Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Explorer & Ranger Transmissions, Transfer Cases, & Differentials
Notices
Explorer & Ranger Transmissions, Transfer Cases, & Differentials Transmissions, Transfer Cases. A4LD, 4R70W, 4R44E, 4R55E, 5R44E, 5R55E, M5OD, BW 1354, Control Trac, GEM, AWD. Ford 8.8", Dana 35
Flashing O/D Light
Reply
Thread Tools
Old 12-28-2008, 10:21 AM   #1
Richie18
2009 STA White Suede
Vehicle Specs
(Original Poster)
Flashing O/D Light
I've tried searching for my issue but have not found anything, if there already is a thread point me to it.
I'm gettingt he stupid flashing O/D light, along with the CEL. I read the DTC codes and they are P0740 and P0743. I understand this refers to the torque converter clutch circuit malfunction and torque converter clutch electrical.
What is happening is the car is locked into overdrive. The transmission will stall the engine unless i manually shift into first gear. I've been advised it may be a blown fuse, i am going to check that out. If anyone has any knowledge on the issue i would appreciate any info.
Richie18 is offline   Reply With Quote
Old 12-28-2008, 10:24 AM   #2
BrooklynBay
Aerostar Forum Moderator
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
It could be a problem with the solenoid block or the valve body. How many miles does it have? Do you have the 5R55W (no dipstick)?
BrooklynBay is offline   Reply With Quote
Old 12-28-2008, 10:52 AM   #3
Richie18
Vehicle Specs
(Original Poster)
I have 2003 Sport Trac with 5R55E, with a transmission dipstick. I have 42,000 miles.
I checked the overdrive fuse and it is not blown.
I haven't had any other tranny issues as of yet, not even the 2-3 flare.
What are my options for repair is this a possible DIY with a lift and shop available.
Old 12-28-2008, 06:25 PM   #4
BrooklynBay
Brooklyn, NY
Vehicle Specs
The 5R55E has individual solenoids so you wouldn't have to replace a block. The sticky thread called the 5R55E valve body rebuild diary has more information.
Old 12-29-2008, 08:22 AM   #5
Richie18
Vehicle Specs
(Original Poster)
Thanks for the help.
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
