#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer 3rd Generation > Stock 2002 - 2005 Explorers
Notices
Stock 2002 - 2005 Explorers Questions related to non-modified 2002 - 2005 Explorers and Mountaineers. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. Sport Trac and Sport use the 1995-2001 forum.
2004 V8 Explorer check charging system problem.
Reply
Thread Tools
Old 11-28-2008, 10:04 PM   #1
kent tango
2004 Explorer Eddie Bauer
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Dk Exp 2004 V8 Explorer check charging system problem.
I am a new forum member and found a similar problem to the one I have where a 05 explorer V6 owner had a "check charging system" problem but never posted a solution?? I have had a similar problem with my 04 Explorer V8 (w/ tow package), but many trips to Ford dealers and private mechanics have not solved the problem. I have added a new battery and alternator, and during the latest dealer siege of three weeks, they tried (2) new PCM's, did a grid (wiring harhas) overlay test and they still have not solved the problem?? The "check charging system and battery light" still come on regularly. The system is charging OK but misses occasionally under light load?? Dealer now says I need a new $1,400 (primary) wiring harnas. The dealer says he "believes" that is the solution (even though he could not find it), but also says it might need one or two other harnaces if that doesn't work. The Explorer only has 37K and is well maintained (Mobile 1 etc.) This is getting out of hand and driving me nuts!! I need a reliable tow vehicle soon!! to make a trec south with my trailer in January and February. Any help would be appreciated!!! -Kent-
kent tango is offline   Reply With Quote
( Join the Elite Explorers )
Old 11-28-2008, 11:48 PM   #2
Sams01XplrSprt
Southern Cali Explorer
Newport Beach California & Bay Area California
Sams01XplrSprt's Avatar
2001 Sport (sold)
Vehicle Specs
Quoted: 4 Post(s)
welcome kent
__________________
2001 Ford Explorer Sport 4.0 sohc engine. Mods include: dual 40 series flowmasters & high flow k&n air filter & removed silencer & yellow fog lights (sold for $1,800) as of 2-26-12
Sams01XplrSprt is offline   Reply With Quote
Old 11-29-2008, 10:22 PM   #3
BrooklynBay
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
Quoted: 380 Post(s)
Welcome to this forum! Your charging system doesn't have that many separate harnesses that it should cost that much. Check Autozone's website for a schematic diagram. You could check each wire from point to point with a continuity tester.
BrooklynBay is offline   Reply With Quote
Old 02-10-2014, 06:53 AM   #4
fkatende
2004 ford explorer
Vehicle Specs
Quoted: 0 Post(s)
i just acquired a 2004 ford explorer XLT and has the similar problem 'check charging system'. i have looked at various problem and seems like its a common problem and there is no lasting solution to it.......has some one out there managed to have it fixed for good..help..!
fkatende is offline   Reply With Quote
Old 02-15-2014, 09:54 PM   #5
mikebusc
2004 Mercury Mountaineer
Vehicle Specs
Quoted: 0 Post(s)
Looks Like you responded to an old post (2009). I have the same problem. Going to try tomorrow changing battery and checking belt and alternator. Let me know if you find anything too.
mikebusc is offline   Reply With Quote
Old 05-28-2014, 09:49 AM   #6
westernMdlife
2004 Explorer XLT
Vehicle Specs
Quoted: 0 Post(s)
I've been having this problem for the last week. It will start up but the alternator doesn't charge the battery back up. I started it and kinda "jump started"/excite the I term on the alternator and it began to charge properly, until I turn the engine off. Replaced the alternator (new), battery is 2yrs old but still good. Have the constant hot to the alternator, continuity on stator wire is good. Only thing I'm left with is something with the ignition switch? ..IDK..
westernMdlife is offline   Reply With Quote
Old 05-29-2014, 12:42 AM   #7
name420420
Fairmont,West Virginia
2002 ford explorer 4.6L
Vehicle Specs
Quoted: 5 Post(s)
mine had this issue. was a broken wire in the harness by the battery. I also am told their is a fuse by the alternator itself. but not sure about that
name420420 is offline   Reply With Quote
Old 05-29-2014, 03:58 PM   #8
phouse
Phila PA
1991 Explorer
Vehicle Specs
Quoted: 0 Post(s)
Have you tried a alternator from the Ford Dealership?
__________________
1991 Explorer 4WD 4DR 4.0 V6 Pushrod 196K blown head gasket.. RIP
2005 Explorer XLT
1998 Mercedes Benz E 430 Sport
1987 Oldsmobile Cutlass Salon V8 Factory Bucket seats
phouse is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
