Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1991 - 1994 Explorer Ranger Navajo 1st Generation > Stock 1991 - 1994 Explorers
Notices
Stock 1991 - 1994 Explorers For questions related to the base Ford Explorer. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. No modification questions.
Rear main seal replacement.
Reply
Thread Tools
Old 11-30-2008, 03:24 PM   #1
Darrman
Waxahachie, TX
'92 Sport 4x4/2001 Sport
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Ok, my rear seal is leaking pretty good, at 104k, I guess its about that time for a new one. I am wondering what all is involved it replacing it.
I know that the trans has to be removed, and the converter/flywheel, or in my case the clutch/flexplate, to get at it. My chilton claims it can be replaced after this is done, but will the one peice seal fit over the rear hub?
Thanks for any help!
__________________
Darrman is offline   Reply With Quote
( Join the Elite Explorers )
Old 11-30-2008, 03:34 PM   #2
boggs1227
Flowery Branch , Georgia, 1994 sport 2wd auto
2005 colorado 2wd 5spd
Vehicle Specs
Quoted: 0 Post(s)
not sure what your asking ...will the new seal fit over the end of the crank ? i would assume so .tho i have not done mine i think that there is a different rear main seal ...a updated version of it ...i think that the factory ones had faults with them and a newer updated version was produced to correct the old ones failures.may help to buy a "seal puller" and "installer" tools .this may help you remove it with out damageing the internal lip where the new seal sit in and the installer will help you get a even pressure all around the seal ..tho i don't think the installer is all that nessary ....just makes it easier and quicker but you can use a ball hammer witha piece of wood to get the same results ,just you have to be more carefull this way.
that help ?
__________________
Scott .
boggs1227 is offline   Reply With Quote
Old 11-30-2008, 06:03 PM   #3
Darrman
Waxahachie, TX
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Well I have never seen the back end of a 4.0, but on my 390 that I had rebuilt, the hub that the flywheel bolts to is bigger than the seal itself, which meant you would have a 2 peice seal.
So you should be able to pull the seal out and replace without any problem?
__________________
Old 11-30-2008, 07:49 PM   #4
boggs1227
Vehicle Specs
Quoted: 0 Post(s)
http://shop.advanceautoparts.com/pro...pe=105&PTSet=A
it appears to be one solid unit no breaks in it so i guess that it would have to .
__________________
Scott .
Old 12-02-2008, 10:47 PM   #5
marragtop
balt, md
91, 92, 95, and 2000 xlts
Vehicle Specs
Quoted: 4 Post(s)
Make sure the PCV valve isn't clogged. If it is, the built up pressure can cause a leak at the rear seal. It's worth a try considering the alternative.
__________________
'88 F150 4x4
'91 Explorer XLT 4x4
'92 Explorer XLT 4x4
'95 Explorer XLT 4x4
If it don't = 16 (4x4), it ain't worth driving...
marragtop is offline   Reply With Quote
Old 12-02-2008, 10:56 PM   #6
boggs1227
Vehicle Specs
Quoted: 0 Post(s)
hmmm..... i did not know that ...makes seance tho....improper crank case ventalation would make the oil seep out at the weakest point....good point there .
__________________
Scott .
Old 12-03-2008, 09:24 PM   #7
Darrman
Waxahachie, TX
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Good point, I wish it was the case with mine, but I replace it every year. I did check tonite tho, clean and free.
I am sure this will be a pain in the ass, but I am tired of drips on the concrete. I use synthetic oil, which may be aiding its ability to leak, I dunno.
That plus the fact I have beefed the motor up a little may contribute also.
__________________
Old 12-04-2008, 01:59 AM   #8
scrivyscriv
Memphis, TN
93 Sport 2WD
Vehicle Specs
Quoted: 1 Post(s)
I changed my clutch & rear main seal a few months ago, and even though I can't remember exactly what the end of my crank had on it with the hub and everything, I know for a fact once I got the flywheel off, I was able to R&R the seal in no time.
Note here: Your leak MAY not be from the seal. My rear main was leaking a little, but the culprit ended up being the oil pan gasket... which, I'm sure you know, isn't going to get fixed unless my motor blows up and I have to replace it.
scrivyscriv is offline   Reply With Quote
Old 12-04-2008, 12:16 PM   #9
Four0Sport
West Virginia
1993 2dr
Vehicle Specs
Quoted: 41 Post(s)
x2 on the oil pan gasket. there is no way im pulling the motor to replace the oil pan gasket. it can continue to leak. half of my problem is the valve cover gaskets, im just too lazy to spend a day cussing at the truck to change them.
__________________
1993 Explorer Sport, Narrowed HP44 SAS, UA2015 survivor
Four0Sport is offline   Reply With Quote
Old 12-05-2008, 11:48 AM   #10
safn1949
Mankato, Minnesota
M60A1 my first offroader
Vehicle Specs
Quoted: 2 Post(s)
Yep,I have a slight leak from my oil pan gasket.Tough,I'm not going to fix it.
__________________
1994 XLT,4.0,3.73 LS
149,000 miles.
Need a Panasonic Toughbook? I have them,email me for details.
safn1949 is offline   Reply With Quote
Old 12-22-2008, 06:48 AM   #11
Anime
EF YEAH!!
Anime's Avatar
2016 EX Sport Concept
Vehicle Specs
Quoted: 190 Post(s)
The rear main seal isn't anything complex to replace if you're just trading one seal for another. Pop it off without messing up the surface, apply lube, bang the new one on evenly until it's flush. It's just a one piece seal that fits quite well over the rear crank hub. There's a shim kit (or special seal) for those that do leak due to the surface being too smooth, but the leaks do seem to be from somewhere else. I swore the oil leak at the back of the engine was the rear main, but it looks like the valve cover gasket, head gasket, or oil pan gasket are more likely. I guess replacing it while the tranny is down rather than risk it going bad and having to drop it again just for that makes sense, though. Just be sure to lube the new seal and take it super easy on the first startup after it's all together.
__________________
"I think man has always gone where he has been able to go, and I think that when man stops going where he can go, he will have lost a lot. Man has always been an explorer. To me, there's a fascination in thrusting out and going to new places. It's like going through a door because you find the door in front of you." - Michael Collins
Anime is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
