#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Offroad Tech Forums > Offroad Explorer - Ranger Projects > Offroad Fabrication - Bumpers, Sliders, Cages etc.
Notices
Offroad Fabrication - Bumpers, Sliders, Cages etc. For the Ford Explorer and Ranger entusiasts who like to build their own rock sliders, bumpers, rollcages etc.
Tube front bumper build
Reply
Thread Tools
Old 11-18-2008, 08:56 PM   #1
DB_1
Elite Ranger
La Quinta, Ca.
DB_1's Avatar
97 SC Ranger xlt
Vehicle Specs
Quoted: 65 Post(s)
(Original Poster)
So I've had all this tube stockpiled like a chipmunk stashes nuts, weather it great, work is slow so no more excuses to get some things done on the truck.
Thought I'd tackle building a front bumper with some 1.75 x .120 wall HREW tubing. Took me a good 3 tries to get the main bar the way I wanted it but I expected that. The stinger was gonna be 1.5" tubing but my first screw up looked like it would make a good stinger so I went with it.
Pretty simple design, it will have 2 supports going in between the frame rails in the front and 2 more side supports going to the outside of the frame rails.
Still figuring out how I want to integrate a receiver, ideally i'd like the frame horns finished off like Froaders with the corners tapered.
I'd also like to make stinger supports that tie into my shock hoops, other than making a hole in the grill the path is clear on the drivers side but the air cleaner duct is in the way on the pass. side.
Here's a couple pics so far:
DB_1 is offline   Reply With Quote
( Join the Elite Explorers )
Old 11-18-2008, 08:59 PM   #2
IZwack
Moderator Emeritus
Germantown, MD
IZwack's Avatar
1998 Ford Explorer
Vehicle Specs
Quoted: 2 Post(s)
Quote:
Great start DB!!
This is you, stashing tubes like a chipmunk
__________________
...how'd the moon get there, how'd the moon get there?
IZwack is offline   Reply With Quote
Old 11-18-2008, 09:08 PM   #3
Burns
Pulaski, TN
Burns's Avatar
1991 Explorer/2002 F-250
Vehicle Specs
Quoted: 20 Post(s)
I have been wanting to do a new bumper. It looks good.
__________________
Jonathan Burns
Moderator of the Feature Truck Forum
Owner of the "Lime"
Forum Rules and Usage
Burns is offline   Reply With Quote
Old 11-18-2008, 09:18 PM   #4
FROADER
Moderator
Huntington Beach, CA
FROADER's Avatar
2010
Vehicle Specs
Quoted: 59 Post(s)
I like it a lot!
Can you just get the pass side bar to the core support, then make another tube bent around the intake?
FROADER is online now   Reply With Quote
Old 11-18-2008, 09:28 PM   #5
DB_1
Elite Ranger
La Quinta, Ca.
DB_1's Avatar
97 SC Ranger xlt
Vehicle Specs
Quoted: 65 Post(s)
(Original Poster)
I have a couple options to look at, I can make the stinger supports go through the grill and core support than angle down and tie into the top of the frame instead of the shock hoops. Option 2 would be to go high and notch the bottom edge of the hood and core support to clear the tubing then tie into the shock hoop support bar. Option 2 would be a bit of work to not make it look like a hack job so that may be out. I'll have to look at it again tomorrow and play around with it.
Old 11-18-2008, 10:26 PM   #6
RockRanger
Elite Ranger
Fresno CA
RockRanger's Avatar
86 ranger no more
Vehicle Specs
Quoted: 115 Post(s)
If you put the tube that close to the fender on the side the fender and tube will make contact with each when you flex the truck out. I put mine nece and tight and the will rub a bit.
Looks good.
RockRanger is online now   Reply With Quote
Old 11-18-2008, 10:38 PM   #7
section525
sextion525
Red Bluff, Ca
section525's Avatar
1975 Ford Bronco 4x4
Vehicle Specs
Quoted: 21 Post(s)
Ooooooohhh!
__________________
Support the Forum
'13 3.5 Explorer
'75 5.0 Bronco
'04 6.0 Super Duty
section525 is offline   Reply With Quote
Old 11-18-2008, 10:41 PM   #8
Stic-o
Elite Movie Star
Tujunga, CA
Stic-o's Avatar
'99 XL 4x4 & '16 XLT
Vehicle Specs
Quoted: 178 Post(s)
Looks good Dave....
__________________
The JP Mobile ~'99 Explorer XL 4X4 * The Mall Crawler '16 Explorer XLT
The Tow Rig ~ '01 F250 Crew Cab 4X4 * The "Commuter" ~ '15 Focus ST
Stic-o is online now   Reply With Quote
Old 11-18-2008, 10:56 PM   #9
DB_1
Elite Ranger
La Quinta, Ca.
