| EF Swag Store | 2013 Ford Explorer | Forums | Elite Membership | Chat Room | My Posts | Reviews | Explorer Photo Gallery |
| Explorer & Ranger Transmissions, Transfer Cases, & Differentials Transmissions, Transfer Cases. A4LD, 4R70W, 4R44E, 4R55E, 5R44E, 5R55E, M5OD, BW 1354, Control Trac, GEM, AWD. Ford 8.8", Dana 35 |
Thread Tools |
#1 |
Wannabe Elite Explorer
Doylestown, PA
'94 XLT
Hey everyone. I have been experiencing some issues with my truck lately and I don't know what the issue is. When I try to put it into reverse, it grinds gears and I have to throw it into reverse in order to get it in gear. At that same time, it is very hard to put it in 1st gear. I have to push very hard and sometimes it grinds. I am not moving my vehicle at all either. This is happening more and more frequently. I have 119,000 miles on it and I changes the transmission fluid last week. I put Royal Purple Syncromax Manual Transmission Fluid in it. It was running fine after that. Better then ever. I just picked it up from the shop after a front end alignment and I could barely put it in gear.
Could someone help me here? What could be causing this issue? |
#2 |
Battle Ground WA
88 Bronco II
Your clutch hydraulics are leaking, most likely the slave is blown, common problem.
__________________ 88 Bronco II EB, 4.0L, M5OD, 4.56s, Aussie Locked 8.8, Aussie Locked D35 w/e-clip eliminator, Manual 1354, 3" PA Body Lift, 34x10.5 Swamper LTBs, Warn Hubs, U-Joint Drive shaft, OBA, Custom bumpers front/rear, 2 1/2" Exhaust w/flowmaster 40 series. 95 Dakota Sport CC, 5.2, 5-Spd(Hurst), 4x4, M1, HS 1.7 RR's, Aero Turbine 3030/Side Exit, 50mm TB, 30x9.50s on 15x8 Ultra 50 Series, 3.55s. |
#3 |
Doylestown, PA
'94 XLT
Ok, any information on that? Where/What is the slave. If my clutch hydraulics were leaking, wouldn't the fluid have gone down? I haven't filled it in awhile and its still full.
#4 |
North of Ottawa
'93 XLT, Cayman Green RIP
X2. When your clutch either has leaked or some air is in the lines the clutch plate doesn't totally disengage when you shove the pedal to the floor. If you were to stuff it in 4th or 5th and then quickly into reverse or 1st it shouldn't grind too bad. Most likely you will have to replace either the slave or master cylinder.
__________________ Ribs. I had ribs for lunch, that's why I'm doing this. List of useful TTB Threads |
#5 |
Doylestown, PA
'94 XLT
I took a quick look on NAPA and this is what I found.
http://www.napaonline.com/MasterPage...nder&VehCode=Y Edit: I looked on RockAuto and wow, didn't think it would be that expensive. Any threads on changing these? How long do you think it could take? http://www.rockauto.com/catalog/x,ca...parttype,10290 Last edited by sledgehammer1990; 11-21-2008 at 07:19 PM. |
#6 |
pineville,nc
97 Explorer Sport
I had that same problem with my 97 sport.First check to see if you have enough fluid in the small reservior for the clutch.if it's low add some brake fluid and that might fix it. that was a temporary fix but i ended up having to change the clutch slave cylinder. the part cost about 130 or so.you have to remove the clutch so i just paid a tranny shop to change it. total cost was $400. good luck .
#7 | |
Doylestown, PA
'94 XLT
Quote:
#8 |
Doylestown, PA
'94 XLT
After reading some more, I found that I think I don't have to touch the Master Cylinder. The Slave cylinder is around $61
http://www.rockauto.com/catalog/x,ca...,parttype,2044 |
#9 |
NC
'95 XL 4x4
You have to remove the tranny to change the slave cylinder.
#10 |
pineville,nc
97 Explorer Sport
I took my explorer to a mr transmission b/c it actually locked up in second gear.I am not sure what all had to be removed but i know the clutch did for sure. i havent had a problem with the truck since the slave cylinder was replaced.
#11 |
Doylestown, PA
'94 XLT
Sometime this week, I am going to discuss this with my dad and see if I am going to change it myself or take it to the shop. I told him and he had to replace 2 of them before on other vehicles. Luckily, it was on the outside of the transmission.
#12 |
Doylestown, PA
'94 XLT
OK, I got my truck back and I put over 100 miles on the new clutch. It is extremely hard to shift. I can't put it in reverse unless I start it in reverse, then when I shift out, I have to turn off the car, put it in first, then start it again.
I am taking it back on Monday, but they said it is hard to bleed the clutch line from the master cylinder. Any ideas on bleeding it myself? |
#13 |
pineville,nc
97 Explorer Sport
I was told it was my clutch also. so after changing it the problem continued.bleeding the line helped for a few days. I found out there was a leak in my slave cylinder and air was getting in through there.I had same deal as you: i couldnt get it to shift into first unless i turned the car off.Once in first i could only go into 2nd. thats when i had the slave cylinder changed. problem solved.If i would have checked that first I would have save a few hundred by not changing the clutch.but oh well its all new now.
#14 |
Doylestown, PA
'94 XLT
But thats just it. That was the whole reason why I had my truck in the shop. I had the Slave Cylinder, Master Cylinder, and Clutch changed. They showed me and my clutch only had about 10,000 miles left on it.
Do you think I could've gotten a bad slave cylinder? I did get a bad master cylinder and had to exchange for another one that was fine. |
#15 |
pineville,nc
97 Explorer Sport
Yea you might have gotten a bad one.
#16 |
Doylestown, PA
'94 XLT
Okay, I called up the shop and they told me the issue and they fixed it. Bleeding the master cylinder is very hard since its in a weird position. The only way they were able to completely remove the air was to jack the front end up way high. I am going to pick it up now.
| Thread Tools | |
