Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Explorer & Ranger Transmissions, Transfer Cases, & Differentials
Notices
Explorer & Ranger Transmissions, Transfer Cases, & Differentials Transmissions, Transfer Cases. A4LD, 4R70W, 4R44E, 4R55E, 5R44E, 5R55E, M5OD, BW 1354, Control Trac, GEM, AWD. Ford 8.8", Dana 35
Differential fluid change.
Reply
Thread Tools
Old 12-30-2008, 05:57 AM   #1
akcrxnj
Ogdensburg, New Jersey
99 Sport
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
All - I was searching the site looking for a how-too in regards to changing out the fluid in the front and rear diffs. Does anyone know if this information is posted up on forum? Is the fluid change hard to do? I have a 99 explorer sport 4wd. Thanks.
akcrxnj is offline   Reply With Quote
( Join the Elite Explorers )
Old 12-30-2008, 07:01 AM   #2
cybergasm
B
Humboldt Ks
cybergasm's Avatar
1997 Mountaineer 5.0
Vehicle Specs
Quoted: 0 Post(s)
i believe the front is gonna the bigger PITA since it's stuffed in the front end but basically for either end you remove the bolts from the covers except for a couple at the top just loosen them get your drain bucket underneath and crack open the covers and let it drain out. then remove the covers reseal em bolt then back on and refill the diffs.
about all there is to it not entirely difficult just time consuming.
Dunno about any stickies on here but I sure someone will be along to post one for ya.
cybergasm is offline   Reply With Quote
Old 12-30-2008, 09:14 AM   #3
Cobraguy
Phoenix...Greatest City on Earth
Cobraguy's Avatar
1995 EB & 1999 EB 5.0
Vehicle Specs
Quoted: 13 Post(s)
For the rear, remove the cover, drain, clean, reseal, and fill.
For the front, purchase a suction gun, remove the fill plug, fish the hose to the bottom of the housing, and suction the gear lube out. Be sure to have the lube warm first. Alternatively, there are many shops that have a machine that is designed to do all that very easily. Call and ask if they have the capability to service a diff by sucking the old oil out.
__________________
http://banners.wunderground.com/weat...AZ/Phoenix.gif
Quote:
Originally Posted by four0sport
she is a girl, there are no answers, only more questions!
Cobraguy is offline   Reply With Quote
Old 12-30-2008, 09:33 AM   #4
Four0Sport
West Virginia
1993 2dr
Vehicle Specs
Quoted: 41 Post(s)
x2 on the suction gun. i also used it to fill the rear with fluid, the fill plug on the 8.8 is in a weird spot that makes working on it while laying on your back on gravel kind of a pain.
__________________
1993 Explorer Sport, Narrowed HP44 SAS, UA2015 survivor
Four0Sport is offline   Reply With Quote
Old 12-31-2008, 05:09 PM   #5
akcrxnj
99 Sport
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Thanks all - I have a suction gun and will probably be going that route. One last question I had was what type of gear oil should be used in the diffs?
Old 12-31-2008, 05:17 PM   #6
IZwack
Moderator Emeritus
Germantown, MD
IZwack's Avatar
1998 Ford Explorer
Vehicle Specs
Quoted: 2 Post(s)
Quote:
Page 248-249 of your owners manual.
Or if you dont have one, download a PDF copy from:
http://www.motorcraftservice.com/?li.../99expog1e.pdf
__________________
...how'd the moon get there, how'd the moon get there?
IZwack is offline   Reply With Quote
Old 12-31-2008, 06:09 PM   #7
Four0Sport
West Virginia
1993 2dr
Vehicle Specs
Quoted: 41 Post(s)
dont they call for 75/140 synthetic with friction modifier? its expensive, i just use valvoline 80/90 and a tube of friction modifier.
__________________
Old 01-01-2009, 09:48 AM   #8
akcrxnj
99 Sport
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I was looking at the manual and it states that the front should get 80w90 and the rear either 80w90 or 85w140 + friction modifiers. I noticed some threads where it looks like some forum members just went ahead and used 85w140 in both front and rear. I was thinking of doing this as it would be convenient to use the same oil in both diffs. Is there an issue with running the 85w140 in both front and rear? Lastly I noticed that Royal Purple makes a gear oil which states you do not need any additional friction modifiers.
Royal Purple Gear Oil - http://www.royalpurple.com/gear-oil.html
Old 01-01-2009, 10:03 AM   #9
Cobraguy
Cobraguy's Avatar
Vehicle Specs
Quoted: 13 Post(s)
I have seen posi chattering from Royal Purple in our Cobras. I would use the modifier with it if it were me. You can also add it later if you need it and try it like it is. As to what oil, you are on your own if you deviate from factory recommended fluids. However, let's get real. We all know there are outstanding products we can use. Synthetics for example. I'm not going to tell you to use 85W-140 in the front diff. What I am going to say is there are Explorers running around just fine with it in there. Hope that helps you decide.
__________________
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