DB_1's Avatar
97 SC Ranger xlt
Vehicle Specs
Quoted: 65 Post(s)
(Original Poster)
Thanks guys...Matt, yeah it's just mocked up but I'll probably move it down and forward a bit so it has room to move.
The pic kinda throws you off too, it actually wraps around the outside of the body instead of under it.
Old 11-23-2008, 10:11 PM   #10
DB_1
Elite Ranger
La Quinta, Ca.
DB_1's Avatar
97 SC Ranger xlt
Vehicle Specs
Quoted: 65 Post(s)
(Original Poster)
Not much to report yet, i've been going back and fourth on how I want to mount the bumper to the frame. Going to try a couple things this week and see how it looks. If I don't get it finished this before I go wheelin' this weekend then I'll get back at it next week.
On a side note, I had to hack off my rear bumper since my shackles were hitting it and binding up my leaf springs. I'm either going to extend the mounts to clear the shackles or come up with something entirely new.
Old 11-23-2008, 11:19 PM   #11
FROADER
Moderator
FROADER's Avatar
2010
Vehicle Specs
Quoted: 59 Post(s)
How about some IZ shackles? They were having the same problem with the zuk.
Old 11-23-2008, 11:33 PM   #12
IZwack
Moderator Emeritus
Germantown, MD
IZwack's Avatar
1998 Ford Explorer
Vehicle Specs
Quoted: 2 Post(s)
Yes and make sure you paint them light blue
__________________
Old 11-24-2008, 11:21 AM   #13
DB_1
Elite Ranger
La Quinta, Ca.
DB_1's Avatar
97 SC Ranger xlt
Vehicle Specs
Quoted: 65 Post(s)
(Original Poster)
Cool shackles, i'll probably just extend the mounts another 1/2" and call it good
Old 11-25-2008, 08:36 PM   #14
DB_1
Elite Ranger
La Quinta, Ca.
DB_1's Avatar
97 SC Ranger xlt
Vehicle Specs
Quoted: 65 Post(s)
(Original Poster)
Some progress...kinda.
I liked Froaders bumper design since it finishes off the frame horns nicely so I bought some 1/4" masonite from Home Depot to make templates and make my own version.
This will mostly be built off 2" x .250 wall square tubing which will be a hitch receiver. It will have the tapered ends on the sides, ramp up on an angle up front with the receiver poking through in the middle. All the plating with be 3/16" except for the top which I might use 1/4" plate if I ever put a winch there.
This will give me a nice platform to weld the tube work to, it's gonna be A LOT of cutting and welding.
I get a pic posted tomorrow once I get all the templates cut.
Old 11-25-2008, 08:40 PM   #15
FROADER
Moderator
FROADER's Avatar
2010
Vehicle Specs
Quoted: 59 Post(s)
I still need to finish mine with tube too.
Old 11-25-2008, 09:04 PM   #16
DB_1
Elite Ranger
La Quinta, Ca.
DB_1's Avatar
97 SC Ranger xlt
Vehicle Specs
Quoted: 65 Post(s)
(Original Poster)
What are your plans for the tube work?
Old 11-25-2008, 09:10 PM   #17
FROADER
Moderator
FROADER's Avatar
2010
Vehicle Specs
Quoted: 59 Post(s)
You know, I never did photoshop what I wanted to do. I'll do that after I eat dinner and post it up.
The plans are to just come off the side of the frame and up below and around the lights. I don't want a hoop around the lights so I'll probably bring another support from the end of the bar (outside the body) back to the frame. Similar to IZwack's old one.
Old 11-25-2008, 09:32 PM   #18
DB_1
Elite Ranger
La Quinta, Ca.
DB_1's Avatar
97 SC Ranger xlt
Vehicle Specs
Quoted: 65 Post(s)
(Original Poster)
Sounds nice and simple, just the way it should be
Old 11-25-2008, 10:00 PM   #19
FROADER
Moderator
FROADER's Avatar
2010
Vehicle Specs
Quoted: 59 Post(s)
That's why my truck looks the way it does.
OK here is my plan. It's like magic.
IZ's
EDIT: That animation was bothering me.
Old 11-25-2008, 10:10 PM   #20
DB_1
Elite Ranger
La Quinta, Ca.
DB_1's Avatar
97 SC Ranger xlt
Vehicle Specs
Quoted: 65 Post(s)
(Original Poster)
Looks very IZ-a-licious
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
