#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1991 - 1994 Explorer Ranger Navajo 1st Generation > Stock 1991 - 1994 Explorers
Notices
Stock 1991 - 1994 Explorers For questions related to the base Ford Explorer. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. No modification questions.
Windshield Wipers Stopped Working
Reply
Thread Tools
Old 12-06-2008, 08:54 PM   #1
coalkickin
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I got another issue with my 93 Explorer. The wipers stopped working. I can hear the motor hum when I turn them on, but the don't move. If I move them manually, they return to the down position? I would think that if it were the motor, this would not be the case. If it is the motor, can I swap out the rear wiper motor?
coalkickin is offline   Reply With Quote
( Join the Elite Explorers )
Old 12-06-2008, 09:05 PM   #2
fixxxer
Aurora, Co.
93 XLT 4X4
Vehicle Specs
Quoted: 3 Post(s)
That would be the wiper motor, and no, the front and back motor are not interchangeable. If the motor is humming, it means it is trying to work. You may be able to take it out, disassemble it and clean and re-grease everything. It may be the brushes are just worn down to nothing. I haven't seen any rebuild kits for the wiper motors though so you will be better off replacing it.
__________________
-Larry
93 XLT 4x4
90 Celica GTS
97 Camry
fixxxer is offline   Reply With Quote
Old 12-06-2008, 09:14 PM   #3
coalkickin
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Cost?
Old 12-06-2008, 09:21 PM   #4
fixxxer
Aurora, Co.
93 XLT 4X4
Vehicle Specs
Quoted: 3 Post(s)
At a guess, about $65 but check your local auto-parts stores
__________________
-Larry
93 XLT 4x4
90 Celica GTS
97 Camry
Old 12-16-2008, 05:59 PM   #5
thinkfaster
Galena, KS
2001 Explorer Sport
Vehicle Specs
Quoted: 0 Post(s)
Sorry to thread hijack coalkickin...but i have an 01 explorer and i'm having a similar problem...for starters its 24 degrees F today and my car was covered in light snow...i starte the car and let it idle for about a minute and made sure the wipers were free of ice and when i turned my wipers on they came all the way up and stopped...i turned the wiper switch to the off position but every 30 seconds or so they will try to go back down but they will only move a couple inches...they worked fine yesterday...what could cause this?
__________________
2001 Explorer Sport
1993 Mustang Cobra
1972 Yamaha DS7 250
thinkfaster is offline   Reply With Quote
Old 12-16-2008, 07:08 PM   #6
thinkfaster
Galena, KS
2001 Explorer Sport
Vehicle Specs
Quoted: 0 Post(s)
got it figured out...pulled the wiper linkage cover on the drivers side and my linkage was covered in solid ice...lol...chipped it off and it works like a charm...
__________________
2001 Explorer Sport
1993 Mustang Cobra
1972 Yamaha DS7 250
Old 01-21-2009, 09:00 AM   #7
dickster@rogers.
94 XLT
Vehicle Specs
Quoted: 0 Post(s)
CAN WIPER Pittman arm "CLIP"
I had a problem with my wiper motor & went to the trouble of replacing it before I found it was the ground, [see thread] for details. BUT I lost the CLIP that secures the Pittman arm to the Pittman, TWICE [drop it down past tranny into snow cause my hands were cold] but only found it once. Went to the dealer to get another one.."WOW" THIS "CLIP" A SMALL PIECE OF TIN, SMALLER THAN A DIME , 1/5 THE WEIGHT, MIGHT COST FORD .10 CENTS A HUNDRED,WANTED $24.00 FOR ONE WENT TO THE WRECKERS & GOT ONE FOR THE PRICE OF TAKING IT OFF..."FREE" I`ll find it in the spring & ask $5.00 & it will be a hellofadeal...lol Want install info....E me
dickster@rogers. is offline   Reply With Quote
Old 01-21-2009, 09:04 AM   #8
smbracing
Jackson, OH
1994 Explorer XLT
Vehicle Specs
Quoted: 0 Post(s)
make sure your wiper motor has a good clean ground, sounds like it may be corroded. Even if cleaning the ground doesn't work it's another thing to try and it costs nothing, that solved a similar problem on my '91
smbracing is offline   Reply With Quote
Old 02-04-2009, 04:43 PM   #9
dickster@rogers.
94 XLT
Vehicle Specs
Quoted: 0 Post(s)
Yes, after replacing it, It was the ground! damit.
Old 06-08-2011, 05:24 PM   #10
Garybee
Midland Michigan
98 Eddie Bauer 4D AWD V8
Vehicle Specs
Quoted: 0 Post(s)
i had a problem like this with my wipers, here is the link to my posting http://www.explorerforum.com/forums/...80#post2745880
Garybee is offline   Reply With Quote
Old 07-30-2013, 04:23 AM   #11
lancer525
Augusta, GA
2002 XLS
Vehicle Specs
Quoted: 0 Post(s)
Question
Having a very similar problem in my 2002 Explorer. I replaced the wiper motor with no results. All of the relays and fuses are good, and according to the continuity tester I have (looks like an icepick with a wire coming out the other end) I am getting electricity in the 12-pin plug to the motor. The wipers and washer do not work, and I have absolutely NO idea how to begin to check the wiring, since I cannot see where any of the wires go. There's so much 'stuff' packed in the engine compartment, I can't visually track the wiring.
There is no clicking, no reaction in the motor, no noises, no nothing.
I am literally at my wits' end trying to figure out what this could be, and not being a mechanical-type I don't really have any idea where to even begin to look.
lancer525 is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
