#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer 3rd Generation > Stock 2002 - 2005 Explorers
Notices
Stock 2002 - 2005 Explorers Questions related to non-modified 2002 - 2005 Explorers and Mountaineers. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. Sport Trac and Sport use the 1995-2001 forum.
I replaced my steering column, and it won't start. I'm new here, and need some help!
Reply
Thread Tools
Old 12-02-2008, 07:37 PM   #1
watt80
02 mountianeer v6
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
i just replaced the steering column on my 02 mountianeer an cant start it.is it something with the theft switch? if so how do i reset it?
watt80 is offline   Reply With Quote
( Join the Elite Explorers )
Old 12-02-2008, 07:43 PM   #2
Sams01XplrSprt
Southern Cali Explorer
Newport Beach California & Bay Area California
Sams01XplrSprt's Avatar
2001 Sport (sold)
Vehicle Specs
Quoted: 4 Post(s)
welcome watt and good luck with ur mounty
__________________
2001 Ford Explorer Sport 4.0 sohc engine. Mods include: dual 40 series flowmasters & high flow k&n air filter & removed silencer & yellow fog lights (sold for $1,800) as of 2-26-12
Sams01XplrSprt is offline   Reply With Quote
Old 12-02-2008, 10:28 PM   #3
BrooklynBay
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
Quoted: 380 Post(s)
Welcome to this forum! Check the connection to the ignition switch wiring harness.
BrooklynBay is online now   Reply With Quote
Old 12-03-2008, 07:39 AM   #4
ExploringNC
Hickory, NC
'98 XLT, '91 EB
Vehicle Specs
Quoted: 0 Post(s)
There is a switch on the shifter column that tells the ignition that you are in park. Make sure the wire is hooked up and inserted correctly. You can check the switch by using an ohm meter.
__________________
'91 EB 4.0 OHV 4x4
31x10.5 Maxxis Bighorn's
Uwharrie 2010
BrooklynBay's List of Useful Threads
ExploringNC is offline   Reply With Quote
Old 12-03-2008, 04:29 PM   #5
watt80
02 mountianeer v6
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
thanks NC.i'll try that but heard that it might have somthing to do with the theft system that is stock.idk
Old 12-03-2008, 11:07 PM   #6
joemiranda
North Ga Mountains
04 Limited
Vehicle Specs
Quoted: 0 Post(s)
I had a buddy change his steering column in his ford focus and he had to get the key reprogrammed. Another thing to try is to put the ignition from your old steering column in there if that's possible. Sorry couldn't be more help.
joemiranda is offline   Reply With Quote
Old 12-04-2008, 09:34 AM   #7
ExploringNC
Hickory, NC
'98 XLT, '91 EB
Vehicle Specs
Quoted: 0 Post(s)
Quote:
I would start there. If your using the key that came with the replacement column then it won't mach the key that is programed in the theft system. Call a Ford dealer or local shop you trust and ask them what you should do. Of course they will say bring it in but if you can't start it how can you do that unless you tow it. What was the reason you had to replace it?
__________________
'91 EB 4.0 OHV 4x4
Uwharrie 2010
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
