#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
wont go in 4wd low
Reply
Thread Tools
Old 12-27-2008, 12:43 PM   #1
jamienfld
2001 explorer sport
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
wont go in 4wd low
never used 4wd in long while anyway i cant get it to go into 4wd low. It is a explorer sport 2001 goes in 4wd high thats all. If i put it in 4wd high and switch to low the 4wd high light still says on any ideas
jamienfld is offline   Reply With Quote
( Join the Elite Explorers )
Old 12-27-2008, 01:32 PM   #2
cybergasm
B
Humboldt Ks
cybergasm's Avatar
1997 Mountaineer 5.0
Vehicle Specs
Quoted: 0 Post(s)
Ok but is the 4 lo light coming on when you push the button? cause if i am not mistaken both lights should lit when you are in 4 lo.
cybergasm is offline   Reply With Quote
Old 12-27-2008, 07:20 PM   #3
Andy96XLT
Branchburg NJ, Bethlehem PA
96 XLT
Vehicle Specs
Quoted: 1 Post(s)
are you in neutral before switching it to 4WD low? I believe it will only switch over to the low gears if you are in neutral.
__________________
-Andrew
96 XLT 4.0 OHV-TT, AZ shackles, K&N intake, Borla exhaust
04 EB 4.0 SOHC new toy hauler vehicle
Andy96XLT is offline   Reply With Quote
Old 12-27-2008, 07:26 PM   #4
IZwack
Moderator Emeritus
Germantown, MD
IZwack's Avatar
1998 Ford Explorer
Vehicle Specs
Quoted: 2 Post(s)
And more importantly, do you need 4LO?
What are you trying to accomplish with LO range? Because all it does is give you torque and slightly more throttle control but only in off-road situations.
__________________
...how'd the moon get there, how'd the moon get there?
IZwack is offline   Reply With Quote
Old 12-27-2008, 09:06 PM   #5
Spdrcer34
Bremerton, WA
1992 Explorer XL
Vehicle Specs
Quoted: 10 Post(s)
Your X must be in Neutral, and STOPPED for it to shift into and out of 4Lo.
4Lo is good for crawling out of a hole, or over a rock.....NOT for using on the street. You can go about 20-25mph MAX in 4Lo w/ 3.73's and stock tires.
Ryan
__________________
1992 Ford Explorer XL - with a few bolt ons...
Spdrcer34 is offline   Reply With Quote
Old 12-27-2008, 10:08 PM   #6
adub98
Olympia/Ellensburg, WA
1998 Ford Explorer XLT V6
Vehicle Specs
Quoted: 1 Post(s)
I use low anytime I'm towing someone out of a ditch. We have got a lot of snow the last week and have pulled three people so far. I use low range because it takes a lot of stress off my already weak transmission.
__________________
1999 Explorer Eddie Bauer 5.0 AWD all stock 83k miles.
adub98 is offline   Reply With Quote
Old 12-27-2008, 10:44 PM   #7
Hoppy
Ontario, Canada
2000 XLS 4x4 SOHC
Vehicle Specs
Quoted: 0 Post(s)
You can roll ever so slowly to go into or out of 4 Low.
My 00 ex does not illuminate both 4 hi and 4 low lights when in 4wd. Only one light is on at a time. It cannot be in both ranges at the same time.
__________________
1986 Bronco II XLT 4x4
1992 Explorer Sport 4x4
1997 Explorer XL 4x4 (Killed by an impaired driver)
2000 Explorer XLS 4x4
Hoppy is offline   Reply With Quote
Old 12-27-2008, 10:54 PM   #8
IZwack
Moderator Emeritus
Germantown, MD
IZwack's Avatar
1998 Ford Explorer
Vehicle Specs
Quoted: 2 Post(s)
Quote:
If you're talking about not having the transmission in Neutral or Park, then I wouldn't do it -- the gear that slides into the planetary (and the planetary itself) has very sharp angled teeth. If the driveshafts and the transmissions are not at the same RPM (that is to say that the transmission is in one of the forward gears or reverse), you're going to be grinding those teeth down. Its like shifting an unsynchronized manual transmission from a dead stop into 1st gear without using the clutch and not having a tachometer.
__________________
Old 12-28-2008, 08:47 AM   #9
Hoppy
Ontario, Canada
2000 XLS 4x4 SOHC
Vehicle Specs
Quoted: 0 Post(s)
I stand corrected. I thought I read somewhere that you could be rolling very very slow to shift into 4 Low somewhere. My manual for my 2000 ex does not say this. Maybe it was in my 97 manual.
I do not do this anyway, I always come to a complete stop, but it will not shift into or out of 4 Low unless it is in neutral, no other position will it shift.
__________________
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
