| Explorer & Ranger Transmissions, Transfer Cases, & Differentials Transmissions, Transfer Cases. A4LD, 4R70W, 4R44E, 4R55E, 5R44E, 5R55E, M5OD, BW 1354, Control Trac, GEM, AWD. Ford 8.8", Dana 35 |
Thread Tools |
#1 |
Wannabe Elite Explorer
Sikeston, Missouri
'97 Sport
Manual transmission issue. It's very difficult shifting into gears.
Ok, just got a 1997 explorer sport (4.0) and was warned it has some shifting issues but not all the time. So yesterday it was shifting fine then all the sudden after i had been driving awhile it was a B!tch to get into first when at a complete stop (stick) so when i got to another stop i tested and it was a b1tch going into any gear from a stop, like i had to push really hard to get it to go in, but it didnt grind at all, or kick back out and it always went it, which i would think if the synchros were going that it would grind/kick out but it didnt do any of that. Also it only does it once the vehicle gets hot, and when i shut the vehicle off it goes into every gear fine, without any hesitation....
Any ideas? anybody ever have a problem like this? Havent really dug into it at all just wondering if anybody else ever experienced anything like this. __________________ 1997 Explorer sport, 2 dr, 5 spd, TT, shackle'D, 31" mud kings on black pro comp rock crawler rims, brown wire mod, lockers to come!-- "crawler" Audio: sony headunit, 2x12" rockford fosgate p3s, rockford fosgate t1000=144.8db, cobra 29, 102" whip. Lighting: 2 hella offroad lights |
#2 |
Boonton, New Jersey
1998 XLT
Sounds like the clutch isn't releasing all the way (drag).
#3 |
Sikeston, Missouri
'97 Sport
thats what i was thinking also, but i was told it could possibly be that the pilot bearing is hanging on the input shaft and not releasing...
#4 |
Aerostar Forum Moderator
Brooklyn, NY
88 89 93 95 96 Aerostars
I've moved, and renamed your thread to help you get more responses.
#5 |
Village Idiot
Trenton, MI
98 ExSport, '00 F-150
I'm with those guys... Either a clutch that's not releasing )could be a leaking slave cylinder or master cylinder or hose), or a pilot bearing siezing on the shaft. Neither one bodes well for it.
Try this: When it won't go into first, shut the engine off, put it in first, and re-start it. It's not a permanent fix, but it may let you limp it around for a bit. -Joe __________________ -98 Explorer Sport, 4.0 SOHC, K&N drop-in, LEMON in progress! -'00 F-150, mucho mods "We need to allow Darwinism take it's course and let the idiots weed themselves out of existance." ~ Rick Horwitz We must believe in free will — we have no choice. ~ Isaac Bashevis Singer I'm not smart, just a resourceful idiot. ~ Me |
#6 |
Panzerfaust™
Utah
96 sport
this is very typical of the mazda 5 speed. mine has been like this for over 60k miles. i put it into first when im coming to a stop, around 5mph. i have had my clutch replaced to try and fix it, but its not the clutch
__________________ Rollover Posse CV Death Toll: 4 33x12.50 ProComp Mud Terrains on 15x8.5 Centerline Rims 6" Suspension, Locked Front/Rear, 1354 Manual T-case ARB Snorkel, and Custom Pinstriping
#7 |
Bartlett Tn
91 Eddie Bauer
Sounds like the slave cylinder is going bad. These transmissions are notorious for that.
#8 |
1995 Explorer XLT
My 95 has had a similar problem but it is not as severe and is more consistent. Manley just have trouble getting into first while at a dead stop. So I pop it into first just before coming to a complete stop. This may work for you to.
#9 |
pineville,nc
97 Explorer Sport
stupid question but did you check the fluid reservior to make sure there was enough brake fluid in it. sounds like the begginings of a slave cylinder problem.good luck.
#10 | |
Sikeston, Missouri
'97 Sport
Quote:
could it still be the slave? __________________ 1997 Explorer sport, 2 dr, 5 spd, TT, shackle'D, 31" mud kings on black pro comp rock crawler rims, brown wire mod, lockers to come!-- "crawler" Audio: sony headunit, 2x12" rockford fosgate p3s, rockford fosgate t1000=144.8db, cobra 29, 102" whip. Lighting: 2 hella offroad lights |
#11 |
So.Calif.(San Fernando Valley)
'94 Ranger, '90 Bronco II
Definitely sounds like the clutch isn't releasing all the way.
A leaky slave is a likely cause, yes (allowing air to enter the hydraulic system from the reservoir). __________________ '90 Bronco II XLT 5" lift (Skyjacker jeep coils), locked D35 & 8.8", 5.13s, double T-case, 35x12.50s & cut fenders '94 Ranger XLT 6" Skyjacker, ARB D44 front, Detroit 8.8" rear, Atlas 4.3, 33s |
#12 |
Sikeston, Missouri
'97 Sport
I just got back from like a 10 minute trip and wow... it is absolutely TERRIBLE now.. idk what changed from the other day.. but now i have to about BREAK my wrist off to get it into first.. and then once im moving its not as bad.. but i still have to pull or push extremely hard to get into any gear... also my check engine light has been on since the vehicle was brand new and the coolant temp gauge hasent worked.. and now the light is off, and the temp gauge is working... but shifting is horrible now..
