Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer 3rd Generation > Stock 2002 - 2005 Explorers
Notices
Stock 2002 - 2005 Explorers Questions related to non-modified 2002 - 2005 Explorers and Mountaineers. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. Sport Trac and Sport use the 1995-2001 forum.
Ford Explorer 2004 Overheating/No heat
Reply
Thread Tools
Old 12-22-2008, 11:51 PM   #1
ccarr10488
riverside, ca
2004 explorer eddie bauer
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
We have just replaced the radiator cap, fan clutch, water pump and thermostat in my 2004 ford explorer and it is still overheating. The radiator was also flushed. In addition there is no heat coming out of the heater. I don't know if it related, but the air does not blow out of the inside vents all the time. It is intermittant. It appears the water/coolant is not always flowing as it should. Sometimes it appears to flow normal and sometimes it doesn't. The car overheated when the heater vents were changed (heat to feet, face, defrost, etc) and when the temp was raised and lowered. We are at a loss. Any ideas?
ccarr10488 is offline   Reply With Quote
( Join the Elite Explorers )
Old 12-23-2008, 02:25 AM   #2
Dopler174
Official Welcome Committe
Greensboro, NC
Dopler174's Avatar
1993 XLT 4X4
Vehicle Specs
Quoted: 0 Post(s)
It sounds like you have thermostat issues.
Dopler174 is offline   Reply With Quote
Old 12-23-2008, 08:45 AM   #3
tv4fish
Minnesota
2007 EB V8 & 2002 EB V6
Vehicle Specs
Quoted: 1 Post(s)
I agree w/Dopler - I would take it back to the shop that did the work, take off the radiator cap and see if you DO have any circulation.
tv4fish is offline   Reply With Quote
Old 12-23-2008, 08:51 AM   #4
Russ in CT
Milford, CT
'99 XLT
Vehicle Specs
Quoted: 0 Post(s)
Its overheating as in steam pours out, or is it just the gauge that says its overheating? Are there actual overheating symptoms besides just the gauge? (maybe its just the sending unit or an electrical problem with the gauge?)
Somebody else suggested the thermostat, even though you already replaced it (new ones can be bad, too). So to verify this, you can try the trick of running without a thermostat. If it still overheats then, that wasn't the problem (you can also try boiling the thermostat in a pan of water on the stove. You see it pop open well before the water boils. You can use a Turkey thermometer to make sure its at the right temp.
Also, you can make sure you have decent water flow through the block by getting it warm enough for t-stat to be open, then disconnect upper hose from rad and start it back up again (have a bucket or sumthin' to catch the fluid).
__________________
'99 XLT 4x4 SOHC 4.0
Russ in CT is offline   Reply With Quote
Old 12-23-2008, 09:21 AM   #5
xtoolmaker
orlando florida
2003 xls
Vehicle Specs
Quoted: 0 Post(s)
Also check the coolant expansion tank cap. Make sure it is pressure tested.But if you are getting no heat sounds like the thermostat is faulty.Check the oil to see if it is milkey could also be head gasket blown.Though that is unlikley.
xtoolmaker is offline   Reply With Quote
Old 12-23-2008, 02:24 PM   #6
ccarr10488
riverside, ca
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Ok, I tested the thermostat and it tested good. Also checked the tempurature in the water that I tested it in. We watched the circulaton and again, for the most part it appears to be circulating as it should. While we were watching the circulation, my husband was also in the car to see if any heat was coming out of the vents. As he was playing with the heater controls, the tempurature went into the red. (not sure if it's related). Also one thing, while we were testing it, after the car started to overheat, we would have to fill the plastic reservoir with water because it was being sucked up. I don't understand where it was going so fast. THere is nothing leaking. Another thing, again not sure if it's related, when I accelerate and sometimes even when I don't, the air vents from inside of the car hardly blow out any air. I also was convinced that it was the thermostat but it tested as it should.
Old 12-23-2008, 02:25 PM   #7
ccarr10488
riverside, ca
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I forgot to add, there are no signs of a blown head gasket. We did all of the testing for this and everything appears OK. A;so, the car is actually overheating, it's not just the reading.
Old 12-23-2008, 04:20 PM   #8
xtoolmaker
orlando florida
2003 xls
Vehicle Specs
Quoted: 0 Post(s)
The coolant is boiling away do to the overheating.This does sound like a cracked cylinder wall or blown head gasket.take it to the shop that did the work[unless you did it yourself].If you have the same problem now as you did before the parts were added there is something else wrong.If you keep messing with it you will end up with a cracked block or blown gasket.
Old 12-23-2008, 04:47 PM   #9
Nytroman
Lackawanna, New york
04 XLT 4.6L
Vehicle Specs
Quoted: 0 Post(s)
you might have some serious air pockets in the system after you all the work you put in, did you release the air out of the system? if your truck is like mine, you also have rear heat, thats alot of lines, and alot of air can be trapped in there causing airpockets and thus not letting the thermostat open, thus overheating
__________________
My Truck - http://www.cardomain.com/ride/3080567
Nytroman is offline   Reply With Quote
Old 12-29-2008, 08:52 AM   #10
xtoolmaker
orlando florida
2003 xls
Vehicle Specs
Quoted: 0 Post(s)
Any update on your problem?
Old 01-01-2009, 04:36 AM   #11
ccarr10488
riverside, ca
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Old 01-01-2009, 08:00 PM   #12
ccarr10488
riverside, ca
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
IT'S Fixed!!!
Wow, it's fixed. They bypassed the heater core and it ran fine. They purged the air prior to hooking it back up. Then they hooked it up so antifreeze would go to the heater core and come out the other side. Anyways, the bottom line is it must have been air pockets that was causing this continuous issue after replacing everything that we did. Thank you everyone for your input.
Old 01-02-2009, 12:23 PM   #13
xtoolmaker
orlando florida
2003 xls
Vehicle Specs
Quoted: 0 Post(s)
Nytroman hit the nail on the head.
Old 01-02-2009, 03:26 PM   #14
Nytroman
04 XLT 4.6L
Vehicle Specs
Quoted: 0 Post(s)
thats great news! thx Toolmaker.
__________________
Old 10-27-2012, 12:27 PM   #15
tru1
2004 ford explorer limitd
Vehicle Specs
Quoted: 0 Post(s)
2004 ford explorer purge
Quote:
so how would i purge the system im having the same problem
tru1 is offline   Reply With Quote
Old 02-17-2014, 04:25 PM   #16
kaync09
2004 Ford Explorer
Vehicle Specs
Quoted: 0 Post(s)
2004 Ford Explorer Purge
I am having the same thing going on with my explorer too Nytroman please share how to fix..........I am a female so everytime I take it to a mechanic their trying to get me to fix 18 other things that have nothing to do with the problem I'm trying to take care of!
kaync09 is offline   Reply With Quote
Old 04-19-2016, 05:22 PM   #17
camodiva
Florida
2004 Explorer XLT
Vehicle Specs
Quoted: 0 Post(s)
Thank you so much for this info. Appreciate it.
__________________
" Take a kid hunting, and you won't have to hunt for the kid."
camodiva is offline   Reply With Quote
Reply
Tags
no heat, overheating
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
