Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Ranger - Mazda B-Series Forum > Ford Ranger - Mazda B-Series Forum
Notices
Ford Ranger - Mazda B-Series Forum Ford Ranger and Mazda B Series forums. The Mazda B2300 B3000 and B4000 are clones of the Ford Ranger, with all systems the same. The only differences are trim and a few body parts. This forum discusses Ford Ranger and Mazda B series specific issues. Owners of the older Mazda B2000 B2200 and B2600 are welcome as well.
Where is the VSS sensor located on a 94 Ranger?
Reply
Thread Tools
Old 12-06-2008, 03:35 PM   #1
scrapper
Maroa Il
1994 ranger xlt
Vehicle Specs
Quoted: 2 Post(s)
(Original Poster)
I changed the rearend with one from a 86 and it has no abs. How can I get a vss on my truck for cruise control and overhead console temp ? I understand that vss and abs are the same. Is there a spot on the trany, 2 wheel drive 5 speed? is there after market sensor I can install? Thanks
scrapper is offline   Reply With Quote
( Join the Elite Explorers )
Old 12-06-2008, 05:24 PM   #2
Michiganbear
Traverse City, MI
1992 Explorer Sport
Vehicle Specs
Quoted: 0 Post(s)
vss will be mounted on the tail shaft of the trans, where you would find the speedo cable.
abs sensors are NOT the same sensor, abs sensors are on each wheel (except for the RABS system, which only uses 1, and its mounted on the rear axle, near the driveshaft).
Michiganbear is offline   Reply With Quote
Old 12-06-2008, 06:03 PM   #3
scrapper
Maroa Il
1994 ranger xlt
Vehicle Specs
Quoted: 2 Post(s)
(Original Poster)
I have been going crazy because I cannot find the vss wire. I looked at the wires in the dash but dont see anything gray with black stripe. The connector at the fire wall is numbered and the 3 wire is supposed to be vss+ it is white with blue stripe? I tried to look in engine compartment but no luck. If I chase wires from trany should be the right ones? why is wires different color in my truck? any help would be great
Old 12-06-2008, 07:25 PM   #4
Michiganbear
Traverse City, MI
1992 Explorer Sport
Vehicle Specs
Quoted: 0 Post(s)
its not uncommon for wires to change colors as they pass thru connectors in the harness. not every does change color, in fact most do not, but its not uncommon.
download the appropriate manual from here
http://www24.brinkster.com/sdhartney/linc/linc.htm
which I think will be the 93-94 manual, I think it includes trucks.
this is THE ford CD based manual. it will have all correct wire colors on all sides of the connectors, as well as all the placement info for sensors, and anything else you can think of
Old 12-07-2008, 06:52 AM   #5
scrapper
Maroa Il
1994 ranger xlt
Vehicle Specs
Quoted: 2 Post(s)
(Original Poster)
Thank you I will have to have brother-in law download it. We can't get cable here. I think we are to small of a town. I wonder why some people had post saying that the abs sensor was the speed sensor also. I almost gave up. I will trace it down when it gets a little bit lighter out, warmer also. It will give me a chance to get newer front pegs on my motorcycle. I am almost ready to give in on the cruise, will see what today brings? I seen someone put after market cruise on for only 90. after Christmas sales start soon, maybe I will get lucky? Thanks again.
Old 12-07-2008, 05:54 PM   #6
scrapper
Maroa Il
1994 ranger xlt
Vehicle Specs
Quoted: 2 Post(s)
(Original Poster)
I found it and the temp changes on the overhead console
I should have the rest of the cruise hooked up by the end of the week. Thanks again.
Old 01-15-2009, 08:59 PM   #7
badbachelor
Guatemala City, Guatemala
'07 Ford Ranger 2.8L Dsl
Vehicle Specs
Quoted: 0 Post(s)
Ranger VSS
MichiganBear, do you know where I can tap into the VSS for aftermarket cruise on a 2007 Ford Ranger? Also, where can I get a tach wire? Thanks for any help.
badbachelor is offline   Reply With Quote
Old 01-15-2009, 09:22 PM   #8
BrooklynBay
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
Quoted: 417 Post(s)
I saw that your thread was in the stock 91-94 Explorer section, so I moved it to the Ranger section for you.
BrooklynBay is online now   Reply With Quote
Old 01-16-2009, 08:34 AM   #9
badbachelor
Vehicle Specs
Quoted: 0 Post(s)
oops
Thanks for correcting it.
Old 01-16-2009, 05:26 PM   #10
scrapper
Maroa Il
1994 ranger xlt
Vehicle Specs
Quoted: 2 Post(s)
(Original Poster)
I read on here that all you need is the steering wheel with the buttons and then have to get the computer programed. I found mine in the engine compartment after tracing the wire from the transmisson. Good luck.
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
