Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Explorer - Ranger Interior Accessories
Notices
Explorer - Ranger Interior Accessories Seating, Neons, Custom Upholstery, Headliners, Carpet, Console, etc...
2002 door panel removal
Reply
Thread Tools
Old 12-22-2008, 10:33 AM   #1
flyman
Little Rock
2002
Vehicle Specs
(Original Poster)
How do you remove the front door panel on a 2002 explorer
flyman is offline   Reply With Quote
Old 12-30-2008, 01:47 PM   #2
jluv
DFW, TX
'04 XLS
Vehicle Specs
1. Remove the two (or maybe 3) small screws at the very bottom of the door panel.
2. The piece with the window/lock switch buttons pries out by putting your fingertips between the top edge and the panel itself and pulling back and over away from the panel.
3. Once that's loose, the piece below that that goes around the door handle pops out. Set aside.
Unplug the piece with the switches and set aside.
4. There is now one more screw behind those pieces you just removed. Take it out.
5. Now lift up on the panel and it will slide up about an inch and then come off. On the driver's side you will still have a plug to undo where the power mirrors hook up to the switch.
I've done it a hundred times, but it's been a few months. You may have to reverse steps 2 and 3. Those pieces snap into the door and hold onto each other. Without being down in my truck right this second I cannot be sure which one loosens up first, but it should be obvious once you get started.
Just remember - once you have the screws and those two pieces removed, be sure to lift up on the panel. It doesn't just "pop out" like a lot of other panels.
jluv is offline   Reply With Quote
Old 02-22-2009, 11:26 AM   #3
jhard
Toronto, Ontario
'04 Limited
Vehicle Specs
A little old, but for anybody else interested here's a couple PDF's with pictures and instructions for removing the Front and Rear door panels.
Front:
http://rapidshare.com/files/20123833...oval.Guide.pdf
Rear:
http://rapidshare.com/files/20123846...oval.Guide.pdf
jhard is offline   Reply With Quote
Old 02-21-2011, 09:07 AM   #4
F15E_WSO
Washington DC area
2002 XLT; 2001 Exp Sport
Vehicle Specs
Quote:
Front:
Rear:
Does anyone know if this is basically the same for a 2001 Sport? And if NOT a link or other thread for 2001 Sport door panel removal?
F15E_WSO is offline   Reply With Quote
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
