Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Ranger - Mazda B-Series Forum > Ford Ranger - Mazda B-Series Forum
Notices
Ford Ranger - Mazda B-Series Forum Ford Ranger and Mazda B Series forums. The Mazda B2300 B3000 and B4000 are clones of the Ford Ranger, with all systems the same. The only differences are trim and a few body parts. This forum discusses Ford Ranger and Mazda B series specific issues. Owners of the older Mazda B2000 B2200 and B2600 are welcome as well.
93-97 Ranger Schematics / Diagrams
Reply
Thread Tools
Old 12-28-2008, 02:19 PM   #1
Tbars4
Offroad/Fitness Moderator
anaheim hills,california
Tbars4's Avatar
95 ranger 4x4/ 91 X 4x4
Vehicle Specs
Quoted: 300 Post(s)
(Original Poster)
...I will update these as I get them in...
...90's service manual cd
http://www24.brinkster.com/sdhartney/linc/linc.htm
...Autozone's Vehicle Repair Guide
http://www.autozone.com/servlet/UiBr...pair_guide.jsp
...BW-1350-1354 transfer case
http://www.transtarindustries.com/ca...oad.asp?ID=648
..Ford door Sticker Decoder...
http://www.ford-trucks.com/article/i...r_Decoder.html
...Ford Transmission Spotters Guide..
http://www.ford-trucks.com/article/i...ers_Guide.html
...PATS Key System Programming..
http://www.ford-trucks.com/article/i...ogramming.html
...Owners Guides..
https://www.fleet.ford.com/maintenan...ls/default.asp
...Multi-Function Switch...
__________________
I have Rocks in my head. What's in yours?
'95 ranger xl 4x4 2.3L std cab, 3 sticks Ranger RegistryThe Squirrel
'91 4x4=To much to list, much more to add.. Project "X" and more Pics & Mod's List
How to: Wheels,Tires, & Lifts...
Buy Explorerforum.com Items here
Tbars4 is offline   Reply With Quote
( Join the Elite Explorers )
Old 12-28-2008, 02:20 PM   #2
Tbars4
Tbars4's Avatar
Vehicle Specs
Quoted: 300 Post(s)
(Original Poster)
Dana 35...
__________________
Old 12-28-2008, 02:21 PM   #3
Tbars4
Tbars4's Avatar
Vehicle Specs
Quoted: 300 Post(s)
(Original Poster)
...For more detailed information on locking manual hubs, go here...
http://www.explorerforum.com/forums/...d.php?t=232754
...For links to all your 4wd or auto/manual hub problems, Tires, wheel, and lift questions, go here..
http://www.explorerforum.com/forums/...d.php?t=216933
...The vacuum disconnect axle locking system was used on 1998-99 Ranger models only...
__________________
Old 12-28-2008, 02:29 PM   #4
Tbars4
Tbars4's Avatar
Vehicle Specs
Quoted: 300 Post(s)
(Original Poster)
...This is the Dana 28 info for the Dana 35 Hybrid...Use at your own risk as I have seen a couple variations on the Hybrid axle and the info pertaining to it...
...Dana 28/35 Hybrid...You can tell a Dana 35 Hybrid by it's smooth pumpkin (no Ribs)..
__________________
Old 12-29-2008, 04:44 PM   #5
Tbars4
Tbars4's Avatar
Vehicle Specs
Quoted: 300 Post(s)
(Original Poster)
..Be sure to ALWAYS verify in your Haynes Manual first..
...This is the torque specs for a 94 Ranger, 2.3L
Clutch Housing to Engine Block Bolt 28-38 ft.lb
Clutch Housing to Transmission Nut 30-40 ft.lb
Pressure Plate to Flywheel Bolt 15-24 ft.lb
Insulator to Crossmember 71-94 ft.lb
Insulator to Transmission 60-80 ft.lb
Starter to Clutch Housing 15-20 ft.lb
Flywheel to Crankshaft Bolts 56 - 64 ft-lbs
Cylinder Head Torque in 2 steps [1st (50 - 60 ft-lbs), 2nd (80 - 90 ft-lbs)]
Main Bearing Bolts Torque in 2 steps [1st (50 - 60 ft-lbs), 2nd (80 - 90 ft-lbs)]
Rod Bearing Bolts Torque in 2 steps [1st (25 - 30 ft-lbs), 2nd (30 - 36 ft-lbs)]
Crankshaft Pulley Bolts 100 - 120 ft-lbs
Intake Manifold Torque in 2 steps [1st (5 - 7 ft-lbs), 2nd (14 - 21 ft-lbs)]
Exhaust Manifold Torque in 2 steps [1st (5 - 7 ft-lbs), 2nd (16 - 23 ft-lbs)]
...For a 2.9L...
Flywheel to crank shaft tourqe is 47-52ftlbs
Main cap for the crankshaft is 65-75ftlbs
Connecting rod nut is 19-24ftlbs
..For a 4.0L...
