Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Explorer & Ranger Transmissions, Transfer Cases, & Differentials
Notices
Explorer & Ranger Transmissions, Transfer Cases, & Differentials Transmissions, Transfer Cases. A4LD, 4R70W, 4R44E, 4R55E, 5R44E, 5R55E, M5OD, BW 1354, Control Trac, GEM, AWD. Ford 8.8", Dana 35
How to remove an Aussie Locker?
Reply
Thread Tools
Old 11-24-2008, 05:11 PM   #1
DeRocha
NEX Vice President
Brockton, MA
DeRocha's Avatar
'93 XLT 4x4
Vehicle Specs
(Original Poster)
The short story is that I need to remove my aussie locker to replace the drive's side axle backing plate. As it stands now I have removed the center pin, the 4 springs and alignment pins, but I cannot get the passenger side "C" clip to come out and want to know what the trick is? I have rotated the passenger axle so the "C" is facing up and the "C" clip cups are both all the way to the driver's side. I had a helper push the passenger axle in and out while I played with the side cam gear trying to get the "C" clip to drop but wouldn't. Any ideas for those that have worked on an aussie?
BTW I have seen the very good Aussie install write up
__________________
John D-"Search first, Ask questions later" & "You can have my Explorer when you pry the keys from my cold dead hands." <<<Forum Rules >>>*My Truck*
4x4 Trouble Shooting Guide
See how cars work Axle and tire calculators U-joint replacement info/pics
Repair info NEX-New England Explorers NEX: Club Events
DeRocha is offline   Reply With Quote
Old 11-24-2008, 05:36 PM   #2
Tbars4
Offroad Moderator
anaheim hills,california
Tbars4's Avatar
95 ranger 4x4/ 91 X 4x4
Vehicle Specs
...You probably have tried this but, have you tried pulling the slack on the drivers side shaft first, and then pushing in on the pass side.......I know the last clips are a pain to put in in the first place...
__________________
I have Rocks in my head. What's in yours?
'95 ranger xl 4x4 2.3L std cab, 2 sticks Ranger RegistryThe Squirrel
'91 4x4=To much to list, much more to add.. Project "X" and more Pics & Mod's List
How to: Wheels,Tires, & Lifts...
Buy Explorerforum.com Items here
Tbars4 is offline   Reply With Quote
Old 11-24-2008, 05:42 PM   #3
LBarr2002
Leesville, SC
'91 XLT 4x4, '92 XLT 4x4
Vehicle Specs
I don't know how to get it out, but don't put it back in when you get ready to put it back together. Do the c-clip eliminator with the spring.
__________________
'87 Samurai, Dana 44's, 5.89's, spooled
'92 XLT and '91 XLT 4x4, both SOLD
'04 LJ
'01 Chevy 2500HD Duramax 4x4 - The Toy Hauler
LBarr2002 is offline   Reply With Quote
Old 11-24-2008, 05:59 PM   #4
brianjwilson
98 Ranger, 05 Sport Trac
Vehicle Specs
I used a couple butter knives, and I believe I pushed the c-clip into the front of the diff (if memory is right).
__________________
2006 F150 FX4 Super Crew - Xcal 2, Bilstien 5100's leveled 2"
2003 VW Jetta GLI VR6 six speed, 2" drop on 18's
Old Stuff;
2005 Explorer Sport Trac 4x4 locked and lifted on 33's
1998 Ford Ranger 4x4 on 33's
1997 Ford Explorer 4x4 on 31's
brianjwilson is offline   Reply With Quote
Old 11-24-2008, 06:33 PM   #5
HahnsB2
Battle Ground WA
88 Bronco II
Vehicle Specs
Quote:
You're thinking of the D35, he's talking about the 8.8.
__________________
88 Bronco II EB, 4.0L, M5OD, 4.56s, Aussie Locked 8.8, Aussie Locked D35 w/e-clip eliminator, Manual 1354, 3" PA Body Lift, 34x10.5 Swamper LTBs, Warn Hubs, U-Joint Drive shaft, OBA, Custom bumpers front/rear, 2 1/2" Exhaust w/flowmaster 40 series.
95 Dakota Sport CC, 5.2, 5-Spd(Hurst), 4x4, M1, HS 1.7 RR's, Aero Turbine 3030/Side Exit, 50mm TB, 30x9.50s on 15x8 Ultra 50 Series, 3.55s.
HahnsB2 is offline   Reply With Quote
Old 11-24-2008, 07:01 PM   #6
Stic-o
Elite Movie Star
Tujunga, CA
Stic-o's Avatar
'99 XL 4x4 & '06 XLT 4x2
Vehicle Specs
Try shaking the axles in and out with the clips so they will fall down. That's how my lock right came apart. It just fell out at the right point. I cringe the day I have to take my 8.8 apart again, because I had to hammer in the c clip
__________________
The JP Mobile ~'99 Explorer XL
The Mall Crawler ~'06 Explorer XLT
The Tow Rig ~ '05 F-150 SuperCrew
The Commuter ~ '10 Focus SES
Stic-o is offline   Reply With Quote
Old 11-24-2008, 09:43 PM   #7
LBarr2002
Leesville, SC
Vehicle Specs
Quote:
ahh...good point. Sorry.
__________________
'04 LJ
Old 11-25-2008, 06:35 AM   #8
DeRocha
NEX Vice President
Brockton, MA
DeRocha's Avatar
'93 XLT 4x4
Vehicle Specs
(Original Poster)
All good advise thanks for the suggestions.. I'm working outside and it starting raining last night so I will give them a try when the rain stops (in a few days). I'm currently thinking the butter knife and maybe a dental pick may do the trick..
In the mean time this is what I've done:
I rotated the Carrier so the open part was facing down (so the "C" clip would fall out). I pulled the driver's side shaft all the way out so its on its "C" clip. I then used a few screwdrivers to force/keep both cams on the driver's side. When you do this the teeth on the cam and side gears mesh perfectly which gives you the biggest gap for the slot on the passenger cam. . I could push the passenger axle in and see the "C" clip centered in the slot, but it was still attached to the axle shaft and would only come 1/2 way.. I was thinking that some really thin tweezers would have been able to reach in and yank them out, but I can't find mine. I tried with a pair of micro needle nose pliers, but they are too thick. I could easily touch the clip with a screwdriver and even put a large magnet on it to see if it had enough force to pull out the clip (but it didn't)...
__________________
Old 11-25-2008, 11:39 AM   #9
brianjwilson
Vehicle Specs
Yeah the magnet thing didn't work for me either. I think I remember having to push it out the backside so it fell out.
__________________
Old Stuff;
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
