| Explorer & Ranger Transmissions, Transfer Cases, & Differentials Transmissions, Transfer Cases. A4LD, 4R70W, 4R44E, 4R55E, 5R44E, 5R55E, M5OD, BW 1354, Control Trac, GEM, AWD. Ford 8.8", Dana 35 |
Thread Tools |
#1 |
Wannabe Elite Explorer
1996 F150
96 2wd 4r70w od issues
Ok, this is an ongoing pain in da butt....Here's the info, 1996 2wd 5.0, 4r70w tranny, engine replaced with a '93 5.0, trans acts like it's shifting between neutral and in gear. Doesn't feel like slippage, bought truck like this, ($400.00 couldn't pass it up). I have replaced all internal solenoids and mlps with new ones. Can't get my scanner to "link" up to computer so I can't get any codes. Anyone got any possible ideas?
#2 | |
Got beer?!?!?!
Springport, Michigan
91 xlt & 93 xlt
Quote:
Eric __________________ ASE certified mechanic. 91 XLT on 36's. 2005 F150 XLT -Tow rig. |
#3 |
1996 F150
While replacing the solenoids, I dropped the valve body and checked the filter screen, verified the check balls weren't stuck, and looked at gaskets for a tear or what not. Reinstalled, torqued to 92 in/lbs, new pan filter and fluid but no difference. It does shift ok through the gears, will have to scout around for a pressure gauge and line and try a pressure check while driving, if it's an internal leak, might as well try rebuilding it. thanks
#4 |
1996 F150
Wow, the details can kill ya....posted it was od issue in the title but didn't really explain it, sorry. When up to speed 50/70 mph, it seems to shift back and forth between neutral and overdrive.
#5 | |
Got beer?!?!?!
91 xlt & 93 xlt
Quote:
This is the kit I have, just an idea for ya. Maybe a place like Harbor Freight will have one?? Good luck Eric __________________ ASE certified mechanic. 91 XLT on 36's. 2005 F150 XLT -Tow rig. |
#6 |
1996 F150
Just another little oddity I found. I know OBD2 started in 1996, my truck has the connector
in the cab for it and has power to it, just can't get a data link to get codes. Now for the odd thing, it also has the OBD1 connectors under the hood and I can't find anywhere on the truck that it "actually" is OBD2 compliant, ie. under hood, driver door frame etc. Have OBD1 reader for my wife's 92 crown vic, so when I get the battery chrged up am gonna try to get codes off the OBD1 connector.......weird......I'll hint to the wife about that gauge kit, maybe for xmas, lol. |
#7 |
ELITE BRONCO2ERER
Crawlorado
B2 Mod
what?????
This 96 truck has a 93 5.0L under the hood with 93 wiring?????? No wonder your 4r70w isnt working correctly, if it is indeed a 4r70w does your V8 have a distributor? __________________ 96 Explorer daily driver build-1996 XLT 5.0L AWD to 4x4 conversion complete on 33's 88 BII 5.0L conversion - BII 5.0l drivetrain thread My Bronco II - 1988 Bronco II 4x4 V8 on 35's - registry and updates Wifes 07 FJ build - 2007 FJ cruiser locked and lifted |
#8 |
1996 F150
Hey, I didn't do it. Just what I was told had been done to it.....supposedly all the sensors, wiring, etc. was switched over so basically just the running block was changed.......I'm just trying to get it going. And yes, according the pan bolt pattern and case #'s I could find, it is a 4r70w like is supposed to be in it.
#9 |
1996 F150
Welp, started to get codes from connector under hood, but for some reason it won't complete the KOEO test. Starts to test, get first 2 digit flashes, then a sound like a fuel pump turning on comes from under the driver side and it quits. In order to start the test over I have to actually disconnect the battery, just turning key off won't do it. Darn thing has more issues than my ex-wife. I'm kinda stymied for the moment, but guess I'll have to hunt that noise down next time I'm home.
#10 |
1996 F150
Found this while checking the EECIV posts...
"I currently still have the 92 PCM in it and the original exhaust with just one o2 sensor.Should I change that too? The only issue I seem to have( I posted it in the tranny forum, maybe wrong place?) is my CEL was coming on. I checked it and I'm getting codes 522=vehicle not in park or neutral during KOEO-it was in park..and 629=CCS circuit fault or lock-up solenoid circut fault. I haven't noticed anything wrong with the TC.It seems to stay in OD and it doesn't shift back and forth or rev up and down during driving like I would expect if it isn't locking." Exactly the problem I'm getting, shifting back and forth and rev up and down during driving, at this point any advise would be helpful. |
#11 |
ELITE BRONCO2ERER
Crawlorado
B2 Mod
was this truck ever running right since the engine work done to it?
does the V8 have a distributor? __________________ 96 Explorer daily driver build-1996 XLT 5.0L AWD to 4x4 conversion complete on 33's 88 BII 5.0L conversion - BII 5.0l drivetrain thread My Bronco II - 1988 Bronco II 4x4 V8 on 35's - registry and updates Wifes 07 FJ build - 2007 FJ cruiser locked and lifted |
#12 |
1996 F150
According to the guy I bought it from, it ran good for about a year, then tranny started acting up. Engine starts and runs fine, no problems I can "detect" there. Yes, it does have a distributor.
