ipwizard
- November 1, 2008
- Peoria, AZ
- '01 XLT
These are the parts I have collected to replace all the timing componets for the SOHC in my '01 Explorer.
Parts List as of 11/19/2008:
Jackshaft Chain/Tensioner Kit from TSB 04-14-4 Includes Instruction booklet from FORD 2U3Z-6D256-DA
Upper, and Lower Timing chain Tensioners
Chain Tensioner Upper (Left) FU3Z-6K254-B
Chain Tensioner Lower (Right) FU3Z-6K254-A
Jackshaft rear plug (Located in the back of the block) F77Z-6026-AB
Timing Cassette Front (Left/Front) FU3Z-6A257-A
Timing Cassette Rear (Right/Rear) 4L2Z-6M290-AA
Oil Pan Gasket (Upper Ladder assy to Block). F77Z-6710-AA
Oil Pan Gasket (Lower) 4L2Z-6710-AA
Valve Cover Gasket (Right Side?) F77Z-6584-AE
Valve Cover Gasket (Left Side?) F77Z-6584-BA
Gasket (Upper Intake) YL2Z-9461-AA
Gasket (Lower Intake) YL2Z-9E436-AA
Seal (Timing Cover Crank) E6TZ-6700-A
OTC FORD 4.0L SOHC Timing Tool Kit OTC-6488
Extra Stuff, If you pull the engine you might as well change these parts also, Cheap insurance IMHO.
Oil Pump XL2Z-6600-AA
Seal (Rear Main) F5TZ-6701-A
Seal (Transmission Tail Shaft Auto) 4L5Z-7052-AA
Everything together around $940.00 for all parts, and the tool kit. I know im going to have some extra stuff like water pump gasket might even change the water pump aswell depends how it looks/feels, and might as well change the thermostat and radiator hoses while I have it apart.
If I end up buying more Ford parts I will post the part numbers and a picture of the part. I'm also going to take pictures of the project as I do it. Going to do all the work the week after Thanksgiving.
Hope this info helps someone out.
-Keith
-Keith
