| EF Swag Store | 2013 Ford Explorer | Forums | Elite Membership | Chat Room | My Posts | Reviews | Explorer Photo Gallery |
| 2001-2005 Explorer Sport Trac All questions related to the 2001-2005 Explorer Sport Trac model. |
Thread Tools |
#1 |
Wannabe Elite Explorer
hampton roads, VA
2003 sport trac
03 sport trac seat warmer problem
I have a 2003 sport trac. the driver seat warmer does not heat. the light comes on and stays on but no heat. the passenger side works. at on or about the same time i noticed the rear blower does not blow warm air. the lights come on and the controls still control the front radio, just no warm air? could they be related ?
how do I fix ???? THX |
#2 | |
Elite In Memoriam
Houston, TX
2001 Sexy Sport Trac 4x4
Quote:
I have no clue how to fix the seat. As far as the rear blower, do you feel warm air coming out the dash vents? __________________ John_Rock - Mugshot - Click Here For info on my 2001 Sport Trac 4x4 - 2000 Explorer Limited AWD, 5.0L v8; 4.10 gears, KKM True Rev filter, B&M Tranny Super Cooler, Aux. Tranny Filter, Autometer Tranny & Water temp gauges. Demon4x4.com |
#3 |
hampton roads, VA
2003 sport trac
thanks for helping
Yes the front dash works perfectly. Very warm air comes out of all windshield, dash and floor vents. Because both went out at the same time I honestly thought the rear blower might have an electric heater or something. Thanks again for looking at this !!!!
#4 |
Elite In Memoriam
Houston, TX
Well, think about it. The only controls at/for the rear blower are to control the speed and exit point. Not to control the temperature. Unless an 03 is different from an 01.
#5 |
hampton roads, VA
2003 sport trac
broken seat warmer and back heater
that makes it all the wierder. the dash blows hot air but the back blows out cold ? I guess it must have only been coincidense ( misspelled i know) that it went out at the same time as the seat warmer.... I checked all fuses and they appeared fine. think changing them out may still help?
#6 | |
Wake Forest, NC
2010 ST Ltd
Did you fix the seat?
Quote:
Thanks. |
#7 |
hampton roads, VA
2003 sport trac
seat warmer problems
Nope. The dealer said the "grid" in the seat is probably broken and putting in a new one would be between $300-$600. can't exactly remember what he quoted but he could not assure me that was the problem. I believe him but need more of a gurantee before i spend that money. a friend suggested a $25 heated seat cushion you plug into the lighter. i'm going that route. For that amount of money i could install a moonroof you know.
#8 |
YYC
'01 sport trac
if the seats don't have airbags, you could take them out, or disconnect the connector to the seat heaters.
measure the resistance for the heater coil in the seat. It's pretty well a wire that you put +,- (power) to and the wire heats up. If you measure a low resistance, the element should be ok and you need to check wiring, fuses, switches going to the element, if it's high (open circuit), then the element is broken. __________________ _____________________________ '01 sport trac Yay another post, I'm well on my way to being a post whore! |
| Thread Tools | |