Flywheel to crank tighten to 10 ft-lbs in an alternating pattern then to 50-55 ft-lbs in a cross pattern and use locktite.
Pressure plate to flywheel 15-24 ft-lbs in an alternating pattern and work all the bolts down a little at a time until the pressure plate is all the way down and then torque them.
...Mazda 5 speed
Mitsubishi 5 speed
Ranger/Explorer/Mountaineer 1991-1999
The VSS is located half-way down the right-hand side of the transmission assembly.
__________________
Old 01-01-2009, 07:31 PM   #6
Tbars4
Tbars4's Avatar
Vehicle Specs
Quoted: 300 Post(s)
(Original Poster)
..92 Ranger 2.,3L-2.9L Engine wiring
__________________
Old 01-01-2009, 08:06 PM   #7
Tbars4
Tbars4's Avatar
Vehicle Specs
Quoted: 300 Post(s)
(Original Poster)
89 Ranger/BII
...2.3L-2.5L...
__________________
Old 01-17-2009, 07:25 PM   #8
Tbars4
Tbars4's Avatar
Vehicle Specs
Quoted: 300 Post(s)
(Original Poster)
Vacuum Diagrahms
91-94
_______________________________________________________________________________________
95-99 2.3L and 2.5L
95-99 3.0L
95-99 4.0L
__________________
Old 02-07-2009, 05:27 PM   #9
Tbars4
Tbars4's Avatar
Vehicle Specs
Quoted: 300 Post(s)
(Original Poster)
...Bumpin for the new guys...
__________________
Old 02-19-2009, 09:11 PM   #10
Tbars4
Tbars4's Avatar
Vehicle Specs
Quoted: 300 Post(s)
(Original Poster)
...bumpin for the Ranger owners...
__________________
Old 03-06-2009, 06:43 PM   #11
4byer
Minnesnowda
89 Ford ranger
Vehicle Specs
Quoted: 0 Post(s)
thank you for this thread...
4byer is offline   Reply With Quote
Old 03-06-2009, 09:27 PM   #12
Tbars4
Tbars4's Avatar
Vehicle Specs
Quoted: 300 Post(s)
(Original Poster)
...Your welcome...
...Just curious but, what did you find useful???
__________________
Old 03-28-2009, 05:39 PM   #13
Tbars4
Tbars4's Avatar
Vehicle Specs
Quoted: 300 Post(s)
(Original Poster)
...bumpin for the new questions being asked..
__________________
Old 03-28-2009, 09:32 PM   #14
97DangerRanger
south jersey
97 XLT Ranger
Vehicle Specs
Quoted: 0 Post(s)
you are the man!! you have alout of info iv bin looking for on here thank you so much but i do have one ?? and if you could PM me the anser it would be grate. im going to be swaping out my electrec t-case(1354) for a manual(1354) and in the pics on the one link it looks like it yousis a diftind drive shaft, is this true? and if so what tip dose it youse. thank you very much!!!
97DangerRanger is offline   Reply With Quote
Old 03-28-2009, 10:13 PM   #15
Tbars4
Tbars4's Avatar
Vehicle Specs
Quoted: 300 Post(s)
(Original Poster)
...You might find some really good answers in one of these 2 threads...If not, that would be where I would ask that question...
http://www.explorerforum.com/forums/...highlight=1354
...I am also getting ready to add some more pics to this thread as in vacuum lines and such...
__________________
Old 04-06-2009, 11:28 AM   #16
INOV8TN
Salisbury, NC
1994 2.3 L 2WD Ranger
Vehicle Specs
Quoted: 0 Post(s)
Smile You are da man!
Great stuff!
INOV8TN is offline   Reply With Quote
Old 04-06-2009, 04:32 PM   #17
Tbars4
Tbars4's Avatar
Vehicle Specs
Quoted: 300 Post(s)
(Original Poster)
...It's a work in progress....I am trying to add it as I go and before I need to use it on my own vehicles...
__________________
Old 04-08-2009, 12:01 PM   #18
dae06
Minnesota
ranger-1991 and 1995
Vehicle Specs
Quoted: 0 Post(s)
Does anyone have the vacuum line diagram for a 1997 4.0 liter. I found 2 unused vacuum lines coming out of the intake manifold and my HVAC has defrost only. I can not for the life of me find where these go.
http://home-and-garden.webshots.com/...35451125JJRqyQ
dae06 is offline   Reply With Quote
Old 04-08-2009, 12:14 PM   #19
Tbars4
Tbars4's Avatar
Vehicle Specs
Quoted: 300 Post(s)
(Original Poster)
...I just updated post #8 with Ranger vacuum diagrahm's...
__________________
Old 04-08-2009, 12:47 PM   #20
dae06
Minnesota
Vehicle Specs
Quoted: 0 Post(s)
Thanks.
Can anyone tell me where the 2 loose ends go from my picture and the diagram in post 8?
4.0 liter
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
