
IZwack is offline   Reply With Quote
Old 11-04-2008, 05:36 PM   #22
Dannyboy
Other Make & Models Mod
43°48′48″N 91°13′59″W
Dannyboy's Avatar
91 4 do'
Vehicle Specs
might I direct you to Stic-o's fullwidth 44/9" swap that has outer frame rail shocks. also his truck hauls balls in the washes.
Dannyboy is online now   Reply With Quote
Old 11-04-2008, 06:00 PM   #23
james t
moderation
Texarkana AR/TX
james t's Avatar
94 SAS sport
Vehicle Specs
(Original Poster)
Dannie- thank yuou, your a live saver... i owe u a beer... going by tape measure i dont see how that is possible but ill recheck tom.
Truck is done other than shock mounts. State trooper budy of mine came over and drove me around town in it wiht no shocks on it. Front or rear. Throttle + brake + throttle + brake = pimp ass hydro simulation that brings in all the b!tches.
sorry 4 crappy pic Start on the shock mounts tommorrrrow.
james t is online now   Reply With Quote
Old 11-04-2008, 06:03 PM   #24
james t
moderation
Texarkana AR/TX
james t's Avatar
94 SAS sport
Vehicle Specs
(Original Poster)
Neighbors callin we got a block party im done see yall in the mornging!
Old 11-04-2008, 07:28 PM   #25
DB_1
Elite Ranger
La Quinta, Ca.
DB_1's Avatar
97 SC Ranger xlt
Vehicle Specs
Quote:
7100's are revalvable, I was talking to Winter about shocks once and he said that the Bilstein racing shocks (7100's included) are a little difficult to revalve but can be done.
I have a set of 12" 7100's I still need to install in the rear of my truck.
Looking good thus far James
DB_1 is offline   Reply With Quote
Old 11-05-2008, 07:21 AM   #26
james t
moderation
Texarkana AR/TX
james t's Avatar
94 SAS sport
Vehicle Specs
(Original Poster)
About to get started on shockmounts here in a min... just a few notes from yesterday..
1- Ballpit full of luck and falling backwards into it- from the before measurements i took the front was shifted 2" to the drivers side. After lowering it down 4" it now sits dead nuts center. I didnt have to do a darn thing to the trackbar.
2- Caster was 0 degrees from the start. Havent measured yet to see what it is now but IIRC i need to be around 4-6 degrees. Somebody correct me if im wrong. Either way, it will be better now than it was.
3- Wheelbase is now 108". Anyone know what it is for the Sport stock? The front was already a tad forward... now its about 1.5" more than it was.
Old 11-05-2008, 09:26 AM   #27
Dannyboy
Dannyboy's Avatar
91 4 do'
Vehicle Specs
I know steve had issues with making those things fit but eventually he made it work. I can't fathom how you wouldn't stuff a tire into it, but i've always ran stock width axles and scrubbed my inner fender wells.
Also, I didn't know how to state this before, but when you lay your shocks at an angle you definitely can get longer travel from a shorter shock but you also loose a lot of the dampening effect. My truck was really bouncy in the rear even with 4 shocks but I kinda found a solution that got this under control
Old 11-05-2008, 09:27 AM   #28
Turdle
Old and in the way
Humboldt, Kansas
Turdle's Avatar
2000 Mounty
Vehicle Specs
Happy Birthday!!
__________________
Jon
2000 Mountaineer
Turdle-gone
Vitamin D Wagon Sold also
Turdle is online now   Reply With Quote
Old 11-05-2008, 10:42 AM   #29
james t
moderation
Texarkana AR/TX
james t's Avatar
94 SAS sport
Vehicle Specs
(Original Poster)
Thanks JT!
Danny- im about to start on the rear in a minute. I think im going to rig up a temp mount and run the 9" PC's at a 45 degree angle straight towards the rear. This will get it roadworthy and give me some room to build through the floor hoops as time allows... without having it undrivable.
Front shocks are on... set with 5" uptravel/ 9" down. I used the existing upper mounts and built a stud plate and welded it to the lower part of the radius arm. Everything clears lock to lock. Ill bumpstop it later... just eyeballing it im going to have to get pretty radical with some mounts.
Second pic is a little better one of it on the ground.
Old 11-05-2008, 11:01 AM   #30
Stic-o
Elite Movie Star
Tujunga, CA
Stic-o's Avatar
'99 XL 4x4 & '06 XLT 4x2
Vehicle Specs
Quote:
These were my original shocks and wheels I started off with after the SAS. 16" BBCS's and 15x8 with 4 1/2"BS. I now have 14" Fox's with a 17x8 with 4" BS. we have moved the bottom mount around a bit too. I actually bent one of my orginal BBCS running this combo though That's why I went back down to 14" shocks. What I would like to do is go through the fenderwell and make a mount over the frame, that ties into the cage.
you can actually see here with the 35's and BBCS when I rubbed all the paint off the shock!
