Today my 99 ford exploder refused to work wen put in reverse, it was just slipping what cut be wrong
It is a 4WD, there have not been any problems until this day.
I am a millwright from trade and have the habit to lisen and care for my car's
Thank you for the welcome note
Yes today I was test driving it has all gears 1-4 in top gear with 80 kmh the rpm is 1500 with 100 kmhrs 2100 rpm this is nomal operation rpm spped (I did test it slow at first this is end result) the gear brake is working as well as well as 4 WD high and low + the over drive forward only as well.
Reverse is the only thing not working
A broken shift fork has been known to cause a no reverse situation. BTW, do you know if your brake lights are lighting up when you put it into reverse?
Ahh! Thanks BB. Not sure why that would only affect reverse as it shouldn't really care what direction the input shaft is spinning, but I'll defer to you on that.
