#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
The Absolute Best Way to Find the Factory Door Code on Your 2002 Explorer Sport
Reply
Thread Tools
Old 12-07-2008, 11:44 AM   #1
bfcerny
Omaha, Ne
2002 Sport
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I am creating this post because although there are a lot of posts out there on this, most of them suggest look under the pillar molding, in the jack box, etc. These are not the correct place to find you code on a 2002 Explorer sport.
I have also seen people say to take out the airbag on the 02 sport. This may work, but if you are like me you are not comfortable messing round with the safety system that could save the life of someone in your family or even deploy and and injur you in the removal process.
In my opinion, the following is the best way to find your code and it will literally take 5 minutes even with no mechanical skill.
You need...
Two flat head screw drivers. I used one flat head and an inch and a half scrapper for more surface area.
Take these tools and carefully pry the defrost vent away from the dash. Do this with care so you don't brake the plastic. Use one tool to pull it up and then place the other in the gap created and slowly pry. You should pop the clips right out of the dash. There are about seven of them across the front and one on each side. Due to the angle of the windshield, you will have to start in the middle of the vent for the easiest way to get it started. It can be done from the corners first, but I found the middle to be the best starting point.
Next...remove the vent and set aside.
Now you should have the inner dash exposed. In my opinion, this is much easier and safer than removing the passenger side airbag.
Now raise your passenger side windshield wiper
Now you will need some good sunlight or a flashlight. The offwhite box with the wires leading into it is the location of your code. Point your light into the area and look at the 5 digit code on the top of the box. It will be to the right of the arrow you will see on the left. There should be no mistaking it...it will be 5 large printed numbers by themselves that look like they were deliberately placed there for viewing.
The picture does not work very well for showing the code, but it is right on top of the offwhite box you see in the picture. If you tilt your head you will see it.
Nex just put your wiper down, then replace the vent by carefully lining up the clips to the wholes and giving it a little thump with your palm. Be sure it is lined up correctly before you try to pop it back on so you dont break the clip.
There you go...that's it! Now you can use your door code and not worry about removing your airbag...even though it is easy to remove, I find this way a lot more simple and gives you a lot better piece of mind not having to wonder if you hooked the airbag back up properly or severed a wire in the process.
Hope this helps all of you out there with a 2002 Explorer Sport!
bfcerny is offline   Reply With Quote
( Join the Elite Explorers )
Old 12-08-2008, 11:02 AM   #2
uefear
Jacksonville, FL
2002 Explorer Sport
Vehicle Specs
Quoted: 0 Post(s)
Great post. I have the same year sport as you and I did it by removing three screws in my glovebox and moving my airbag to the side (not unplugging it). Although this does look much easier great post.
__________________
2002 Explorer Sport 4.0L SOHC 2WD
2.0" TT, AAL, WARRIOR Shackles
265/75/16 Dayton Timberline A/T II
Two 12" Diamond Audio D612D2 Subwoofers
Diamond Audio D5 1200.1 Monoblock Amp
Boston Acoustic S35 Speakers
uefear is offline   Reply With Quote
Old 01-02-2011, 01:17 PM   #3
just1me
Pryor, OK
2001 Sport
Vehicle Specs
Quoted: 45 Post(s)
I did the same thing removed the cowl, and it worked great for me as well.
just1me is offline   Reply With Quote
Old 01-04-2011, 12:50 PM   #4
sport01
Kennewick, WA
01Sport
Vehicle Specs
Quoted: 0 Post(s)
Mr. bfcerny,
Do u think it may be the same for 01 Sport? If it is, this seems to be the easiest way to get to the code. I will appreciate your thought.
Ami
Kennewick, WA
sport01 is offline   Reply With Quote
Old 01-04-2011, 04:58 PM   #5
just1me
Pryor, OK
2001 Sport
Vehicle Specs
Quoted: 45 Post(s)
I have a 01 sport so it should be that's where mine was.
Old 02-05-2012, 10:54 PM   #6
Mike's brother
Ithaca, NY
Mike's brother's Avatar
2001 Explorer Sport
Vehicle Specs
Quoted: 12 Post(s)
Great tip!
I've got a late-year 01 Sport, and you just saved me from the terrifying prospect of doing anything with the airbag assembly. Did this, and had my number in 10 minutes. Excellent tip. Thanks.
Mike's brother is offline   Reply With Quote
Reply
Tags
2002, door code, sport
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