Here you can see the current setup. I have maxed out on articulation I think I use to get more with factory mounted shocks and 33's. However, you must note, I have no sway bars on the truck at all, and this rides like a caddy on the highway at 65mph, with 37" MTR's
I think the leafs would think my articulation is fine though
__________________
The JP Mobile ~'99 Explorer XL
The Mall Crawler ~'06 Explorer XLT
The Tow Rig ~ '05 F-150 SuperCrew
The Commuter ~ '10 Focus SES
Stic-o is offline   Reply With Quote
Old 11-05-2008, 12:01 PM   #31
Dannyboy
Dannyboy's Avatar
91 4 do'
Vehicle Specs
so steve, are your shocks your limiting strap
Old 11-05-2008, 12:51 PM   #32
Stic-o
Elite Movie Star
Tujunga, CA
Stic-o's Avatar
Vehicle Specs
what is this thing "limiting straps" you speak of?
Yeah have been thinking about putting some on for awhile now
__________________
Old 11-05-2008, 01:28 PM   #33
SVO
Moderator Emeritus/Doctor
Bastrop/Austin, Tx
SVO's Avatar
Turbocharged Navajo LX
Vehicle Specs
Happy Birthday James!
Jeff -
__________________
The problem with America is stupidity. I'm not saying there should be a capital punishment for stupidity, but why don't we just take the safety labels off of everything and let the problem solve itself?
SVO is offline   Reply With Quote
Old 11-05-2008, 01:58 PM   #34
IZwack
Germantown, MD
IZwack's Avatar
Vehicle Specs
Yeah happy birthday Jamezzzzz!!!!
__________________
Old 11-05-2008, 04:21 PM   #35
james t
moderation
Texarkana AR/TX
james t's Avatar
94 SAS sport
Vehicle Specs
(Original Poster)
Its done.
The rear shocks are now at a 50 degree angle straight off the back of the rear end, outside the framerails. No way i could go forward, or "A" across the back of the housing. The upper mounts are actually welded on to the bumper support bar. Ill try to get pics later.
Driving it- holy mother of God good shocks are worth the money. I havent had a chance to get into some rough stuff yet, but the 25mph speedbump test was awesome. Hold speed at 20mph and then punch it right before the bump and the front tires just soak it all up like it was an expansion joint. Now i need some for the rear. Since the rear is moved back on the leaf pins 2", its closer to the center of the spring than factory so i should in theory get more travel out of them.
I also need to do some fender opening reshaping... hopefully ill work on this in the next few weeks.
Old 11-05-2008, 07:39 PM   #36
section525
sextion525
Red Bluff, Ca
section525's Avatar
1975 Ford Bronco 4x4
Vehicle Specs
Looking forward to the pics! Happy b-day too! I'm sending you a <3 package on Saturday.
__________________
Support the Forum
'13 3.5 Explorer
'08 2.0 Focus
'75 5.0 Bronco
'04 6.0 Super Duty
section525 is offline   Reply With Quote
Old 11-06-2008, 04:02 PM   #37
james t
moderation
Texarkana AR/TX
james t's Avatar
94 SAS sport
Vehicle Specs
(Original Poster)
First pic is the lower rear shockmount. Shock angle is 50 degrees straight back. Going by the tape i could run an 11-12" shock back there, raise the upper mount and get close to 60 degrees without having to go through the floor. Dont know what to do at this point.
Old 11-06-2008, 04:04 PM   #38
james t
moderation
Texarkana AR/TX
james t's Avatar
94 SAS sport
Vehicle Specs
(Original Poster)
Here's a side shot. Upper mount is just a cut down piece of 2" .250 wall sqaure tube i had laying around. There is tube running from the bumper corner to the frame that its welded to.
This also shows how much work i need to do cutting some more fender.
Old 11-06-2008, 04:41 PM   #39
IZwack
Germantown, MD
IZwack's Avatar
Vehicle Specs
That turned out pretty good James -- the angle is pretty close to the stock angle (+90 degrees rotated).
BTW is that the way that shock is supposed to be ran -- body up? Just wondering cauz I ran my rear shocks like that (which was upside down according to Explorer Pro Comp) and the ride was super harsh.
__________________
Old 11-06-2008, 04:48 PM   #40
Stic-o
Elite Movie Star
Tujunga, CA
Stic-o's Avatar
Vehicle Specs
Mine are body up...
__________________
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