#13 |
ELITE BRONCO2ERER
Crawlorado
B2 Mod
here is your problem
Your engine is from a 93 car/truck and it is using a 93 computer How do I know this? 5.0L explorer's do not have a distributor 96+ explorer's do not have a diagnostics connector under the hood Your 4r70w automatic transmission REQUIRES a computer to operate it. The 96-2001 Explorer 5.0L computer controlls the 4r70w transmission the 3-4 shift and converter lock up and controlled by the PCM Whoever built this truck screwed up big time, they put a 93 5.0L into a V8 explorer and instead of using the explorer computer and awesome GT-40 5.0L engine they used an older 5.0L with the older computer = sucks! If i was you I would either: 1. purchase a stand alone transmission controller for your 4r70w (big $$$, lots of wiring) 2. convert to a different auto / 5 speed transmission 3. go to the junk yard and buy the correct engine for your vehicle and install it along with the computer/wiring, etc 4. Part it out Wow what a headache, I hope you got a GREAT deal Previous owners idea of runs great = please take this off my hands __________________ 96 Explorer daily driver build-1996 XLT 5.0L AWD to 4x4 conversion complete on 33's 88 BII 5.0L conversion - BII 5.0l drivetrain thread My Bronco II - 1988 Bronco II 4x4 V8 on 35's - registry and updates Wifes 07 FJ build - 2007 FJ cruiser locked and lifted |
#14 |
1996 F150
Well, I'm sure I could get my 400 bucks back just for the engine, but the body is in great shape so I'm gonna weigh my options, maybe trans controller or switch to earlier tranny. Thanks for the help.
#15 |
ELITE BRONCO2ERER
Crawlorado
B2 Mod
You can find 98-2001 complete 5.0L Explorer 5.0L engines with computer/most accessories here in denver for $350-500 with low miles all day long
The 93 5.0L is WEAK compared to the GT-40p 5.0L used in the explorer You could put a C4 auto or AOD auto in it fairly cheap The Baumman 4r70w controller is damn near $1000, I am not sure of others on the market these days, I am pretty sure there are cheaper options out there now too.. cool thing about the aftermarket controllers is you can shift your trans when you want I can tell you this truck has not been "right" since the day the 93 engine went in, I would have a "word" with the previous owner LOL __________________ 96 Explorer daily driver build-1996 XLT 5.0L AWD to 4x4 conversion complete on 33's 88 BII 5.0L conversion - BII 5.0l drivetrain thread My Bronco II - 1988 Bronco II 4x4 V8 on 35's - registry and updates Wifes 07 FJ build - 2007 FJ cruiser locked and lifted |
#16 |
1996 F150
Well, he had to move to Maine, so I'll let the snow and cold be the last word. (btw, I be in sunny florida, lol). A friend suggested a C4/C6, think it was "go vacuum and screw that electric s**t". Any thoughts on what I need to watch out for when trying to find/install a C4/C6 or an AOD?.....not sure but wouldn't computer be a lil miffed about not sensing the tranny if I went with a C4/C6?
#17 |
ELITE BRONCO2ERER
Crawlorado
B2 Mod
C4, C6 and AOD are before the computer controls
I know with the AOD you had better get your input cable adjsuted 100% of you can blow the trans up in a short time (like a week LOL) So your computer wont care Your truck was likely thrown together, with the minimum done to get it to run = sucks! I have seen these conversions before and its just like buying $400 worth of headaches! At least yours runs good! LOL for $400 I probably would have dragged it home too Now you know whats wrong with it I vote keep the 4r70w and control it, its a wicked cool transmission __________________ 96 Explorer daily driver build-1996 XLT 5.0L AWD to 4x4 conversion complete on 33's 88 BII 5.0L conversion - BII 5.0l drivetrain thread My Bronco II - 1988 Bronco II 4x4 V8 on 35's - registry and updates Wifes 07 FJ build - 2007 FJ cruiser locked and lifted |
#18 |
1996 F150
I'll definetly keep the tranny, maybe not in this ride, but I got a corner in the shop not doing anything right now, ( might have to move the ironhead though).
I'll probably look around for a C4, I have abit of experience with using those as switch outs. Yeehaw, more adapter/bracket building.......Bad thing is, tore my sporty apart 3 years ago to chop it (2 in stretch on the dwntubes, 3 in stretch on the backbone, 10 over springer frntend, extended the rear 3 in, widened it........I'm never gonna get it done with all this other stuff creepin in. |
#19 |
ELITE BRONCO2ERER
Crawlorado
B2 Mod
LOL I have a 98 sploder that needs a new 5.0L, been sitting for 4 months, was to be done well before X mas....I know the feeling!
first remodel the house, clean garage, fix daily driver, clean garage, repeat... __________________ 96 Explorer daily driver build-1996 XLT 5.0L AWD to 4x4 conversion complete on 33's 88 BII 5.0L conversion - BII 5.0l drivetrain thread My Bronco II - 1988 Bronco II 4x4 V8 on 35's - registry and updates Wifes 07 FJ build - 2007 FJ cruiser locked and lifted |
| Thread Tools | |
