MDub
- August 26, 2008
- Silverthorne, CO
- 99 XLT Flex Fuel
I have had this problem for over 3 years and 50,000 miles now and it is really annoying.
When it's below freezing outside and I go to start my truck I can feel the clutch pedal is a little stiff. Then when I put it in gear and let out the clutch a little bit, I can hold the pedal at about 1 inch off the floor and it acts like I have let the clutch out all the way. When I depress the pedal again it does not fully disengage the clutch and the stick is stuck in gear, I put my foot on the brake and stall the engine. Now I have leaked about 1/4 of the reservoir of clutch fluid, and the clutch has no resistance until about 1 inch off the floor.
Then I fill up the reservoir, pump up the pedal, and go. I'll be good for the whole day (unless it's about -10 in which the problem can repeat in a few hours). Next morning - same problem.
I talked to a guy at a tranny shop when it first happened and he said it's possible the o-ring seals are shrinking when its cold and allowing fluid to pass by. Three times it has drawn air back and I have had to bleed the clutch in the nearest parking lot.
Sorry for the long post. Has anyone else ever experienced anything like this? What can I do short of replacing the slave cylinder?
Thanks for all your ideas!
Mike
Mike