wtf is going on?? __________________ 1997 Explorer sport, 2 dr, 5 spd, TT, shackle'D, 31" mud kings on black pro comp rock crawler rims, brown wire mod, lockers to come!-- "crawler" Audio: sony headunit, 2x12" rockford fosgate p3s, rockford fosgate t1000=144.8db, cobra 29, 102" whip. Lighting: 2 hella offroad lights |
#13 | |
Battle Ground WA
88 Bronco II
Quote:
__________________ 88 Bronco II EB, 4.0L, M5OD, 4.56s, Aussie Locked 8.8, Aussie Locked D35 w/e-clip eliminator, Manual 1354, 3" PA Body Lift, 34x10.5 Swamper LTBs, Warn Hubs, U-Joint Drive shaft, OBA, Custom bumpers front/rear, 2 1/2" Exhaust w/flowmaster 40 series. 95 Dakota Sport CC, 5.2, 5-Spd(Hurst), 4x4, M1, HS 1.7 RR's, Aero Turbine 3030/Side Exit, 50mm TB, 30x9.50s on 15x8 Ultra 50 Series, 3.55s. |
#14 |
Village Idiot
Trenton, MI
As already mentioned... You likely have an issue with the clutch actuation mechanism... be it a hydraulic leak, or a bad master or slave cylinder, the problem is not going to heal itself and will only get worse the longer you let it go. Now, in addition to your initial hydraulic issue, you're putting excessive wear on your synchros and other internal parts of the transmission itself by trying to force it into gear when it won't go. If you EVER need to use excessive force to get a transmission to engage, there's something very wrong, and delaying the repair will only make it worse!
#15 |
Sikeston, Missouri
'97 Sport
Ok, just got it to a shop yesterday to get the problem fixed, he drove it and said that its seems like a classic symptom of the slave cylinder being bad. He said that its a 6 hour job to get the transmission out. He said with labor, parts, fluids it will be $487 to do.
Does this sound like a reasonable price to replace the slave??? __________________ 1997 Explorer sport, 2 dr, 5 spd, TT, shackle'D, 31" mud kings on black pro comp rock crawler rims, brown wire mod, lockers to come!-- "crawler" Audio: sony headunit, 2x12" rockford fosgate p3s, rockford fosgate t1000=144.8db, cobra 29, 102" whip. Lighting: 2 hella offroad lights |
#16 |
Killeen, Tx
97 Sport 3 Door 4.0 SOHC
Mine has problems with first and second, mostly being second. And grinds on reverse, all the other gears work fine though. Its at 160k, im assuming the tranny is original.
#17 |
ELITE BRONCO2ERER
Crawlorado
B2 Mod
if you are replacing the slave cylinder you better damn well be putting in a new clutch and turning the flywheel
Clutch is CHEAP $487 is VERY fair, get it in writing and make sure it includes a new clutch, I have seen it double by the time they are done clutch job = new slave cyl and throw out bearing new clutch pack (driven disc, pressure plate) new pilot bearing turn the flywheel + labor 6 hours is about right, although I can do it in 4 myself with hand tools, I would expect a competent clutch shop to be able to do the full thing on a 4x4 in 3-4 hours max Clutch is usually $500-1000 so your price seems very fair IF IT INCLUDES THE NEW CLUTCH I like the LUK gold series clutch or centerforce also your 5 speed may need a rebuild soon, many times the clutch is replaced and its still hard to get in the gears = synchros
__________________ 96 Explorer daily driver build-1996 XLT 5.0L AWD to 4x4 conversion complete on 33's 88 BII 5.0L conversion - BII 5.0l drivetrain thread My Bronco II - 1988 Bronco II 4x4 V8 on 35's - registry and updates Wifes 07 FJ build - 2007 FJ cruiser locked and lifted |
#18 |
Sikeston, Missouri
'97 Sport
No, $487 is to replace the slave cylinder, he said nothing about the clutch. The transmission shifted FINE, then the next day i couldnt get it into gear. im Sure the transmission is fine.
#19 | |
South Redondo Beach, CA
'97 Explorer Sport Manual
Greetings, I have exactly the same issues even with a new clutch just installed and the internals check out. It's a beast to get into gear when it doesn't want to go; warmed up. The transmission guys said everything looks good, gears and all. And there was no evidence of fluid leaks. I'm wondering if maybe it's something in the shift linkage that hangs up, otherwise I've not a clue. This is my biggest complaint with my otherwise reliable lil buddy. Any ideas? I'm having it rechecked next week. And if a solution comes forth then for just $19.95 and a free Turnip Twaddler, no make that two Turnip Twaddlers, plus free shipping I'll send you the solution.
enjoy the weekend, Will Quote:
__________________ Slick Willie ~One_Crafty_Character~
#20 |
Surrey, B.C.
'91 explorer, '88 bll
my '91's slave is leaking slowly, i learned to put it in neutral while at a stop light or in slow traffic to ease the pressure off the hydraulics. instead of having to top up the reservoir with a couple ounces of brake fluid every week i now go about 3 weeks. eventually it will have to be done.
my '88 bronco ll has 389,000 kilometers on it and it still has the original master and slave unit in it. |
| Thread Tools | |
